Question about HP PSC 950 All-In-One InkJet Printer
Loading color cartridge printing okbut showing to check
Printer showing remove and check cartridge but is working ok
  • ellisantiq Aug 15, 2008
    Just followed your advice & the same message keeps coming up. I installed brand new HP ink cartridges & the printer works(prints black only though), but this message keeps coming up! HELP! Thanks in advance.
  • 975 Answers
Get some Q tip & alcohol and clean the golden dots on the back of the cartridge and install it again , it should work
Posted on Aug 14, 2008
Printer is not printing the black colour when i load the paper from the rear slot...
Hi
try printing a "Nozzle check" to confirm that both your black cartridges are working ok. One cartridge - the smaller (photo) one is used for printing photos on glossy paper. The second - bigger cartridge is used on plain (copy) paper. Sounds to me like your smaller (photo) black cartridge is not working. It's either empty or may need "Cleaning" or "Deep cleaning". In case you don't know...Nozzle check, Cleaning etc utilities can be found on "Maintenance" page in "Printer properties".
good luck
Lumir
www.inkbank.com.au
Mar 07, 2014 | Canon PIXMA MG5320 All-in-One Printer
New ink cartridges not printing
The ink cartridges that you replaced are brand new or refilled ?
Thanks
Proton
Sep 07, 2008 | Brother MFC-5840CN All-In-One InkJet...
I was given an HP Officejet J3640. I installed the HP21/22 ink cartridges, printed the alignment page, then loaded the alignment sheet in the feeder. After I loaded the alignment sheet, it responds...
Hi
Check if the alignment page has been printed correctly i mean the bars printed with a little yellow color around it right?
Okay what you can do is do a reset first. Follow the below things
1. When the printer is on remove the power directly from the back of the printer.
2. hold # and 9 key and connect the power
3. Printer will show you on the screen it is resetting the NVRAM then release the buttons
The printer will print alignment page again this time try to scan and it should work.
DO RATE MY SOLUTION
Jun 30, 2011 | Office Equipment & Supplies
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
HP colour cartridge no. 22 won't print
if the test pages come out OK then the problem can not be the printer !!!!!!!
it must be from the application
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Won't print
Try the following steps:
Check for and remove any grayscale settings. Use the following steps to check this setting.
  1. In the program, click File and then click Print . The Print dialog box opens.
  2. Select the correct product and then click Properties . The Properties dialog box opens.
  3. Click the Color tab.
  4. Check the Print in Grayscale setting. If necessary, unselect the setting.
  5. Click OK to save the settings.
If this doesnot work:
    1. Open the Printer Toolbox .
    2. Open HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
    Now Click the Estimated Ink Levels tab. This will tell u that the cartridge might be running out of ink even if the graphic shows that there is ink remaining in the cartridge.Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • If this doesnot work:
  • If the Print in grayscale option is not the problem and the print cartridges are not low on ink, print and evaluate a self-test page to determine if the cartridges or printer is causing the problem.
    1. Load the input tray with unused plain white paper.
    2. Press and hold the Cancel button and then press the Start Copy Color button.
    3. Release both buttons. The self-test page prints.
    This will definitely work for u.
    Thank u.
    May 27, 2008 | HP DeskJet F380 All-In-One Printer
    Replaced empt 3E cartridge. Now it won't print
    I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
    Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
    HP PSC all-in-one printer skipping lines
    1. Press the Setup button.
    2. Use the arrow keys to select Tools and then press the OK button.
    3. Select Clean Print Cartridge and then press OK . The device prints a test page.
    4. Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.
    5. Open the Printer Toolbox . There are two ways to do this:
      • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
      • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
    6. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
    If the steps have not solved the problem, clean the electrical contacts on the print cartridge and in the carriage.
    1. Gather the following items to clean the cartridge and print carriage:
      • Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
      • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
      • Sheets of paper or a paper towel to rest the cartridges on during cleaning.
