Unfortunately this unit does not have any security or write protection feature. If you received a write protection message on the drive, do check for the following:-
Verify that you are allowed to write to removable storage devices. There may be a security setting in the OS that disables write access to removable storage devices.
Be sure you have not enabled any write protection on the drive by using a third party software.
If none of the above apply, the drive may be defective. Contact Kingston Technical Support for further assistance or claim warranty for replacement.
Other Options you can try
Use this Tools to repair from Link below
1.http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip
2.Download Smart Virus Remover @ http://www.softpedia.com/get/Antivirus/Smart-Virus-Remover.shtml
***(Use at your own risk on my recommend)
Hope it helps.
Step 1:- format to use 2003 server, **** management
step 2:- download hpformat utility
to use this utility format your pendrive
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
