Question about Pioneer TS-A1057 Coaxial Car Speaker
Popping noise have a 94 saturn sl1. right rear speaker just getting a popping noise. thought i had a bad speaker so installed new ones . still have problem
  • 69 Answers
Its a wiring issue. Check the wiring harness (if used) and make sure all wires are intact. Same with the wires at the speakers. Make sure all speakers and head unit are properly grounded. Hope this helps!
Posted on Aug 14, 2008
Where is the ground wire for tail lights on a 1999 saturn sl1
The left and right rear ground points are on the rear package shelf near the left and right speakers. Remove the trim and you'll see the ground screws on both sides.
Dec 06, 2017 | Saturn Cars & Trucks
NEW STARTER DOES NOT SOUND RIGHT DOES IT NEED SHIMS
normally shims are not needed on anything newer than a 1988.. if it doesn't sound right it may be the wrong starter. teeth not lining up on flywheel.. change the gear on the starter with your old one and see if that fixes your issue. pitch of the teeth could be different
Jul 14, 2012 | Saturn Cars & Trucks
2002 Saturn SL1, 72K miles. Hasn't been driven in
Single click? More battery is needed. Id change the battery, or slow charge it.
Might also be the security system shutting down the starter. Common on GM vehicles. Heres a link on that. http://vatspasslockpasskeysecurityhelp.yolasite.com/
May 27, 2011 | 2002 Saturn S-Series
I just got my Pioneer DEH-7200HD Head Unit. The problem is that it doesn't come on when I hook it up. I've tried everything. even touching the ground and positive wires to a 12volt source and still...
This should be the wiring information: 1998 Saturn SL Stereo Wiring Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6 1/2" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue If you have additional wires, I would see how much voltage is running through them.
Apr 12, 2011 | Pioneer DEH-P7200HD Car CD Player
Saturn wagon SL1 Door locks go crazy.....
Having same problem...did you get any help?
Jul 27, 2010 | 1998 Saturn SL
94 Saturn sl1 tbi, started running rough. Changed the plug`s it still no better. It dies if i turn on the air. Lack of power.
Change your ECTS sensor with a brass one, it's the water temp sensor you can buy it at auto zone for 8 dollars and replace it yourself, make sure you get a NEW wire plug harness for it probably about 10 or 15 bucks, it gets corroded then the computer reads the wrong engine temp then it makes the idle rough and run rich.
Mar 31, 2010 | 1993 Saturn SL1
The plug has been cut off that connects to the
Ground Black
Illumination Gray
Dimmer Brown
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Sep 14, 2009 | 1996 Saturn SL
1994 sl1 saturn burning oil
Sound like you solver that problem...your the champ.
Jun 07, 2009 | 1994 Saturn Sl
94 saturn SL1 manual
The treaded nuts on the lines are different sizes. They only install one way.
Jul 30, 2008 | 1993 Saturn SL1
1994 saturn SL1
This vehicle has an electronic variable orifice rack and pinion steering system.
Charlie
Jun 11, 2008 | 1993 Saturn SL1
Pioneer TS-A1057 Coaxial Car Speaker Logo
141 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
