Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Lawn mower not starting/primer not functioning
Hello! I took out the carb and cleaned it out. Worked for a couple mows but back to the same startup problem. Replaced the spark plu\\\\\\ this is normally the problem but a no go this time. I have noticed the primer doesnt function properly. I prime and dont see/feel the gas being loaded into the main chamber. I did notice the gasket has deteriorated partially from the primer. So I assume the solid seal (gasket) is the reason I dont see or feel the gas loading into the chamber being the problem? Can I pick up this gasket as local home depot. Troybilt machine.
Thank you,
Scott
  • jwwende Aug 24, 2008
    I am having the same problem what was your solution?
    Champion:
  • 313 Answers
See www.smallengineadvisor.com for trouble shooting & repair.
Posted on Aug 16, 2008
Victa v160 runs for a while then stops
Ignition module is failing
Oct 14, 2012 | Garden
I took my toro 6.5 lawnmower carb apart and cleaned, now fuel spurts out of red tube into the air cleaner. Why is this happening?
Sounds like you assembled something wrong when reinstalling the carb. Or your missing a step or two.
Mar 18, 2012 | Toro Power Lawn Mower
Poulan pro 550series lawn mower rust from tank plugged carb, took off tank and carb 3 or 4 times and cleaned , last time fixed rust problem primer bulb started to flake sending small pieces into carb....
You still have trash in the carburetor blocking or partially blocking. You are going to have to get some spray carb cleaner and be very thorogh about cleaning it, every hole, every passage, every thing. While you are at it if you have not recently changed the diaphram, go ahead and do that since you have it apart. The diapham is not expensive.
Sep 20, 2011 | Poulan "Poulan" Push Mower
SmengesI have a briggs statton 6.75 series Craftman lawn mower 21" cut ,that I cant start. Recently serviced with spark plug, oil and air filter replacement. Brought it home and it the same problem....
I can only go by what you say was done. If you took mower to repairman then it should run. If you took to a buddy who thought he knew, WELL.
Try this first. The primer button is a round button usually BLACK, CLEAR, or RED. Look around your mower and you will find it at the end of the carburator. Carburator is opposite the muffler on your mower. With new gas in your mower ,press the primer button three or four times. Try to start. With all you have done it should start. If it doesn't start, think back and try to remember if you hit something while mowing, if you did then your problem is your timing. With the hit you sheared your timing key. This key keeps your fuel ,compression, and spark happily together to keep your engine running.
Check the other things first and please get back to me, I will be more than happy to help you further. GOOD LUCK.
Sep 01, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Will a hole in the primer button cause the lawn mower to shut off after it's started for only a few seconds?
Not typically. Remember some primers have a hole in them to function as a vent for the carb.
Short runs (2 to 3 seconds) are usually caused by a blockage in the carb's main or idle jet.
I hope this helps.
Aug 29, 2010 | Craftsman Garden
My mower wont run. Unless I put gas in the carb...please help...
I think my mower is doing the same thing. There is no fuel getting to the carb but there is fuel being pumped through the filter. I took the bowl off the carb hoping I would find an obvious problem but nothing looked out of place. Get this, when I put the bowl back on the carb, it started! I mowed the lawn thinking I inadvertantly fixed the problem. A week later I went to mow again and the same thing happened agian, it wouldn't start. So, I did the same thing and took the bowl off the carb, looked at it and again nothing looked out of place, put the bowl back on and again, it started!
I think the float is somehow sticking. When I look at the inside of the bowl it has slight vertical rub marks as if the float is rubbing and possibly sticking to the side of the bowl but why would it start doing this after two years? I'm no expert technician but I know floats don't grow and bowls don't shrink. Hopefully someone out there will have a solution for both of us...any takers?
Jun 28, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Lawn mower starts and stops right away
take bowl off bottom of carb....clean and reassemble
Nov 16, 2009 | Garden
The toro will start and run for 2 seconds then quit. We took apart the air filter and cleaned the gas line as well as cleaned the plug. No improvement. Thought it may have been bad gas or a plugged gas...
I am not sure what type of carb you have so I will give you a couple of ideas.
1. If the carb is one of the plastic ones that attaches directly to the gas tank take of the air cleaner and press the primer bulb. If you get a spurt of gas and not a stream of gas get a new diaphragm for the carb. It goes between the tank and the carb.
2. If there is a sediment bulb hooked to the carb drain the gas from tank and then carefully remove the sediment bulb and clean it.
3. If there is a sediment bulb hooked to the carb and a flat paper air filter attached to the sediment bulb via a plastic air filter holder with a primer bulb built into the air filter holder replace the gasket between filter cover and sediment bulb.
good luck
let me know if this works.
roundo4
Aug 12, 2009 | Toro Lawn Mower With Toro Power Tools
Toro walk behind model 20025 Gas running through the carburetor
Carb. float must be stuck open. First if you have no fuel in the tank it must all be in the crankcase.Drain the oil and refill and also check the carb as the float has to be sticking open. Hope this will help you. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
My mower surges. its a Murray, model number
first check to see if you have good clean gas in it. No water. if you have good clean gas. then I would recomend taking the gas tank off wich should have a plastic carburetor mounted to it. after that is removed and free of excess dirt. take the carb off there should be 5 phillips head screws. pull the carb off gently while observing just how it all goes back together. you may want to take pictures. you will find a fuel screen that you should take off and clean with carb spray. also there is a fuel pickup tube clean that also with carb spray. a couple words of caution if using compressed air Do not carried away with it. also same with the carb cleaner to much of it in rubber primers is not good.
Mar 10, 2009 | Garden
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
120 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
