Question about Magic Sing Along Consumer Microphone
Can't power ON...
Were using the Extreme Magic Sing and now we were not be able to power on even if we press the "Power ON" many times. Before, we usually keep the magic sing with the connector still connected to the mic so I'm thinking the connector has been broken or something.
  • 1 more comment
  • Anonymous Dec 23, 2008
    can anyone help me get the pin outs of the connector? I may have to DIY to fix it.
  • Joe
    Joe May 11, 2010
    hi im joe,
    i need some additional information so i can provide you a solution. may i know the model of your magic sing? if you can provide a picture it will be a great help.
  • Anonymous Mar 19, 2014
    wow magic sing premium
See if the microphone connector wiggles. It shouldn't move, but if it does, the legs on the connector can snap inside.
Posted on Nov 19, 2009
Magic Sing ET19KV On connecting Magic Sing through RCA Cable, get buzz sound on my speakers Have chked on diff TV's and replaced the RCA cable.The Video is clear, but getting buzz on speaker
Most buzzes are caused by one of two things: "DIRTY" power or a lifted\non-existent ground. Allow me to explain;
"DIRTY" power is just that. It comes in and carries a lot of static with it. Most newer systems have filters built in on the power side of the main board. The fix? Try running your Magic Sing from a wall socket that doesn't have anything else pulling from that particular circuit. You should also invest in a GOOD power strip and not one that cost $5-$10 bucks. All these are good for is getting power to multiple products simultaneously, AND they don't have the resistors and filters to give you a constant 120v AC.
Monster Cable Co. was a very sought after item up to the point to where Radio Shack no longer carried their products.
If you really want to get your money's worth out of the instruments you buy, don't slack on the power strip. This will be the most costly mistake ANYONE can make.
Here is an article that explains what I did and gives you answers on how to fix this issue.
Hope this helps. Dirty Power What It Is and Why You Need to Clean It Up Schneider Electric...
Aug 12, 2017 | EnterTech Magic Sing Et19k Et-19k Et19kv...
I dropped the mic of my magic sing and now it won't even turn on even with new batteries. My brother tried to open it and he said everything looks fine inside. I don't know what else to do. Help!
Dropped microphones could disconnect the display/control board from the motherboard. If so, you cannot turn it on using the power button and neither could you see anything on the display. To correct this, you have to open up the unit so as to push the mother board unto the display/control board.
Oct 31, 2015 | Magic Audio Players & Recorders
DELAYED AUDIO USING MAGIC SING ET23KM
Where did u buy this from? I have not heard of this model yet but I might be able to help.
Nov 08, 2012 | Magic Sing Along Consumer Microphone
Interference problem on my wireless magic sing, i can hear the voice of my neighbor using her own wireless magic sing on my sound system and vice-versa, it's annoying. what should i do?
The magic sing has an omnidirectional antenna which is unnecessary since you will be standing directly in front of it while using it. I recommend you take an aluminum pie plate or other aluminum piece that is larger than the antenna and place it directly behind it, perhaps even held on by tape to the antenna. You can even bend it around the antenna in the form of a V with the opening towards you, where you'll be holding the mic. This will block the other signals from your neighbor while still allow you to use it. It may even block your signals from leaking onto your neighbor's unit.
Jan 23, 2010 | Magic Sing Along Consumer Microphone
Change from PAL to NATSC
hi there...try this
1. turn mic off
2. press and hold 8, then press power button (to change to NTSC)
press and hold 9, the press power button (to change to PAL)
Mr. Sean A. DelCarmen
Customer Service Dept.
In A Jiffy Ent. - Wow Magic Sing
1081 EDSA Balintawak
Quezon City 1106 Philippines
customerservice@magicmic.com
Mar 02, 2009 | Magic Sing Along Consumer Microphone
Change from PAL to NTSC
You need to configure it out.
1. Connect the magic sing in your TV
2. Turn on your TV
3. Magic sing should be Off
4. On your magic sing; Press and Hold "8" then while holding "8" press "power button", count for thre seconds then release both buttons (PAL to NTSC)
or
On your magic sing; Press and Hold "9" then while holding "9" press "power button", count for thre seconds then release both buttons (NTSC to PAL)
Magic sing karaoke
has anyone found a solution for this?????????????????????????????????????????????????????????????????????????????????/
my sisters stopped working... the blue light on the base goes on.. the mic lights don't work and the screen doesn't work
Sep 25, 2007 | Magic Sing Along Consumer Microphone
Magic Sing Along Consumer Microphone Logo
475 people viewed this question
Top Magic Audio Players & Recorders Experts
Michial Gueffroy
Lyle Siemens
Lyle Siemens
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
