My computer won't read my sandisk 8gb sdhc microSD card throught the sd reader port
  • 3 more comments
  • skootermarx Nov 27, 2008
    I have a SanDisk 8G microSDHC which I cannot read when insterted into the SD slot.
  • jdanielmoore Dec 31, 2008
    mine is the gateway GT5220 and it will not read anything over a 2GB. Is it a problem with the size???
  • Anonymous Apr 20, 2009
    Same issues here as well my pc wont read my card in my sd slot any ideas ?
  • Anonymous May 02, 2009
    Sansa e280 - Windows XP can't access the Micro SDHC card. Why?
  • bethnoel8 May 19, 2009
    I have the SanDisk 8 GB Micro SD and my Dell won't recognize it. Any thoughts?
    Problem Solver:
  • 14 Answers
Yes, some of the older readers will not recognize SDHC larger than 2G. you can buy a USB SD card reader off Ebay from Hongkong for a buck with shipping.
Posted on Sep 22, 2010
Why wont my computer read my SD card? i have a Samsung TL210 double view hd camera. when i put my 8gig SD card in my computer nothing happens at all i have a vista computer ok. i am 13 years old so make...
If the 8Gb SD card works on your HD camera, then the problem is with your built in memory card of your computer. Most of the built in memory cards of the computer only supports up to 2Gb.
You can actually isolate it by trying to test an SD card lower than 8Gb to your computer.
Solution for this is to use external USB SD reader that supports high capacity SD card (SDHC) or contact the manufacturer of your computer and ask for firmware updates for the memory card reader. Hope this is clear and would help you.
Jul 01, 2011 | SanDisk 8GB microSD High Capacity...
My San Disk micro SDHC Memory Cards 8GB wont format and when put in a device it heats up. What is wrong with it?
technically, some card readers dont have any regulators to minimize the voltage to read a microSD.. some direct card reader can destroy/ damage your memory card.. try to use an all-in-one card reader, or a microSD adaptor then put it in your card reader slot..
Card reader slot in laptops made for memory cards only.. =))
Feb 15, 2011 | SanDisk 8GB microSDHC Memory Card with...
SanDisk 2GB microSD Memory Card not working
SaveMyUsb.com can recover data from most flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 18, 2010 | SanDisk 2GB microSD Memory Card
Where can I insert my mini sandisk memorycard into my toshiba laptop? I see no slots for it.
If you have no SD slot on your laptop, you will have to buy an external USB SD reader. They typically cost $5-$10, and are readily available online (e.g. http://www.buy.com/prod/micro-sd-sdhc-card-usb-reader-for-1gb-2gb-4gb-8gb/q/sellerid/23962916/loc/101/213271933.html) or in almost any store with a good selection of electronics.
Dec 06, 2010 | SanDisk 2GB microSD Memory Card
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
When i insert my 8 GB micro SD card it says the same thing.
Your 8GB card is considered "high capacity". You will need an SDHC USB card reader to read it.
Jun 24, 2009 | SanDisk 8GB microSDHC Memory Card with...
I have a 4gb sandisk micro sdhc with adapter and the computer freezes when i have it in the sd drive.I have a hp pavilion a1 a1203w. Is there anything i can do?? Please Help
I had a similar problem not long ago. The SD and SDHC standards are different. SD only goes up to 2GB, and SDHC (high capacity) goes higher than 2GB. THe problem is that SD card readers aren't capable of reading SDHC cards, even though the card will physically fit into the card reader slot. When you insert an SDHC card into an SD card reader, the reader attempts to read the format, and locks up the OS while trying. You'll need to get an SDHC card reader and use it separately like through a USB port or something.
May 13, 2009 | Computers & Internet
Micro sd card not working
I'm having the same problem with a Transcend 4GB microSDHC card / microSD adapter. I have also found it probably has something to do with the card reader...either the card reader is an SD card reader trying to read an SDHC card OR the card reader is not able to read high-gigabyte SD cards (over 1 GB in some cases).
Jan 23, 2009 | SanDisk 4GB microSD High Capacity Memory...
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
Computers & Internet Logo
595 people viewed this question
David Payne
David Payne
