I have a Sony shelf system that was giving to me because they said it wont turn on so they didnt want it. I looked at it and it seems to be stuck in demo mode and will not turn on no matter what button i push. The front panel doesn't seem to be responding to anything i do. I disconnected the connector thats running from the front panel to the main board, blew out the dust with a can of air and reconnected it. I've done the same with all the connectors since it was pretty dusty inside. Plugged it in and tried to turn it on and get nothing but the demo.
Any Ideas what could be causing this? I was thinking that the AMP board could be bad, or even the front panel board, but im not sure.
Comments:
Aug 15, 2008
- I've done some asking around and found out that the memory chip on my stereo needs to be reset. I followed the steps from the manual to reset the radio by pressing 3 buttons. No luck! is there a way i can do it manually? or a site where i can buy a replacement front panel board? or where ever the chip is located. Its 2 main boards.
At low volume the Right Channel Speaker cuts in and out. When i turn the volume up it stops. Ive...
(More)
At low volume the Right Channel Speaker cuts in and out. When i turn the volume up it stops. Ive check wires and they are fine.
I got this system off Ebay. It is the MHC-GX250. It played fine for about an hour. I put a CD in and...
(More)
I got this system off Ebay. It is the MHC-GX250. It played fine for about an hour. I put a CD in and it played for a few minutes, then something popped and it quit. Now it just grinds and have a problem with the drawer opening also. Everything else was playing ok, then after shutting it off and turning it back on, all I get is the Standby flashing on the display. I can unplug the unit, plug it back in and the system will turn on. But it will not turn on again after shutting it off. It goes back into Standby. I have tried the reset operation, but that does nothing. Need some help. thanks
I get nothing on AM...FM works fine and so does everything else. It used to work, now nothing...any...
(More)
I get nothing on AM...FM works fine and so does everything else. It used to work, now nothing...any idea what to look for/fix, etc?
