Question about Sony Cyber-shot DSC-W55 Digital Camera
Lens will not focus, "access" screen, lens reluctant to retract
I've had the same problem as that of several people who have already posted here (the problem where the screen says "access" and the lens goes partially in and out, makes a clicking noise, and eventually retracts itself after pushing "on/off" like 4 times. But, I've also had an additional problem, which is:
The camera works when I initially start it up after not touching it for a few days, but the lens is really not focusing at all. The pictures are unfocused (but not grainy, if that makes any difference - just generally unfocused). I've tried turning macro and on and off but it doesn't change anything. It just seems like holding the picture-taking-button halfway down to focus doesn't do anything at all. After I go to the picture viewing screen, I can view the pictures, but then once I try to go back to the picture-taking mode, the problem with the lens not wanting to retract and the "access..." on the screen occurs.
The problem started soon after I uploaded a bunch of pictures on to my computer (the pictures were fine, which was pretty fortunate) and I accidentally left the camera on and the battery ran out. I'm not sure if that gives you any insight...
Anyway, I'm really frustrated because these problems happened only a few weeks after my warranty ran out, so I really don't want to have to send it in for repair. Any help would be greatly appreciated! If you are unable to offer a solution that works on my camera, however, then if you could offer a rough estimate on how much it might cost me to send in my camera, I would really appreciate it. If that's not possible, it's okay, but I really just want a ballpark measure so that I'll be able to make a decision on whether or not I should get it fixed or (very unhappily) invest in a new one.
Thank you!
  • emlad Aug 14, 2008
    Edit: I also banged the camera around, which several people have suggested as a solution (and it does seem to be successful, in most cases!), but unfortunately it did nothing for me.
  • Sony Master
  • 1,800 Answers
I guess that u shud change the focus oart of camera and that is no esay u jst give it toa repair guy!!
Posted on Aug 14, 2008
  • Jalal Sordo
    Jalal Sordo Aug 16, 2008
    look sorry but i got a solutution for u
    u need to upgared ur webcame
    its need a newer firmware cuz the one that u got has corrupted by those pictures that u download
    get a upgrading utility from the sony download cneter
    thanks fro the rating
System Error (Focus)
The systems control board has detected a problem with the auto focus lens, the focus is controlled by a tiny motor that has jammed or there is a mechanical issue with the camera lens. It will require a technician that is highly skilled to deal with the situation, but the repair cost would probably not be justified.
Jan 12, 2011 | Panasonic DMC-FX37 Digital Camera
After reading SteveGorak's experience, I placed the vacuum end of my...
This is a tip explaining how we can try to resolve a lens error.
Firstly you will need to understand what exactly the lens error is, and how it came to happen.
The most common cause for a Lens error:
  • Misaligned Lens rings
  • Sand and grid wedged in between the lens and the barrel.
  • Dropping the camera
  • Ran down battery
Here is the Fix:
  • Batteries
Firstly you can try removing the batteries and replacing it with a new set of fully charge ones(2500mah).
  • Memory card
If the batteries ran down while you were taking photos with the lens extended, you might also get this error. Remove the the memory card and replace the batteries with a fresh recharged set. Try to power on the unit with the fresh set of batteries while the memory card is removed.
  • USB cable
Connect your camera to your computer using your USB DATA cable which came with the camera. Once the camera gets power in this mode, the screen should stay off, hence, supplying the lens with more power to push or pull out/in.
  • Barrel Guide Pins
Place the camera on a sturdy table with the lens pointing to the ceiling. With a fresh set of batteries installed(Do this without a memory card) hold down the shutter button while you power on the unit.
  • Compressed air and Vacuum
Now, you can either use a compressed air canister to blow around the lens area. This will result in the sand or dust particles to be blown out of the area between the lens and the barrel. Or, you can use a vacuum and and carefully place the nozzle around the lens to **** out the particles.
The following Fixes will be done at own risk and can even further damage you camera.
  • Tap your camera with the palm of your hand a couple of times to displace the lens into the original position, or to dislodge particles in the lens barrel.
  • Try gently pushing/pulling/wiggling the lens while powering up the unit.
I hope this can help you to resolve this problem, and send you well on your way to experience that Legendary Kodak moment.
Kind regards
on Sep 06, 2011 | Cameras
Turns on for 1/2 second and turns off
It sounds like the focus element inside the lens is stuck. This is usually either due to an impact knocking the elements out of alignment, or to sand/debris entering the focus motor's gear drive and preventing it from rotating. The buzzing sound you hear is the focus motor attempting to rotate, but buzzing up against some obstruction. When the lens extends, you hear a buzzing sound, and then the lens retracts - this is usually the cause of the issue. Unfortunately there is not much you can do externally to fix this problem. The camera will need to be taken apart and repaired by a professional or by the manufacturer. David Millier
Jun 05, 2007 | Casio EXILIM EX-Z1000 Digital Camera
Fine-Pix A400 is showing Focus Error and will not allow photos to be taken. In addition, the lens will not retract when the camera is shut off. This problem occurred after using the zoom procedure several...
Here is a quick fix to try. If you attempted to remove the focus error doing the 3 times on and off, and it didnb't help to this. Power the camera on, you will hear the gear skipping as if it is slipping. Right at the moment you turn of the camera push the lens in manually slightly and gently. This will reposition the timing of the lens to focus. This usually fixes the Focus error when the lens is stuck in the out position and never retracts. I have had this happen twice, and it cleared both times by doing this. Good Luck
Jul 22, 2009 | Fuji FinePix A400 Digital Camera
The lens will not retract when the camera is turned off. the screen says focus error when the camera is turned on. is there a way to fix this problem?
I was able to lightly tap the lens in with the tip of my finger while turning the camera off. Then I applied a little pressure on the lens while turning it back on. I guess I was thinking that I would make the lens work a little harder to come out and tighten whatever may have slipped or something. Anyway, after dropping it on carpet and tapping the lens, then the pressure.... It works. Hope this helps..
May 09, 2009 | Fuji FinePix A500 Digital Camera
Canon S80 lens won't retract
I have the same camera and had this problems today. My son solved the problem for me. He put his thumbs on each side of the lens and pressed inwards causing the lens to pop out. Since then, I have been able to close and open the lens repeatedly without any problem. Hope this works for you. Good Luck!
Nov 29, 2007 | Canon PowerShot S80 Digital Camera
Hello, there is a problem with the optical unit (lens). Normaly when the camera is in camera mode the lens should go out. In your case it seems that for some reason the lens is stuck. Please contact your nearest Sony dealer. If you want to repair the camera yourself please tell me. I can send some additional info as well. Regards, Arpi
Jul 12, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Lens error
The most common cause of this issue on the L3 is an impact which dislodges the focus element in the very front of the lens. The metal platform that the focus system is mounted to is attached with 1 screw and is able to flex slightly under stress. When impacted it flexes and allows the focus drive to become misaligned. The lens still technically works but the camera senses that the focus is jammed and leaves the lens extended so no components will be damaged by retracting. This repair costs $145 at my shop, not an economical repair for this camera. Some parts of the focus element are accessable from the front of the lens. You can remove the metal cover (it is glued down). Generally you will not be able to re-install the lens barrier, but it can be removed without harm to the camera. When you remove the plastic plate which carries the lens barrier you will see a small metal gear, this is the base of the focus drive.
Jun 13, 2007 | Nikon COOLPIX L3 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
158 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
