Question about Music
Peavey cirrus pickups
Changing output jack on front routed bass. when ready for reassy, noticed two wires broken. they run from the wide plug, #3 and #5 from red side to ???. help?
    Novelist:
  • 157 Answers
VIsit Peavey's website at http://www.peavey.com contact their customer support and you can order a wiring diagram on how these pickups should be wired. I've always been able to get any diagram I've needed for any of their products, some times you have to pay for them but sometimes they can be downloaded for free.
Posted on Aug 28, 2009
6ya staff
SOURCE:
I plugged in ibanez sdgr 5 string bass into a peavey 300 monitor and now the guitar wont work.. can somebody tell me what happened and how to fix it?
I'm pretty sure that model has active - battery powered - pickups, and yours is flat, so no output at all. The battery would be under the smaller cover plate on the back
http://resources.ibanez.com/resourceservicehost/images/Ibanez/web/insets/zoom/SR300SLB_Battery_Box.jpg
Jul 11, 2016 | Peavey Music
Peavey serial number lookup
Contact Peavey toll free at 877-732-8391 or by email at [email protected],
Aug 09, 2014 | Peavey Electronics Peavey Cirrus 5 BXP 5...
Peavey schematic diagrams
Peavey Customer Support toll free at 877-732-8391 will be glad to send it to you.
Aug 08, 2014 | Peavey Electronics Peavey Cirrus 5 BXP 5...
Serial numbers peavey
Unfortunately "BXP" indicates that it is an import. There is no
way, (that I know of), to correlate the serial number with the year shipped like american made models are done. i will try to research it for you further. Let you know if i find anything
Jul 24, 2014 | Peavey Electronics Peavey Cirrus 5 BXP 5...
How do I replace cord jack on a Peavey bass guitar?
You'll need needle nose pliers, small phillips head screwdriver, soldering iron, electronics-grade solder, socket screwdriver or 1/4" wrench, black electrical tape. Purchase necessary replacement jack. Remove plastic electronics cover plate, located on the back of the body, behind control knobs. This will expose the electronics cavity. Locate existing jack and its wire connections inside the exposed cavity. Remove any electrical tape covering the jack connections. Using a hot soldering iron, touch each of the two soldered input jack connections, one at a time, just until the soldered connection melts. Then, disconnect the associated wires (taking note of which wire connects where!). Once disconnected, loosen and remove the nut on the outer part of the jack that holds it onto the guitar body. Remove the old jack. Insert the new jack (with the nut removed) into the existing hole, from inside the electronics cavity and tighten it in place, on the outside of the guitar body, with the nut. Re-attach the wires to the new jack, by using needle nose pliers to wrap them tightly around the correct posts. Touch the hot soldering iron to each post and apply a small amount of solder to the post as it's being heated. Once the molten solder runs over the connection and looks shiny, remove the tip of the soldering gun. This process takes only 2 to 3 seconds. Let the connections cool for a few seconds. To insulate, wrap connections with black electrical tape. Replace cover plate.
Apr 27, 2014 | Peavey Music
Peavey Fury 4 Quilted Bass guitar serial number 01050957
This is from the Peavey website. It indicates a date between 2001-2003. I found a date from another source indicating 2003. They Fury IV is a nice instrument!
"Offset double cutaway solid body, 21-frets, Quilted Maple top, solid maple neck with rosewood fingerboard, two VFL internally-active pickups, 3-band active EQ, single master volume, mid, bass, and treble controls, satin chrome hardware, available in Trans. Red, Trans. Blue, Trans. Green, or Sunburst finish, 34 in. scale, mfg. 2001-2003"
There is further info available from Peavey: http://www.bluebookofguitarvalues.com/Electric_Guitar_Values/Manufacturers/PEAVEY/Categories/ELECTRIC_BASS__FURY_SERIES/Models/FURY_4_QUILT_TOP?id=PEAVEY_ELECTRIC_BASS_FURY_SERIES_FURY_4_QUILT_TOP
Apr 10, 2014 | Peavey Music
I'm looking for a wiring diagram to replace a jack socket for a peavey void 4 bass
If it is the socket on the bass, it should only be 2 wires, on the 2 ears of the socket. He must have soldered it to the wrong place. The wire from the pickup switch(if more than 1) or the volume(if only 1) should go to the part of the socket that touches the tip on the guitar cord when plugged in. The other is ground and connects to the backs of controls and switches throughout the instrument, even to the bridge and tailpiece.
Mar 04, 2013 | Peavey Music
My double pick up Dean edge quit working while playing. I checked the wiring and all looks good, but three is s a black wire coming from hole to center of body attached to nothing. Looks like it never was....
Make sure you have two wires soldered to the output jack on the bass. having a wire lose is not purposely put like that, for no sound from the bass then that wire is either from the pickups and connects to the pots on the bass or on the output jack. I would suggest taking it to an authorized dean dealer to inspect the wiring.
Jul 13, 2011 | Dean Edge 4 Bass Guitar
I have a Peavey MAX 112 Bass Combo amp. When I turn on the amp and have it plugged into the cord and bass, it immediately begins emitting a "whump whump" sound similar to the sound a beating...
The amp is doing what is called "motorboating". This is usually caused when the voltages to sensitive preamp stages are inadequately filtered or regulated and the sudden load of the output stages cause a dip in the voltages sent to the preamps which in turn vary the input to the output stages starting the cycle over. This will require electronic troubleshooting and if your not skilled in that, then it is NOT a DIY fix. What you are seeing is NOT normal, there is a defect.
Apr 22, 2011 | Peavey Electronics Peavey Max 112 Bass...
Changing the output Jack on 1985 Peavey Dyna Bass
If this has active circuitry, one of the wires is the cutoff for the power supply from the battery. The other two are black for ground and either white or red for signal.
Mar 13, 2009 | Peavey Music
Music Logo
434 people viewed this question
Top Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
