LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
Posted on Aug 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Door doesnot close
Door is not closing . looks like locked..child lock????how to unlock it...
  • 1 more comment
  • Anonymous Nov 30, 2008
    my door will not close either on my lg dishwasher, this thing is a piece of junk... it was never really dried the dishes or even close to it. the look like they were sprayed with water when the 2 HOUR cycle is over. great product.....!
  • Jeff Meyer May 11, 2010
    What is the model number of your dishwasher? Please confirm it is/is not an LG LDS 5811 (or if not, what is it?)
  • Anonymous Mar 17, 2014
    i cannot get door to lock, lock is closed
Jeff Meyer
Level 3:
  • Master 423 Answers
  • Posted on Apr 10, 2009
Jeff Meyer
Master
Level 3:
Answers
423
Questions
5
Helped
287302
Points
1081
The LG LDS 5811 and all models that start with 'LDF" do not have a door latch. They do have a child lock _but_ that feature does not lock the door closed or open, it just locks the controls so the DW can not be turned on or settings changed.
So, please look at the right side edge of the opened door and post the model # back here.
Thanks!
Child lock on, tried open Door Handle from inside, is the handle broken no longer open Door from inside even when child latch off 2003 Cadallac Deville
Hi. Try : unlock the car ( push open 3 times) open doors from outside ( make sure they unlocked) switch child lock to lock position and back to open. Pull again on the handle after you switch before you close the door. Let me know if it helped.
How to open back doors
You have to remove the door panel with the door closed, then switch the child lock to "unlock"
Mitsubishi express van from 95. When I close and lock the passager door ( with the inside button or the key ) i can open it with the outside without unlocking it. From the inside i can't. Any idea ?
possible child lock level on the door that has been moved to the lock position check door for a child lock on the edge of the door that closes in contact with the body of the car when you close it..
Unlock child safety lock
The ones I am familiar with are a simple lever that you move up or down and are in the face of the door near the door lock mechanism To lock or unlock it is just a matter of moving the lever.
1helpful
My rear passenger side door will not close
Just use the outside door handle and pull on the latch that is closed. If you use the inside door handle then you will have to undo the child lock.
Pull on the latched that is closed while holding the outside door handle....Make sure that it is unlocked...
Right rear child lock is on the door but cant get the door open
Child Locks will stop anyone on the inside of the car from opening the door. If the child lock is on then the door can only be opened from the outside of the car. Of course the main door lock must be off just as any door must be unlocked to be opened from the outside.
Now if you do not want the child door lock to be on then you must first open the door from the outside with the main lock open or unlocked. Look at the space that is covered when the door is closed. There you will see the lever that turns the child lock on or off. Simply move it to the off position.
Good Luck.
2answers
Just bought an 03 Focus. Cant unlock the child lock. There is no small hole in the door or I cant see a switch to unlock it. Help!!
I don't have this vehicle, but a quick web search indicates one of two ways to accomplish this task. Most sedans, SUVs, and such these days have child safety locks on the rear doors. Almost always, this switch is located on the rear face of door (the area that can't be seen when the door is closed). The general way to lock / unlock is to open the rear door and push a switch to the appropriate icon (either an open or closed padlock). The other way that I found, specific to the Focus, is to use your ignition key instead of a switch. Take your key to the back door, open it, and look for a keyslot that is in the area of the icons. My research indicates that the key vertical is locked and the key turned horizontal is unlocked.
Good luck.
1helpful
Have 2000 hyundai elantra cannot open both rear doors from inside or outside.They seem to be locked.called dealer want 90.00 just to look. how can door panel be removed without opening door?
Sounds to me like the child locks are on. Make sure the doors are unlocked first( if they are power locks unlock them manually to make sure they are unlocked), then try to open from the outside. It's just odd that both doors are doing the same thing. If that works, and you get both doors open, there is a small switch to disable the child lock near the latch on the door.
Door panels generally can not be removed with the door closed. There are plastic rivets that pop out when pulling the door panel away from the door frame.
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