    2. Open the product cover and wait until the print carriage stops moving.
    3. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up. NOTE: Clean the contacts quickly so that the cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
    4. Unplug the product.
    5. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp.
    6. Clean the print-cartridge contacts. Do not touch the nozzles. Figure 1: Cartridge electrical contacts c00832021.gif
    7. Clean the contacts in the print carriage, inside the product. Figure 2: Carriage contacts c00246272.gif
    8. Either let the cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
    9. Reinstall the cartridge, plug the product back in, and close the product cover.
    10. Try to print again. If the issue still appears, continue to the next step.
    In the black print cartridge, this problem might be caused by sediments collecting in the nozzle area. Perform the following steps to solve this problem:
    1. Remove the black print cartridge.
    2. If the carriage has a latch, re-latch it and then close the printer. NOTE: If the printer is not closed, it cannot adequately protect the remaining tri-color cartridge.
    3. Place the cartridge on a level surface with the nozzles up (label down). Figure 4: Cartridge with the nozzles up c00260331.gif
    4. Allow the cartridge to sit undisturbed for two hours.
    5. Reinstall the cartridge and print another diagnostic page.
      1. Load letter or A4 unused plain white paper into the input tray.
      3. Make sure that the test patterns show a complete grid and the thick color lines are complete.
      • More than a few broken lines in a pattern can indicate a problem with the nozzles. You might need to clean the print cartridges.
      • If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black print cartridge in the right slot.
      • If any of the color lines are missing, or if the pattern appears faded, streaked, or shows lines, this might indicate a problem with the tri-color print cartridge in the left slot.
    6. Look for defects on the page. If the diagnostic page shows no defects for the black cartridge, and if the cartridge was new, align the cartridge. To align the cartridge, follow the steps:
      1. Load letter, A4, or legal unused plain white paper into the input tray.
      2. In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Toolbox . NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device . The Printer Toolbox appears.
      3. Click the Device Services tab.
      4. Click Align the Print Cartridges and a print cartridge alignment sheet is printed.
      5. Load the print cartridge alignment sheet with the print side down on the right front corner of the glass.
      6. Press the Start Scan/Reprints button and the HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet. For aligning the cartridges from the hardware only, follow the steps:
      7. Load letter or A4 unused plain white paper into the input tray.
      8. Press and hold the Cancel button and then the On/Power button.
      9. While the Check Paper and Check Print Cartridge lights are blinking, press the following buttons one at a time in the following order: Cancel , Number of Copies , Paper Type , Color Start
    Nov 27, 2007 | HP PSC 2355 All-In-One InkJet Printer
    My Hp 6210 is skipping lines and moving the paper down
    note :--do not use refilled cartridges Step 1: Did you just install a new tri-color or photo cartridge? If all three of the following are true, the problem can probably be solved just by letting the printer sit for 30 minutes: You just installed a photo or tri-color print cartridge (the cartridge can be either new or previously-used) The problem appeared right after you installed the cartridge The recently-installed cartridge is the one that is printing the defective patterns on the diagnostic page Sometimes when a tri-color or photo print cartridge is snapped into the print carriage, it ingests a small amount of air, which can prevent some nozzles from working properly. The air soon works its way out of the cartridge. Step 2: Run the clean print cartridges utility If the step above did not solve the problem, clean the print cartridges. Press the Setup button. Use the arrow keys to select Tools and then press the OK button. Select Clean Print Cartridge and then press OK . The device prints a test page. Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning. Open the Printer Toolbox . There are two ways to do this: Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox . If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints. Step 3: Clean the contacts If the steps have not solved the problem, clean the electrical contacts on the print cartridge and in the carriage in the printer. Gather the following items to clean the cartridge and print carriage: Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap-water can contain contaminants that damage the cartridge. Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well) Sheets of paper or a paper towel to rest the cartridges on during cleaning Open the printer cover and wait until the print carriage stops moving. