Computers & Internet Logo
Posted on May 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have PrintMaster Platinum 15. I love it! burt recently it is saving cards under the wrong name or wrong picture and I am unable to correct it. I save the cards on an external drive. but when I go to my project the latest saved cards are listed incorrectly. I also have The Print Shop Publishing Suite and I am unable to install it on my new computer.....I have lost access to these card.
  • prpconsl May 16, 2011
    I have tried this and I even tried saving currently created cards under another folder and I still have the problem.
Lee A.
Level 3:
  • Master 4,472 Answers
  • Posted on May 16, 2011
Lee A.
Master
Level 3:
Answers
4472
Questions
0
Helped
1083181
Points
12549
First thing I would attempt to do is uninstall it and reinstall it and see if that will fix your problem.
Thank you,
Lee
  • Lee A.
    Lee A. May 16, 2011
    I would suggest then updating to the latest version you can purchase it for about 30$. 15 is quite old and not even supported anymore. You can go to their website to get platinum 2011 for 30$ right now:http://www.broderbund.com/
Our business has been using Printmaster 15 for a few years now. We recently bought a new computer with windows 7. Printmaster 15 is obviously not compatible with Windows 7. I bought printmaster 2011...
You can try version 15 in compatibility mode:
Troubleshoot Compatibility
This can help with some (but not all) programs/drivers:
1) Uninstall the program if it's already installed. Then when you install/reinstall it instead of double clicking on the install file right click it and select "Troubleshoot Compatibility"
2) Then click "Try Recommended Settings" and in the next window click "Start the Program" to install it.
3) After it installs see if it works correctly. Please note - some programs may not be able to run in Windows 7.
More details about how to make older programs run in this version of Windows:
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
My problem is printing a section of a saved jpg. graphic. All parts of the poster print correctly except for one section that prints two letters in block instead of the arched shape of the text block. ...
I haven't used that version of printmaster but if you can see it correctly on the screen but not when printed I would check the name of the font used and then check to see if that font is installed in windows. Go to the font folder and look for it. If i recall PrintMaster comes with some fonts that are not included in windows. You can add fonts to windows btw.
Printmaster 17 does not save as pdf files under
Here's my solution: Don't waste your time and money on, use a program other than PrintMaster! PDF is universally accepted across formats/browsers/OS ...what kind of program would not export THE most commonly used format????
I recently had my computer serviced for a major virus attack. System operates on Windows XP. I now cannot open PrintMaster Platinum 12. I get a message "cannot determine configuration." Additionally, I...
May have to uninstall it first, then reinstall it.
Click START button, lower left corner
then click Control panel
then click on add or remove programs
*see if your product is listed(may be under BRODERBUND or other publisher name)
If it IS listed, uninstall it
Or sometimes the UNINSTALL is included in the CD options:
Insert the cd into the drive
go to my computer
find the cd drive
right-click the drive
select "explore"
Look for an Uninstall program
Hope this helps!
hansola
2helpful
PMSUER.DAT message on Printmaster Platinum 15
Have a look here.
http://support.encoreusa.com/kb.asp?id=144
3helpful
2answers
Cant save to pdf in printmaster gold 17
found the fix for printmaster 18 broderbund pdf saving problems...
1-close all open programs and return to desktop.
2-click START and choose CONTROL PANEL
3-click PRINTER
4-right click on BRODERBUND PDF CREATER, then select PROPERTIES (the broderbund PDF creater properties window will open)
5-click the PORTS tab, then select ADD PORT button. (the printer ports window will open)
6-click NEW PORT, then enter PMPDF in the ENTER A PORT NAME window, then click OK
7-click CLOSE at the PRINTER PORTS window. you will now be looking at the broderbund PDF creater properties window
8-a check mark will be located next to the new PMPDF printer port. click APPLY. the broderbund pdf creator will now be located next to the new port. click OK.
9-exit all windows and restart the computer. once the computer restarts, you can save your project as a pdf file.
1helpful
I have the Printmaster Platinum Version17 , I cannot save to pdf files?
1. In Tools/Options/General Options, check the box beside "Optimal Printing Resolution".
2. Go to File/Printer Setup/Printer Setup.
3. Under "Name" select Broderbund PDF Converter v2.10d
4. Next, go to File/Professional Printing.
5. Select "Save As PDF".
6. At the next screen, type the name of the PDF file you want to save in "Project Name".
7. Under "PDF Resolution", select 600 dpi.
8. Click on "Save As". In the next window, browse to the folder in which you want to save the file (for example: My Documents).
9. Click on the "Save" button.
10. PrintMaster will save the PDF file to the folder you selected.
11. Open the file in Adobe Acrobat to make sure all the elements and pages are there and that it looks as expected.
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
