Question about RCA 32V550T 32" TV
RCA 32v430t Fuse Installation
I need written procedures, schematics and directions on replacing fuse.. The fuse is blown and not sure how to replace.. Symptons are black screen on power up.
This is a very simple fix. I bought fuses at Radio Shack and have to replace one every 6 months or so. Just lay the TV on a towel or something on its face. Pull the screws out of the back - all the way around the edge and a couple on the top of the input/output panel. Trace the power cord to where it attaches to the circuit board and next to it you will see the fuse.
Replace fuse, put it back together and it should work.
Posted on Aug 16, 2008
I have a rca rtd255 home theatre system with two blown fuses. fuse one has 5s3a 250v and fuse two has 5s2.5a 250v written on them. I cant find these fuses. where do i find or what can i replace with
The fuses in question probably are 5 millimeters in diameter by 20 millimeters in length. You might be able to find them at Radio Shack but they also might have to be special ordered.
Sep 26, 2014 | RCA RTD255 System
My windshield wipers fluid motor stoppped working,is there a fuse I need to replace.I have a 2007 ford edge
Hi the chances are its not a fuse thats gone its more likely going to be that the motor has seized this happens if it hasnt been used for a while.
If you look inside the fuse box you should see printed on the inside lid the location of all the fuses and if its not written on the inside of the fuse box then the chances are it is going to be written inside the owners hand book, so look in their and then check the fuse for that part.
If you cant find any fuse location instructions then just look inside the fuse box and replace any fuses that are blown if you find any then if it is a fuse you will find a blown one and then should solve your problem.
So if you find no blown fuse then the chances are its going to be the motor this would need testing to see if you hed power going to it if their is no power going to the motor then this would indicate the switch itself was faulty and would need replacing.
Let me know how you get on or if you need further assistance ok
Jan 03, 2010 | 2007 Ford Edge SEL Plus
Set is dead
Replace the Horizontal Output transistor and High-Voltage Transformer.
Set will come on, if it goes back off,solder around the switch mode power supply even if it looks good.
NMHS Health Services Audio Visual Department
Jan 16, 2009 | RCA 32V430T 32" TV
How to change the fuse on a RCA 35317 television
1. Remove the old blown fuse and order a replacement
2. Replace the old blown fuse with the new fuse
Selah :-)
Sep 15, 2008 | RCA Televison & Video
Mine does the same thing I'm thinking a fuse has blown out and if taken to a tv repair shop or finding the right size fuse you can fix or get it fixed yourself..
Apr 10, 2008 | RCA 32V430T 32" TV
RCA HD Projection TV Model HD52W59
you have a fusible link that has blown. This is what causes the convergence option no be erased from the menu. You will need to locate the blown link and replace it. They are identified by FLpreceeding the location number on the circuit board such FL221 and etc.
Mar 23, 2008 | RCA P61927 61" Rear Projection Television
Rca 32v434t schematic
www.Service ThankYou for using FixYa. Have a Nice Day.
Feb 08, 2008 | RCA 32V430T 32" TV
RCA 32V430T 32" won't turn on!
The fuse is inside the set and is probably ok, but check to be sure. If you have an ohm meter I would check the horizontal output transistor first. It is a big transistor on a heat sink next to the FBT. It has three pins, check the center pin to one of the others, if low the transistor and probably the FBT is bad.
Sep 05, 2007 | RCA 32V430T 32" TV
NO POWER, Yes blown fuse.
Was this the 220 ohm in the power supply??? and if the 5 amp blew right away then it probably took out the bridge rectifyer with the power surge that comes alog with hurricane damage to the power lines as I used to live in florida and repaired lots of sets damaged from storms!! After you check the bridge rectifyers I would start looking to find any other shorts. First measure across the ac line with the fuse replaced but not plugedf in . If its shorted check what I mentioned before if its good after you replace the shorted parts you maybe in luck. need more assistance go to sams photo facts download a schematic and we will trouble shoot this together if you post it here so i can look at it. good luck
May 02, 2006 | RCA P52929 52" Rear Projection Television
RCA 32V550T 32" TV Logo
115 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
