Phillips crt tv 3 yrs old
Unit will not turn picture on w/out cycling the power switch on/off many times
  • madmudder1 Aug 15, 2008
    Thank you. I HAVE SEEN OVER HALF A MILLION HITS for phillips problems. Sounds like a class action suit to me,.
    Sergeant:
    Champion:
  • 258 Answers
Your Hi voltage circuit is likely going into protection mode. getting it past this may be a fire hazard. Take it in... or "out" if you get my drift.
Posted on Aug 14, 2008
HAVE PHILLIPS 60 INCH 5 YRS OLD GREAT PICTURE NO
Hi, check for any speaker switches around rear of set that may have been accidentally switched. Could potentially have a "hotel lock mode"
which some philips sets automatically entered after a set time (namely months) which limited volume settings. Your friendly local service technician may be able to help you out with that one
Mar 19, 2010 | Philips 60P8341 60" Rear Projection...
I can't turn my TV, have to power 15 or times for it to come one and it is also cutting out the sound intermittently for 2-3 seconds once the TV is on - it's approximately 8 yrs old, should it be replaced...
check your power switch it appears that your contacts in side your switch are fused with arcs, and are not making good contacts.
change that switch with a new one. a switch has four contacts switches in it, use a volt meter to check the 115 or 240 AC through the switch.
before changing that switch you have to check for dry joints on your power suppy section of your tv.
thanks.
Feb 27, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Watching tv when the picture went black and now the green on light flashes for 30 times and turns off
A green flashing light for this model of TV indicates that the lamp cover is open on the TV.
  1. Unplug the power cable to the TV.
  2. Remove the 2 retaining screws on the lamp cover with a Phillips type screwdriver.
  3. Remove the lamp door completely from the TV.
  4. Remove the two retaining screws on the lamp case.
  5. Lift up the fixed wire handle of the lamp.
  6. Pull out the handle slowly and remove the lamp case.
  7. Insert the new lamp gently into the correct position. Make sure it is inserted correctly.
  8. Using a manual Phillips screwdriver (Do Not use an electric screwdiver), tighten the screws you removed in
    step 3.
  9. Replace the lamp cover and tighten the cover screws.
  10. Plug in the power cord and turn on the TV. After the initial warmup period (which may take up to several
    seconds for full picture brightness), the TV should operate normally.
If any of the following conditions exist, turn off the TV, unplug the power cord, and repeat steps 1–9 to ensure that the lamp unit and lamp unit
door are installed correctly:
  • The lamp indicator flashes green.
  • No picture
  • Dark picture
  • TV will not turn on
If, after repeating steps 1–10, the problem still exists, call Customer Service at 1-800-631-3811.
Source
Aug 31, 2009 | Toshiba 44NHM84 44" TV
The t.v.just went blank while watching it.
Power boards are like time bombs. When it's time is up, it's up. Since it is 3 yrs old, I would buy a new tv. Most TV parts only last 3-5 years anyways. It did a good job.
Nov 14, 2008 | Televison & Video
Phillips 52" tv
It might be simply a matter of having someone adjust the magnetic rings on the yoke of your picture tube to refocus it - a lost art.
A 15 minute job for a seasoned veteran, perhaps, but expect to pay a minimum charge of 1 hour's labour, at $85-90 CDN.
Sep 18, 2008 | Philips Magnavox 27MS343S 27" TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Hey i got a tv set not 3 yrs old ???
Please give accurate info==need model and chassis # from
back of set-then I can suggest a solution.T.
Oct 09, 2007 | RCA 32F531T 32" TV
Matsui television
1 it might be due to loose contact in plug or socket. 2 there might problem in power supply section in your tv.
Sep 17, 2007 | Televison & Video
My 42 inch plasma wont turn back on after power cut?
We purchased a phillips plasma 50" in july 06 and it cut on and off 5 or more times a day I called phillips customer service they told us it was due to the cable company they came out and changed the tv jack gave us a new box and tested the lines said everything was ok. The problem still kept happening got back to phillips and they sent us a flash drive to update the info in the tv. still kept happening told us it was due to tv being sensitive to power flutuations. well we are now 5mths out of warrenty and the power board blows up! phillips will not do anything to help the person I spoke with admitted we were given bad advice the bill was estimated at over $500 so if I were you if its still under warrenty make them send someone out to look at it, Reading up on phillips tv complaints this seems to be a common thing By the way phillips customer service sucks dont rely on them to help you much. good luck
Jul 02, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
