Question about HP Computers & Internet
HP Pavilion 1640n doesn't power up even with a new power supply and new ram
  • ozserviceman May 11, 2010
    Can you describe what does happen. Any beeps on power on? Fan or hard disk spin? Why did you change the power supply and ram?
  • 5 Answers
SOURCE: Power Supply
Recommend the Coolermaster IGreen PSU to replace the inferior and faulty PSU in my Pavilion t461. I bought from eBuyer and fitted perfectly with a bit of persuation. Very quiet and comes in varies power outputs. Good review at http://www.overclock3d.net/reviews.php?type=3&id=81&page=1&desc=coolermaster_igreen_power_430w
Posted on Dec 09, 2007
  • 54 Answers
SOURCE: HP Pavilion dv1000 no video even with external monitor
ya its problem with ur cd player only the thing u have to do is u need to chANGE ur drive
Posted on Feb 26, 2009
DickCanFixIt
  • 948 Answers
SOURCE: what is the ram limit of HP Pavilion 061
From the HP specifications page for Pavillion A530N:
Memory type DDR Memory speed PC 3200/2700/2100/1600 Memory sockets Two DDR DIMMs (184-pin) Maximum HP/Compaq approved memory Two x 512 MB DDR-DIMMS, 1024 MB total (1 GB)
Posted on Mar 10, 2009
  • 788 Answers
SOURCE: Failed intrenal power supply on HP Pavilion dv6700
Before you go thru all that, HP has an extended warranty for 6 and 9K units with Video and Power startup problems.
They have added an extra year to the original warranty and it would be to your benefit to check first.
Email customer care and issue a repair request.
You can chat with a tech and find out in no time yes or no.
If you log a issued complaint, they may review it in your favor.
Posted on Sep 20, 2009
Testimonial: "Appreciate the comments."
nicoleFIXIT
  • 154 Answers
SOURCE: HP Pavilion dv6636nr boot problem
When we talk about laptop won't boot up it is a hardware failure.
First of all, most of the hardware failures that are going to be presented in this article require you to disassemble the laptop and work on its internal components. Because of this, you need the required components to take the laptop apart (such as screwdrivers, etc.) and space, lots of space. If you don't have a workbench, then working on that large table in the living room should do it.
Second of all, you need to be extra careful about ESD (electrostatic discharge). Sure, this is important when working with a desktop system too, but you really shouldn't consider this as some sort of overreaction or waste of time. A few anti-static conductive bags should suffice. These are going to be useful when you take apart components from the laptop and you need a safe place to put them down.
If the laptop does not power on using the batteries, then try to power it using the AC adapter. Pay attention and see whether the LED on the laptop lights up, signaling that the adapter was detected. If yes, then your power jack works. If the notebook still does not power on, disassemble the laptop and remove the batteries. Look first for the CMOS battery and take it out.
Your best bet is that the problem is memory-related. What you need to do is re-seat the memory modules. If there are more than one, then try swapping them between each other and try different slots. Try booting again. If it does not work, then try running with only one module - this way, you can tell whether one is faulty.
Disassemble the laptop and remove the HDD, CD/DVD drives, and the modem and/or wireless card(s). If possible, take out the sound card module (if separate). To minimize the possible causes, you may disconnect the LCD panel as well. Try running this way. If it does boot, then try connecting each connector one at a time, booting up in between to localize the problem.
Good luck and take time to do a hard troubleshooting this trouble is not easy as well. You need to be care full in removing the some parts so that the other will not affected and being damaged.
Posted on Dec 02, 2009
Testimonial: "thanks! i was not waiting long enough before replacing the cmos battery back in its slot. after a ten minute wait, it did the trick. you rock."
Macerator is not working
Replacing the Power Supply in HP Pavilion p6000 p6 1000 and p6 2000... BestBuy, MicroCenter, Amazon. Very cheaply priced, very functional. Even the generic brands. Hope this help.. have a great day. OH, make sure you at least match the current power supplies WATTs and it's connection. ? if your information is correct "power supply"
Feb 09, 2013 | HP Presario Computers & Internet
Green power supply light is flashing so power is getting to the computer, however the computer will not start from start button. Have removed case and tried ***** start button. Didn't work. Comput
Power getting to the computer/Power Supply?
