Problem for PC Laptops
Generic problem for all PC Laptops
Cursor jumps around
My cursor jumps all over the place for no reason - if my palms are resting on either side of the cursor pad, it triggers a jump - also if the cursor is on the window in which I'm typing it jumps to where the cursor is. I have to scoot the cursor off screen in order to type, although this doesn't always solve the problem. I can't type a sentence w/o it jumping - anyone else have this problem? How can I fix this? thanx!
I have just bought an Aspire7720G laptop and have the same cursor jumping problem - just installed the 'touchfreeze' software as suggested and it seems (fingers crossed) to have solved the problem. Excellent!! It has been driving me insane!! Many thanks for the help :)
Same Problem
May 18, 2009
-   I have an HP Pavilion dv5000. I'm having chronic problems with the cursor jumping when I type. I recently installed a new hard drive, and Windows 7 RC. Seems to happen often when I type the letter "y". (happened when I typed this sentence even) Very annoying.
-   Guest Mar 26, 2009
-   Same problem as described by others. I'm working with a DELL Latitiude D630. I've disabled the all the pointer, pad functions, as well as all four right/left buttons and went to an external mouse to see if I could isolate the problem. Unfortunately it still persists. Others who have the same and other Dell notebooks report the same problem.-
H_Park Mar 23, 2009
-   I am in the same boat with my Dell 1525! My problems started after I replaced the harddrive in January- From March of 2008 to this January, it never jumped so I have got to think it is hardware or a glitch with the reload of Windows! I just want it to STOP! :(
ilkewlj Mar 07, 2009
-   I have a DeIl Inspiron 1525 Laptop, and I can't even type a few words with the cursor jumping and all of a sudden I am typing somewhere else (like a few lines above where I am typing, etc...) My fingers or palms DO NOT touch the mouse pad... I have been very careful to avoid that, and it still does it... I am getting very fed up!
Has anyone found a fix for this????????-
fedup67 Jan 29, 2009
-   dell latitude D630 laptop cursor jumps around seemingly at random. I suspect touchpad is triggered by movement of my thumb above the keyboard. I can't find out how to reduce sensitivity.
windsurferLA
Best Solution
posted on Aug 30, 2008
Rank: Apprentice
Rating: 93%, 6 votes
I was having the same problem and what I did after doing some research was to roll back the driver that was installed to an earlier version (control panel/device manager/mouse/synaptics touchpad/driver/driver rollback) once that was done under control panel/mouse/device settings/settings i was finally able to adjust the sensitivity settings. This finally fixed the problem for me, I hope it helps you because it is a very frustrating problem.
Was this helpful?2 people thought this was helpful
Solution #2
posted on Aug 14, 2008
Rank: Master
Rating: 83%, 31 votes
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
Adjust the sensitivity of the touch pad:.
- Click the Start button and click Control Panel.
- Click Printers and Other Hardware.
- Click Mouse.
- When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
Figure 1: Pointer Speed
- Under Select a pointer speed:, click to move the slider bar closer to Slow.
- Click OK.
- Check to see if the touch pad still behaves erratically.
- If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Was this helpful?7 people thought this was helpful
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
i want to bye the best performance laptop on the market, with the state of the art hardware, 15in...
(More)
i want to bye the best performance laptop on the market, with the state of the art hardware, 15in display with 1gb vga, 500gd hdd,. hd plugs, 4gd ddr3 memory, ... what laptop do u recomend
the best site i have ever visited,,, thanks fixya guys
Ihave a netbook Acer Aspire one D250-1116 model KAV60...we have dial up and i need an external type...
(More)
Ihave a netbook Acer Aspire one D250-1116 model KAV60...we have dial up and i need an external type modem to connect with an usb port.. we haven't got wireless in the area, we are in a very rural area...Can you help me?
StartUp no menu on Acer Aspire 5715-4713 Notebook
Hp pavilion entertainment pc dv2214us Is slow to boot is okay for a couple of days then the screen...
(More)
Hp pavilion entertainment pc dv2214us Is slow to boot is okay for a couple of days then the screen scrambles horizontal lines. Have new battery and old cord... should I replace or think it is more hard drive issues?
8 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Dec 14, 2008
I have a different Medion laptop but have the same problem. I'm now happy with the touchfreeze solution of performing fn-f3 when I want to enter text. All I want it the option to disable touch to click is that too much to ask of the driver?
Comment by a-nibert, posted on Oct 30, 2008
Did ya'll think we had an earth quake? Nope! It was just me rantin' and ravin' about this crazy cursor JuMpIn'.....I do not look at the keys or screen while typing...I look only at the document.....The anger and frustration I feel when I finish to only see Jibberish....Please HELP!
Comment by Guest, posted on Sep 08, 2008
mouse cursor jumps when typing. I have no option tp disable touchpad