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up. NOTE: Clean the contacts quickly so that the cartridge is not outside of the printer for more than 30 minutes. If the cartridge is outside of the printer for too long, the ink can dry and clog the nozzles. Unplug the printer. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp. Clean the print-cartridge contacts. Do not touch the nozzles. Clean the contacts in the print carriage, inside the printer. Either let the cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it. Reinstall the cartridge, plug the printer back in, and close the printer cover. Try to print again. If the issue still appears, proceed to the next step. Step 4: Black cartridges only: remove and rest for two hours NOTE: The following procedure does not fix missing lines or streaked bars printed by the tri-color, photo, or gray photo cartridges, or other color-printing problems. Perform the following steps only if the black print cartridge has printed defective patterns or if you notice non-uniform black text-darkness. In the black print cartridge, this problem might be caused by sediments collecting in the nozzle area. Perform the following steps to solve this problem: Remove the black print cartridge. If the carriage has a latch, re-latch it and then close the printer. NOTE: If the printer is not closed, it cannot adequately protect the remaining tri-color cartridge. Place the cartridge on a level surface with the nozzles up (label down). Allow the cartridge to sit undisturbed for two hours. Reinstall the cartridge and print another diagnostic page. Load letter or A4 unused plain white paper into the input tray. Press and hold the Cancel button and then press the Start Copy Color button. Make sure that the test patterns show a complete grid and the thick color lines are complete. More than a few broken lines in a pattern can indicate a problem with the nozzles. You might need to clean the print cartridges. If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black print cartridge in the right slot. If any of the color lines are missing, or if the pattern appears faded, streaked, or shows lines, this might indicate a problem with the tri-color print cartridge in the left slot. Look for defects on the page. If the diagnostic page shows no defects for the black cartridge, and if the cartridge was new, align the cartridge. To align the cartridge, follow the steps: Load letter, A4, or legal unused plain white paper into the input tray. In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Toolbox . NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device . The Printer Toolbox appears. Click the Device Services tab. Click Align the Print Cartridges and a print cartridge alignment sheet is printed. Load the print cartridge alignment sheet with the print side down on the right front corner of the glass. Press the Start Scan/Reprints button and the HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet. For aligning the cartridges from the hardware only, follow the steps: Load letter or A4 unused plain white paper into the input tray. Press and hold the Cancel button and then the On/Power button. While the Check Paper and Check Print Cartridge lights are blinking, press the following buttons one at a time in the following order: Cancel , Number of Copies , Paper Type , Color Start If the page still shows defects, go to the next step. Step 5: Replace the problem cartridge If the problem has not been solved by the steps above, either the printer or the problem cartridge is defective. If you have not tried cartridge replacement previously to solve this problem, replace the problem cartridge now. Click here to see if your cartridge is covered under warranty (c00059195). If you have already tried cartridge replacement and it did not help, service the printer. Preventing missing lines Missing lines occur when the cartridge nozzles dry out, or when a cartridge is running low on ink. Do not remove the protective tape from a new print cartridge until just before you install it. Once you remove the tape, do not reapply it. After you have removed the protective tape, do not allow anything to touch the nozzles. Print at least once a month to keep the print cartridges in good working order. Always turn the printer off by pressing the button on the printer control panel, rather than by unplugging the printer. Turning the printer off properly allows it to protect the cartridges. If you are removing a cartridge from the printer temporarily (for instance, removing the black cartridge in order to install the photo cartridge), put it in a cartridge protector. If you do not have a cartridge protector and need to remove a cartridge temporarily, put it in an airtight plastic tub. Make sure nothing touches the nozzles. Do not use a plastic bag. If you intend to store print cartridges in a tub for a long period of time, place color cartridges with the nozzles down, and black cartridges with the nozzles up.
    Sep 07, 2007 | HP OfficeJet 6210 All-In-One InkJet...
    HP PSC 950 All-In-One InkJet Printer Logo
    55 people viewed this question
    Ben Johnson
