Question about GE Kitchen Ranges
Stove Top Knobs "Frozen"
My mom gave the stove a good cleaning two days ago. Right after the cleaning the stove top ignition started clicking and wouldn't stop. We unplugged the stove for 24 hours as instructed by the owner's manual. While unplugged we were still able to light the stove top burners manually. However once we plugged the stove back in the stove front knobs will not move at all. Usually we have to push in then turn to start the burner but now the will not push, they will not turn nothing. We removed the knobs, made sure they were on correctly and still frozen. Oven works fine its just he stove top. Any help would be appreciated.
  • 161 Answers
SOURCE: GE profile glass stove top
You got one or more of the burner switches wet. (It usually happens when you wash the knobs and water stays in the holes until you replace it on the shaft) If just water they may work after a day or two. try using a hair dryer, Keep it at least 12 inches away. If oven cleaner or other chemical got inside switches they may need to be replaced. If you can't dry them out. Disconnect the wires from all but one switch at a time and see which one/s need to be replaced. Sometimes the electric part of the switch can be seperated from the gas part and replaced seperately. DO NOT LEAVE THE STOVE PLUGGED IN until you fix this problem. There have been reports of fires started from this electrical problem. You could also burn out the spark ignightor. The fire problems have been mostly with Maytag/Jenn air products but my whirlpool blew a fuse and shot sparks when this happened to me. I just replacet the whole cooktop as my gas valves were one piece units and way to expensive to repair.
Posted on Jun 29, 2008
rickzilla
  • 706 Answers
SOURCE: ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
leroyal
  • 2120 Answers
SOURCE: Plastic knobs melt when oven door opens...
No, really a dumb idea by GE!
Posted on Feb 21, 2009
jumptrout51
  • 3361 Answers
SOURCE: Ran auto clean for oven and cleaned stove top, not auto lighting
One. DO not use self clean on ranges unless you want to replace parts.
Two. Replace the thermal overload fuse.
Three. The manual should be in the console head.
Posted on Feb 22, 2009
  • 3 Answers
SOURCE: I need metal replacement stove knobs.
The plastic knobs melted on my new LG stove the first time I used the broiler. It is a Model LRG 30355ST. I called their service number (1-800-984-7469) and they were very sorry but I would just have to order new plastic knobs. They also advised me that I should have purchaced an extended warranty. Maybe I will just purchace another brand next time.
Posted on Dec 12, 2009
My Jenn Air Electric stove is making a clicking noise. When I put my hand on one of the cook top knobs I can actually feel a vibration when the click occurs. What is this?
Gas stove? LP? It is probably the electric spark ignitor. Many times when you clean the stove top water from the sponge gets below. The water droplets (align mysteriously) make the connection between the wires, and the stove thinks it's supposed to be igniting. When the water evaporates, the switch will work fine again & the clicking should only occur when igniting & then backed off.
This happened to me once before.
Nov 21, 2010 | Jenn-Air 4 in. JEC0536ADS Electric Cooktop
After cleaning the stove top the 4burners turned into continuous ignite mode
You probably got water under the cooktop while cleaning around the knobs. It causes a short at the 120 volt igniter switches on the shaft of each valve. Unplug the stove for 1 or 2 days and let it dry.
Jan 18, 2010 | Cooktops
Right side stove top igniters dont fire off of right side knobs+
clean the pilot jets out sonds as if they are clogged. if the right side is only being lit once the left side is on then you better not run the right until you do get it fixed as more than likely whats happening is the enough gas is traveling through the chamber to be ignited by the left sides flame and that can be dangerous, however your stove uses an electronic lighter all you need to do is clean the contact points so that they will spark cleanly if it still won't light you need a repairman.
Dec 07, 2009 | Ovens
Ge profile stove top strikers stuck on
If water or liquid gets in the switch it can short the circuit and cause the igniters to fire.....try pulling the knobs off and hairdrying the switches..i had one that sparked for 2 days before they finally stopped. good luck :)
Jun 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
3 of 4 knobs do not compress to turn on gas
You must replace those controls. Cleaning or loosening them up would be temporary at best and the next time they stick it could be in the open position. Safety first...Eric
Jun 14, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Feb 22, 2009 | Kenmore Kitchen Ranges
Tried to clean top of jenn air stove
If this is a gas stove, you've shorted out the ignitor circuit.  If it is electric...you may have gotten some of your cleaner into one of the controls.  See what doesn't work and trace from there.
Dec 14, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
Ge spectra gas stove top not lighting
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
