Question about VillaWare 320 Power Grinder Food Processor
Villaware Replacement Cutter Blade
I accidentally lost it while cleaning one day, is there anywhere online that one can purchase a replacement cutter blade?
  • BMel Oct 15, 2008
    Thanks a bunch Mickey1999, I'll keep this in mind. I ended up buying a blade from Villaware itself for I think about $9 and change.
  • PETERSFAM1 Nov 19, 2008
    HOW DID YOU FIND THE BLADE?
  • 3 Answers
  • mickey1999 Oct 15, 2008
    BMEL, " I ended up buying a blade from Villaware itself for I think about $9 and change. "
    That's a better price!
    Do you have a Link to Villaware were I can get a Blade?
Need to sharpen the rotary blade
Top 5 Ways to Sharpen a Rotary Cutter Blade ' eBay
www.ebay.com > ... > Quilting > Quilting Tools & Equipment
Since the 1970s, rotary cutters have provided a reliable and efficient method for quilters, garment-makers, and other workers of fabric to create symmetrical and ...
Sharpening and Maintaining Your Rotary Blade from Scrap ...
? 5:54
https://www.youtube.com/watch?v=Kdd3JiWnmtE
Mar 13, 2012 - Uploaded by Craftsy
Sharpening and Maintaining Your Rotary Blade from Scrap Quilting with ... My online Craftsy class, Scrap Quilting: Waste Not, Want Not, will ...
Penny's Hands: How to Sharpen Your Rotary Cutter Blade
pennyshands.blogspot.com/.../how-to-sharpen-your-rotary-cutter-blade....
Mar 5, 2011 - And what has the aluminium foil to do with sharpening rotary cutter ...Thanks for that tip Penny, I have lots of blunt blades I can sharpen now.
Jan 27, 2016 | Food Processors
Where can I get a replacement bag cutter for my food saver
Get them direct
http://www.foodsaver.ca
And instructions.
http://m.wikihow.com/Replace-the-Cutter-Blade-in-a-Foodsaver-Machine
Nov 18, 2015 | Food Processors
This is an inquiry about Waring food processor model FP510; SN# 11FP10. I need a new driver (the thing with a hex head that fits over the axle or drive shaft (one side of the axle is flat) of the electric...
I broke mine too, but luckily I found an extra machine at a thrift store. The driver was missing (of course), but I cut the blades off (hacksaw, easy) and used the resulting shaft as a driver. It works well: better and tougher than the original! Though they are expensive, you can order a new set of blades and do the same thing with the blades you have now. -Paul
Dec 13, 2010 | Waring FPC15 10 Cups Food Processor
Locked in blade
My old Cuisinart has this problem because the motor shaft and the corresponding socket on the cutter are worn. The shaft has jammed in the cutter. To un-jam it, stick a bar of wood behind one blade of the cutter (I use the wood handle of my dough whisk) and give it a light, sharp tap with a hammer. Check after every tap to see if it is loose, if not do it again. You want to tap against the back side of the cutter, not the cutting edge side. The socket on your cutter may be cracked, allowing it to open up and slip (and jam) under the stress of cutting. You'll probably need a new one. If the motor shaft is also worn, that can also be replaced. The new part is about $10. I got a few more months of life from my cutter by reinforcing the inner socket with a thin plastic tube from the barrel of a syringe.
May 15, 2010 | Cuisinart DLC-5 Food Processor
Bravetti Food Processer
You can get parts from this company.
http://www.euro-pro.com/europro/productdetail.aspx?pid=E50ADA3D-BACA-44E7-9E78-05263C526241(Euro-Pro+Base+Catalog)
You can call them as well
For technical support, please call us toll-free at 1-800-798-7398. Hours are Monday through Saturday from 9:00am to 6:00pm Eastern Standard Time.
Jun 30, 2008 | Bravetti Quad Blade Food Processor
VillaWare 320 Power Grinder Food Processor Logo
822 people viewed this question
Top VillaWare Food Processors Experts
Are you a VillaWare Food Processor Expert? Answer questions, earn points and help others
