Question about HP Photosmart C3180 All-In-One InkJet Printer
Flashing lights from everthing
Unit after on few seconds all lights flash on left side. Nothing seems to work at that point. No Paper jam, Ink seems to be full, What is it that I can do to find out what is wrong.
  • 2 more comments
  • jstevent Aug 22, 2008
    Paper advances half way through printer - no printing,
  • Anonymous Aug 30, 2008
    replaced cartridges because they were out, now the lights flash, the cartridges just go back and forth, make noise and seem to be losing ink also. I tried to take them out, put back in, run a test print, paper goes through but nothing prints, still goes back and forth and kind of does a little bang against the side and just stops. ink seems to be coming out tho.
  • Anonymous Nov 23, 2008
    seems like its u/s mines doing the same
  • phryne Nov 26, 2008
    same here! those light just keep flashing and when i try to troubleshoot system says that there is nothing wrong, but it just does not work. so frustrating.
Mine is doing the same thing, solution, buy a new printer. No resolution!
Posted on Sep 16, 2008
Epson stylus photo px660 with a paper jam error after dismantling it displays a printer error with all lights flashing
Paper jam problems can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation. I have observed that most people fan the paper pile to keep them dry or non-sticky. It's a wrong method because fanning the pile of papers make them go haywire and often lead to paper jam.
The flashing lights are a "Maintenance request error" or a "Fatal error". Most of the time it is a "Maintenance request error" which means the waste ink pads need to be serviced. You can reset the waste ink counter but the ink pads will need to be serviced at some point.
you can try following points.......
1.turn off the machine for at least 5 minutes and disconnect the interface cable to the computer.
2. push and hold down the "ink" button and the "paper" button and turn the printer on.
3. When the "paper" light flashes quickly release both the buttons and then immediately press and hold down the "ink" button only for at least 10 seconds.
**You will need to try this several times to get the sequence correctly.
If you need any kind of technical assistance, you can contact support cell at http://vtechsquad.com/printer-support/
Sep 11, 2012 | Epson Office Equipment & Supplies
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Light kee flashing orange/green and says computer is busy when there is nothing in print queue
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 29, 2010 | Canon BubbleJet i320 Printer
Both paper feed and power lights flash after printing several pag
lean head-eject ink ruler & clean point of contact betwin cartridges and head-ink unit.
Aug 07, 2009 | HP DeskJet 970cxi InkJet Printer
The light is blinking on my maching (i believe it's the ink--or lack of it). i'd like to find out if that is so, but i can't seem to find the route to that on my machine, which is a mac. How do i get that...
I can't tell you how you could find out on you Mac as I've never used one with my C86 but I can tell you that you can translate the light flashing into a more meaningful "message" by observing the patterns.
  • Paper & Ink lights flashing alternately (power light off) = service required (ie: waste pads need replacing)
  • Ink light flashing = ink cartridge is empty or printhead is in the exchange position. Try pressing the ink button once (don't hold it down) and see if it moves to the exchange position or moves back to park.
  • paper light flashing = paper jam or no paper in feed.. Remove a jam or feed it with paper as required then press the paper button
  • Power light flashing = printer is busy... If it's doing nothing trying pulling the power lead out of the back of the printer, wait 5 seconds and then plug it back in, turn it back on. This should clear any error.
  • Both ink and paper lights flashing (together) = General error.. This could be anything from a serious paper jam, loose wire in the printer, parking station disconnect or similar..
Hopefully that will give you something to go on and get you working again... As far as software information goes, someone else may be able to help but chances are Epson's own support site will have some software called Status monitor or similar for your operating system which may help.
Cheers
Martin
Aug 05, 2009 | Epson Stylus C86 InkJet Printer
Canon was working fine, suddenly got an alarm flashing light, nothing works, no copy no print error 6a00, have taken sides off a tried to clean the ink dump on the rt side. still no help
Hi
It goto be this error
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MP830 6A00 error & ON/OFF switch not working
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Jun 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MY COPIER KEEP FLASHING A LIGHT OF PAPER YAM BUT THERE IS NOT ONE I THOUGHT IT WAS OUT OF INK SO I GOT A NEW BUT IT'S STILL FLASHING LIGHT
the copier have a paper jam on the left side on fixing unit or on right side .
or the copier have a paper sensor that does not move.
Dec 27, 2008 | Canon PC-940 Black and White Copier
Error 6A00
Solution 1:
Solution 2:
Solution 3:
May 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Both Ink & Paper lights flashing!
Hi JayBirde Do the lights flash Together (not alternate) and is it a quick flash (0.1 second on 0.1 second off)? If so, check the Status Monitor for a message. If it says Fatal Error or General Error, then you have a task on your hands! If the lights flash alternate (0.5 second on 0.5 second off) then this indicates a maintenence error and the status monitor should say parts inside your printer have reached the end of their life - or something similar. This much easier to fix with an R220 Rescue Kit from www.TheServiceManualShop.com - use their search to look for R220 Rescue. If you can't find it, just drop them a line and they will create one for you. Delivery is via instant download so no waiting around to get your machine fixed. If you have a general or Fatal error it means the printers head can not move using the norm,al amount of force - i.e. something is in the way. You can check a few things: Ensure their is nothing in the path of the print head - paper, foam from the pad, head lock not retracting, toy soldier on manouvers in the mechanism etc Chech the encoder strip ( a grey-ish looking plastic strip, near the drive belt for the print head) is clean and attached. Check the lid for the ink cart cover is full closed.
Oct 28, 2006 | Epson Stylus Photo R220 InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
100 people viewed this question
Ben Johnson