Yeah.
Power Supply good? -> NO
A) IF ALL of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use from 51 to 125 Watts of power.
Just depends on what Processor it is.
HP Pavilion a810n Desktop PC?
Uses an AMD Athlon 64 3300+ processor,
(Operates Up To a frequency rate of 2.4GHz)
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00280647
http://en.wikipedia.org/wiki/List_of_amd_athlon_64_microprocessors#.22Newcastle.22_.28CG.2C_130_nm.29
Can use up to 89 Watts of power.
Your Power Supply doesn't even have enough power to spin fans, much less start the Processor.
Want to test the Power Supply? Have a multimeter?
No? Have a power supply you can borrow for a test unit?
KNOWN to be good, and Compatible?
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 05, 2012 | HP Computers & Internet
Will not power on
if all fan are spin up.
see your RAM, maybe its broken.
a computer need a routine checking all RAM, if its not good, your computer will freeze.
try pull out and put it again. if its doesn't work. replace it.
PS. when you pull out your computer with all RAM pulled out and doesn't heard any BIP BIP BIP (BIOS POST CODE) noise. I can Assume your Mainbpard or ypur processor is broken. maybe its sound scary but its not. see for computer service center to help, they can give you good advice.
May 09, 2012 | HP KT334AA Pavilion Media Center M8530F...
I have no display even at start it doesn't turn on my monitor
Hi Anthony,
Does the PC actually start up? In other words do the front panel lights come on and can you see the power supply fan turn at the rear where you plug in your power cable?
If so, try removing the RAM memory from the motherboard, clean the connectors with some surgical spirits or anti-static spray, then replace the RAM firmly back in their slots and try turning on your PC again.
Let me know if you still have a problem after following this procedure.
Best wishes,
Graemevm
Jan 14, 2012 | HP Hewlett Packard Pavilion Slimline...
I have a HP Pavilion Slimline s3700y that doesn't always boot. Power is getting to the computer; the light on the back lights up as well as the lights on the front. However, power doesn't seem to...
If you saying "doesn't always boot", most common would be motherboard...
If your motherboard still beeps, then probably some other components has the problem like RAM, GPU card etc., depends on your motherboard.
Hope that give an idea...
Jul 11, 2011 | HP Pavilion Slimline s3700y Desktop,...
I have a hp pavilion a635w that will not boot up not even to bios
check if the ram if is compatible with the board
check if the battary power the bios
Dec 22, 2009 | HP Pavilion A635W PC Desktop
HP Pavilion desktop. Installed new RAM, won't power up.
the power supply seems to be fine> but we can check by removing the BIG ATX white connector on the motherboard> if the light is still on then the power supply is fine>>> then
we can first remove all the RAM from the motherboard> then connect the computer to power and then see if the Computer beeps or not> if it does the motherboard is fine > if it doesnt then the motherboard need to be replaced
Oct 17, 2009 | HP Computers & Internet
Hp pavilion.
You could have RAM problems.
Reseat the RAM module/s, they may not be making proper connection. If this doen't work you may have faulty RAM. Take them out and test them in another laptop or get your friendly computer shop to test them for you.
Jul 02, 2009 | HP Pavilion dv6000z Notebook
I have a hp pavilion 513c it wont boot up! the
There are only two ways this can go for you.
One- you need a new power supply
OR
Two, you need a new mother board
You can verify the power supply by checking it on another machine
If the power suppy is good
And you do not hear the bios beep- then you are looking at a new motherboard- I would double check the powersupply first- most stores that sell them will let you check before you buy a new powersupply.
Mar 26, 2009 | HP Pavilion 513c PC Desktop
Lappy is dead mon.
question: have you replaced the RAM by yourself??? do you get the problem before or after the replacement?
if you get the problem after replacement your RAM probably have static groundings... it was get from not demagnitizing your hands and tools before installing a RAM... if you still got the old RAM... clean the contact points and the RAM socket first and test the old RAM to your unit... if you stop having problems just return your 2gb RAM and ask for a replacement...
Jan 19, 2008 | HP Pavilion dv1310 Notebook
Computers & Internet Logo
118 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
