Question about Dell Dimension 8200 PC Desktop
Shutdown i have to go through the shutdown two times before my computer will shut off. I have a dell 8200 dimension...Thank You
  • pleiku10 Aug 17, 2008
    OK, I don't see the "Hide all Microsoft" check box?
    Scholar:
  • 93 Answers
Manual steps to perform a clean boot in Windows XP
Step 1: Start the System Configuration Utility
Click Start, click Run, type msconfig, and then click OK.
The System Configuration Utility dialog box appears.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box.
5. Click the Services tab.
6. (VERY IMPORTANT DON'T MISS THIS) Click to select the Hide All Microsoft Services check box.
7. Click Disable All, then Click on the startup tab and click on Disable All Button and then click OK..
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. Log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK:
You have used the System Configuration Utility to make changes to the way Windows starts.
The System Configuration Utility is currently in Diagnostic or Selective Startup mode, causing this message to be displayed and the utility to run every time Windows starts.
Choose the Normal Startup mode on the General tab to start Windows normally and undo the changes you made using the System Configuration Utility.
Step 4: Optional step to disable features
This step temporarily disables Microsoft features such as Plug and Play, networking, event logging, and error reporting. Also, this step permanently removes the restore points from the computer. The System Restore feature uses restore points to restore your computer to an earlier state. If you remove the restore points, you can no longer restore Windows to an earlier state.
1. Click Start, click Run, type msconfig, and then click OK.
2. Click the General tab, click to clear the Load System Services check box, and then click OK.
3. When you are prompted, click Restart to restart the computer.
Steps to configure Windows to use a Normal startup state
2. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
Posted on Aug 14, 2008
I have a dell dimension 8200 with Windows XP, sp3. We bought a Belkin N600 Dual-Band Wi-Fi USB adapter to put access wireless internet. The software installs but the internet will not connect. We have a...
Dell offers technical support via phone and chat. You can reach technical support at 1-800-204-4427. You may also chat with Dell Technical Support representative (U.S.) 6 Am to 6 Am, (24*7 hours) Pacific Time, Monday through Sunday. If you needs a technical diagnosis you can call on our Microsoft technical support team 1-800-204-4427, which is especially open round-the-clock for online assistance. For more Click :
Dell Technical Support Phone Number 1 800 204 4427 USA Canada
Apr 30, 2017 | Dell Dimension 8200 PC Desktop
Why does my dimension 8200 dell desktop say "strike f1 to retry boot, f2 for setup utility"
Rduy Cruz,
This error message references that your system Primary hard drive is not being Detected in the system. You can press F2 to enter the setup to see if the hard drive is even being seen. If not, exit out and shutdown the system. Unplug the power cable and open the computer to reseat the hard drive cables at the hard drive and at the motherboard connection. If that does not resolve the issue you may need to replace the hard drive IDE cable.If all this does not work you may need to replace the hard drive. Please post back if this does not resolve the issue.Below is a link to your online manual for your computer.
Dimension 8200 Online Manual
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 24, 2013 | Dell Dimension 8200 PC Desktop
I havd a Dell Dimension 8200 that sometimes shuts down and power light turns yellow. I can usally open case and plug and on plug to get it to power back up. Recently replaced fans due to fan failure....
Thank for the detail, it really helps...
Most people forget about the power supply. If the power supply overheats, it will shutdown. When shutdown, it will cool off then operate again.
A power supply goes by WATT ratings, the average size power supply is now 450 watts for an average system and should cost around $60.
good luck and don't forget to vote.
Oct 12, 2010 | Dell Dimension 8200 PC Desktop
Dell Dimension 8200 Desktop PC shuts off after it has been on for a long time. It shuts off like power has been removed from the CPU although I have an APC hooked up to it.
Sir you should check the power supply of your system.If its working properly then its because of the heat sink of your motherboard...Try to mother heat sink fans in the pc and your problem is solved......
Aug 02, 2010 | Dell Dimension 8200 PC Desktop
I am getting ready to intall additional Rambus memory to my Dell Dimension 8200 and need walked through it... Any help?
Hello d_silverthor,
Here's a video link shoing how to install memory in a Dell Computer:
http://www.memorystock.com/memory/viewvideo.asp?systemtype=Dell+Desktop&Class=Desktop
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 07, 2010 | Dell Dimension 8200 PC Desktop
I want to replace CD drive on Dell Dimension 8200. My options are serial ATA, parallel ATA & ATAPI. Which one do I need?
This computer has 2 IDE connectors. These are parallel ATA connectors.
See: Dell Dimension 8200 Specs
If you get a drive, look for IDE on the package. IDE, PATA and ATAPI are near synonomous. They use a 40 pin flat ribbon cable to connect.
Thanks for using Fixya.
Nov 25, 2009 | Dell Dimension 8200 PC Desktop
Wiring diagram from the LED power button board to the 0M686 CTRL PNL BOARD on a DELL DIMENSION 8200
Go to the Dell web site and type in you computer information and look for a pdf download for repairing the Dimension 8200. Dell is real good about giving you any information on fixing your computer. And it is usually free. I use them all the time. If you are having problems finding it on there site, you can call them and request the information you need...Hope this helps you,,,Darren
Oct 16, 2009 | Dell Dimension 8200 PC Desktop
Dell Dimension 8200 won't power up
If the power button does not light up at all, I would guess the power supply has a problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 8200 PC Desktop Logo
132 people viewed this question
Alun Cox
