Computers & Internet Logo
Posted on May 16, 2011
What is DSL ID in airtel and what is its password? Is dsl id our modem no.?
Anonymous
Level 1:
New Friend:
  • Contributor 29 Answers
  • Posted on May 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
29
Questions
0
Helped
9499
Points
67
GO to your web browser type 198.162.1.1
each dsl modem has pass and username as default
TP-LINK username:admin password:admin
How can i put a password on my linksys befw11s4?
Turn over router and check in the bottom default access IP address and then type that IP address in to your browser. Then it shall ask you for ID and password. Enter `Admin` or `admin` as ID and `Password` or `password` as password. You will see a web based setup opened in front of you. Go to the Wireless Lan settings and then you will SSID so change the SSID and this would be your network`s name. Then go to subsection security and select WPA2-PSK or simple WPA-PSK then enter your desired network key. Once done with all these things the click apply and reboot if prompted.
What is uder id & password
If we a re talking about a DSL modem then it would be the username and password your modem uses to connect to your ISP, which allows you to access the internet
I want description on how to connect twp linksys wrt54gr routers to the same DSL modem ?
Hi
I understood that , you need to connect router with DSL modem .
1- connect router with pc by cable
2- change your IP address to be DHCP,
3- open internet explorer and type the default IP for the router , usually be 192.168.1.1
4 -it ask you about used ID and Password insert the default one usually be : admin and password : admin or password
5-choose from left menu wlan, and insert your user name and password ,chose the type of connection ppeo broadband .
to this step it must work correctly if you click connect
Hey... i forgot my dsl id on airtel
Plz reset my HLR id my id is A1327561
Vtech model 2656 caller id is not working. How can I fix this?
Found this on the VTECH support site regarding your model:
Tip 1 of 1
Caller ID and Call Waiting ID are subscription services, available from most local telephone service providers. You must subscribe to these services in order for the features to work on your phone. Contact your local telephone service provider for more information.
In addition, your caller must be calling from an area that supports caller ID.
Both you and your caller’s telephone service provider must use compatible caller ID systems.
If you subscribe to DSL service for this telephone line, DSL filters must be plugged into EVERY phone jack that has a phone. The DSL signal can cause caller ID disruption, static, noise and other issues on your line. DSL filters block the high frequency DSL signals from being transmitted to the telephone. If you are not using the DSL filters provided by the telephone company, this will cause static/noise and possibly caller id issues on your phones.
In most cases, we recommend you connect the plug end of the DSL filter into the telephone jack, then connect a telephone cord between the filter and your phone.
Please contact your service provider to obtain DSL filters and installation information.
Caller ID and Call Waiting ID may not be available for every call. Common reasons are incompatibilities between your and your caller’s service, transmission errors and answering calls before the ID data is received.
In addition if you would like to contact them or get more info on your phone, then use this link:
http://www.vtechphones.com/vtechui/support/faq_index.cfm
MMX 610U Airtel USB does not support Windows Vista
I have Windows Vista. my Airtel MMX 610 U USB modem does not identify SIM and does not work. Also it is well working with Windows other versions like server, or 2000.
please provide me solution or patch for Windows Vista
thanks
Vinod
I am trying to set up zoom x6 modem/router to my computer and i cant find the vci/vpi and i dont know the the encapsulation for my isp. anyone know where i can find this?
Sir,
U can login ur ISP u can find. go to browser type your IP address for ex. http://192.152.185.1 and press enter. it ask user and password. u can login ur user id and password of your internet provider. u can find there. default user id and password is admin and admin
Thanks Good Luck
Appreciate to rate as "Fixya"
Current modem working fine with ATT DSL. I want to install a second modem (2wire) by direct connection to same DSL phone connection (in different room). I have hooked up other modem, filled in user ID and...
Is that second location also a DSL line? You may have to consult with AT&T to see if the DSL line runs to that second location.
What are you trying to accomplish? By adding a second modem, you essentially create two separate networks. Why not use a switch and connect it to the first modem, which would allow you to connect more PCs.
2answers
Cant connect to internet using linksys with att dsl modem
Your router was configured for Cable Modem which is usually DHCP
Now you need to change it for DSL modem. This means you have to change WAN setting from DHCP to PPPoE and enter your Username and Password for DSL service (should have been provided by your ISP)
Some DSL modems that are also routers need to be accessed directly first and have their configuration changed to "passthrough". This means that DSL modem should not be handeling PPPoE login but rather should let your router do the login.
Thnks
Hello!
don't worry, we will figure it out.. i'm pretty sure that you surely did the right thing. its probably the modem itself that is not cooperating here. if you dont see any dsl light on the modem that is because the modem is not yet setup.
nwy, since you already try setting it up using the installation cd, let's try to do check it manually instead
check your cable connection:
step 1: Power supply connected
Step 2: Phone cable to the DSL port of the modem to the DSL outlet
Step 3: Ethernet cable from the ethernet port of the modem to your pc
device configuration:
Step 1:open browser and type 192.168.1.254
Step 2: create your own password
Step 3: username admin and the password you created
Step 4: type your ISP user ID and password
Step 5: it should give your the confirmation that you are now connected
Grand Canyon Tech
Grand Canyon Tech
