Question about Maytag Legacy Series Top Load Washer
The grinding (bearing) noise on "spin", now leaking rusty water under machine... 3 1/2 years old "Legacy" ??? NOT !
I read the McGyver reply, I have the same problem. RepairClinic.com has a bearing/seal kit for $50.35, is this what is needed ? Do you have the parts also ? I would need the same info you were going to send to McGyver.
My grandmother swore by Maytag, I swear AT Maytag ! Any information or suggestions would be deeply appreciated. Both the washer and dryer ar no more than 3 1/2 yeras old, I thought a "LEGACY" lasted forever ?!?!?!?
S/N134694ER, MOD SAV405DEWW
The washer AND dryer have been NONSTOP problems. The dryer squeeked continuously till I worked on the idler and ALL of the brake pads and retaining bolts fell off of the washer a year ago !
I can rebuild engines, dryers, furnaces, and in general fix just about anything. Question is, can I do THIS ?
One thing is for sure, I'll NEVER buy any Maytag product again.
Thank you very much,
Dave Rodkey
Southewest, Pa
  • Anonymous Oct 14, 2008
    agitator slipping and grinding noise... This washing machine was purchased in 2005.
  • vterm Mar 01, 2009
    My dryer is about 4 ;years or less. It know makes a thumping noise when drying and tonight it wouldn't spin and made a buzzing noise. My neighbor swore by Maytag. That's why I purchased a Maytag. It SUCKS. My Washer is a Whirpool. It's so much better.....
  • 91 Answers
Maytag has rear rollers and front drum glides when goes out sound like sand paper scratching, also inspect belt idler same noise
Posted on Jan 04, 2009
I have water leaking on maytag legacy. 9 years old. getting worse over 3 months. removed front and rear panels, dried out and looked for leaks. only water was on agitator base. im thinking tub bearings and...
Look for splatter signs along all of the inter panels, including the ones removed, splatter marks will be just below the line of the tub. Pleazer Appliance...
Apr 14, 2014 | Maytag Legacy Top Load Washer
Apart from the cover at the base. How do I access the internals of the machine. I have a loud noise on spin plus I seem to have a water leak inside
The front panel comes off. 1st you need to remove the Facia to access the 3 screws...Leak could be door boot seal noise sounds like drum bearings/ if its under 5 years old phone Hotpoint it will cost around £100 for call, parts are free.....If over 5 yaers think new machine as its quite expensive to do full job and not always worth it if old........
Dec 03, 2010 | Hotpoint Aquarius WF215 Front Load Washer
Water has been leaking out of the bottom of my washer, and it has been making a horrible grinding sound. It finally stopped spinning last night, though it makes noises and tries to run.
Hi just read your posting.Now when is the machine noisy?Is it when the machine pumps out the water or when the bowl spins.Sorry to ask you this but please be accurate when you reply to this question.The reason being is that if it is noisy when it pumps the water it could be your pump but if it is noisy when the bowl turns for the spin then the problem will be your bearings and seals.Select a spin cycle and push start,is it noisy as soon as you push the start button?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Sep 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
The washing machine started making a grinding noise during wash cycle (minor) and a much louder grinding noise during the spin cycle. Is this a bearing? and is it replacable? Maytag MAV7600
sounds like a bearing... although it could be the water pump... water pump is an easy fix... bearing is not an easy fix... take the belt off the bottom of the pump (under the machine) and see if it spins freely by turning it w/ your hand... or if it seems really stiff... if it looks good then it's def. your bearing...
Jan 15, 2010 | Maytag MAV7600 Top Load Washer
White flakes in circular pattern under washer of 7 years. Time to replace?
First we started hearing a grinding sound during the spin cycle. My husband replaced the belt, which was loose and not helping the spinning of the tub any, thus much wetter clothing after spin cycle. The belt gave us another week of use out of the machine and did drain the tub better, but then water started leaking into the tub from the water inlet (or area where water rushes in to fill tub), and was not up to the usual "rush" of water, when filling up. The grinding sound started again during the spin cycle, and so now we are assuming it is the ball bearings or the brakes and perhaps the water pump as well. Estimates for these jobs on the boards seems to run from $400-500.00. The machine is only 7 years old, but after reading so many posts, maybe I should count my blessings that it lasted that long! This was an all mechanical machine, which I loved. Atlantis Maytag, a very sturdy and solid looking machine. Never did really clean that well though. SOLUTION: we are getting a new machine.
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Legacy washer MAV408DAWW loud noise, dumped all water
Tub bearings and seal have failed. My SAV405DAWW just started with the loud grinding and I am now in the process of finding out if I can fix it myself. Kurt
Jan 12, 2009 | Maytag Legacy Top Load Washer
Maytag washer noise in spin cycle
Hi Lis,
I hate to be the bearer of bad news for you but your maytag washer will not have a motor to transmision coupling. That is only on whirlpool brand and some kenmore brands that are made by whirlpool. Your maytag will have a belt and if it is making a loud sound while spinning your bearing has most likely gotten wet and rusted. That is caused by having a leak in the tub seal and the water getting onto the bearing. This is a major repair and I really do not recommend the average handyman try to do this job. But if McGyver wants to try I will be happy to send along any information about parts and instructions. Just send me the model number and I will let you know what you will need. I really hope this will help and again, sorry for the bad news. Lots of luck.
Michael Anderson
Jul 20, 2008 | Maytag Legacy Series Top Load Washer
VERY LOUD GRINDING NOISE LG WM-2277HW Front Load Washer
Get a new washer. Perhaps another brand.
The fix for me was to get a new washer. Had same issue with loud spin cycle. Tried researching while wife was continuing use of washer. Then the LE message appeared.
Took back apart and found that water had leaked and caused a boat load of damage. Bearings shot, seal leaks, drum leaks, Stator damaged. Same issue as 'jammy64' stated.
Cost to repair wasn't worth it. Going to get an
Electrolux model.
May 19, 2008 | LG WM-2277HW Front Load Washer
Admiral Washer Model#LNC6762B71
if water leaks in the tub your water valve need to replace. and thelower bearing. i can let you know how much the parts are.and valve is not hard to replace but bearing is
Feb 18, 2008 | Kenmore 23822 Top Load Washer
I think I also have a Main Seal problem
We too had this problem. Called out the appliance repair man....He took away our machine. Had to fix the Seal, Bearing, and belt. Brought it back after having it a few days and Now SMELLS like rubber burning. After spending almost 300 dollars my husband had to get under it and found a spring stretched to the hilt. We are replacing the spring and we hope no more fire stinky rubbery smell. BUT it doesn't leak nor does it sound like a plane taking off anymore. IF I could do it again??? I would have bought a new washer without all the frills just because I have done some looking and see that this is a "normal" problem for this washer. AND it may happen AGAIN. Wish us luck but that is what we had done. As far as the appliance repair man?? THEY do not know what is wrong with it and why it "STINKS". Should have just had the hubby fix it.
Oct 20, 2007 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
452 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
