Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Can't print over network
You suggested that I use pcl6 drivers, but I can't find pcl6 drivers for Mac OSX.
I have remote UI enabled but am also unable to get to the UI with any browser.
  • PESysMan Sep 03, 2008
    I am able to ping the printer.
    In the meantime, however, I have learned that the printer does not have a printer board. Apparently that's optional equipment. I don't understand why there is an ethernet port, the printer has an IP address, and the remote UI works just fine; but printing over ethernet apparently requires additional hardware.
    Sure took a long time to figure this one out!!
    Sniper:
  • 89 Answers
Printing over ethernet does not require additional hardware. Whoever told you that is wrong. You just need the Network Card and N Boot Rom which is presumably already installed in your system and to upgrade firmware to N version. PS/PCL drivers have probably not been installed on your copier.
In Service Mode (Additional Functions > 2, 8 > Additional Functions), Copier > Display > Version > PS/PCL is almost certainly blank whereas it should show a number.
Get a technician to reload firmware.
Posted on Jul 17, 2009
    President:
  • 4,402 Answers
Make sure you have an ip address on the printer and that the lan speed is correct, from a command prompt you should be able to ping the printer.
>>>ping <ipaddress of printer>
Posted on Sep 03, 2008
Can't find sharp ar-bc320 driver for 64bit, there's only PCL5 driver which won't work, we need PCL6 driver for this model.
Sharp does not natively support or provide a PCL6 driver for this device. That being said, another possible workaround to provide you with a PCL6 driver for this is to try the HP Universal Print Driver for Windows PCL6 x64bit. This driver simply prints direct to the IP address that the printer uses on the network. You may sacrifice a few special features of the device using this driver, but I've had excellent success with it and recommend trying it.
Here's a link to the driver:
http://hp.driversdown.com/hp-drivers-download/HP-Universal-Print-Driver-for-Windows-PCL6-x64_18967.shtml
Hope this helps!
Jun 20, 2011 | Computers & Internet
Canon iR3235 will not print over the network. I can ping
Reboot the printer. ANd also try re-mapping the printer from your system.
Jul 09, 2010 | Canon Office Equipment & Supplies
Printing from a mac OSX.5.8 to a Sharp copier AR BC320?
You will need to purchase the Post Script Driver for that model. Sharp Copiers require a product key code to enable post script on their copiers. A sharp dealership will have to sell it to you as well as to get the product key code for the postscript driver.
Dec 10, 2009 | Sharp AR-BC320 All-In-One Led Printer
Printer keeps pausing itself!!
By UI do you mean RUI (Remote User Interface)? Have you installed a network kit? If so did you upgrade firmware using SST? If not, you need to do this or printing won't work.
In service mode. Copier > Display > Version > PS/PCL there needs to be a number e.g. 30.06. If there is no number the copier does not have any print drivers on it and won't be able to print. You also need to have a N BOOT-ROM (included in network kit). There Should be a N next to the number for BOOT-ROM under Copier > Display > Version if a N BOOT-ROM is installed.
Jan 14, 2009 | HP LaserJet 3330 All-In-One Printer
dev_24ind: The parallel port cannot be used for printing by default. Heaps of people have made this mistake. You need a N Boot Rom installed and N system software. Almost certainly you don't.
Get a Network Multi PDL Printer Kit C1 for IR3300 (contains N Boot Rom and NIC aka ethernet port). A technician can install this and update system software and you will be able to print. You will be able to print over a network (which is the preffered option) use Remote User Interface and Pull Scan using Canon Network ScanGear (google it).
Aug 26, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Can't print to a shared HP Laser Jet 2015 printer (Mac)
On the two non working computers...uninstall the printer drivers and uninstall any info about the printer reboot.reset up each indivual (the two non working ones)computer with new drivers from web.reboot and they should work.RICHARDM69
May 02, 2008 | HP LaserJet P2015dn Printer
No PPD available for mac
I used the Gutenprint driver for the Ricoh 220. It seems to be working fine.
Oct 08, 2007 | Ricoh Aficio BP20N Laser Printer
Canon IR C3100n copier "NG 853" error
I had a similar problem with my MF6540. I could access the remote UI and see that the printer was recieving information via the print log. It would list all of my test pages that I tried to print but in the print results column I would get an error code NG(##5536) and the printer would not actually print anything. I tried the UFRII driver stated above and everything seems to be working now.
Sep 17, 2007 | Canon imageRunner C3100 Copier
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
191 people viewed this question
old marine
old marine
