Vcr trouble shooting
I bought a new tv set. Hook up all necessary connections correctly. Still, I don't receive any picture. I went to ch 3 & 4 , press my input button on my tv remote, nothing.Tv set mention"No signal ". I also, try to see if it was on another channel.When I had my old tv. I always use my input button on my vcr remote. Now, that I have this new Sony Bravia. I don't have codes to use for this tv.For programming channels.So, what is the problem??
My VCR shuts off when I try to rewind a tape, can anyone help?
Posted on Nov 15, 2012
3 Suggested Answers
fairlane
  • 50 Answers
SOURCE: New VCR Old TV
Hi This problem has been around for some time when connecting a DVD player to an older tv, and now has become a problem with newer VCR's. You must purchase a device called an RF Modulator which will allow you to connect to the older tv. We sell them at our shop for $30.00 but I have seen them quite often for $65.00 and up...so it pays to shop around. Good Luck
Posted on Sep 27, 2007
Danmart
  • 291 Answers
SOURCE: troubleshooting vcr
Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture.
From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
Posted on Aug 16, 2008
We have a digital tv but an anologue vcr so we bought a strong srt 5430 so we can record through our vcr but are having trouble conecting the vcr and set top box
You need a cable to go between the yellow (picture), red and white (sound) sockets on the strong to the VCR.
Those cables will connect to one of the VCRs AV inputs. You then need to use the VCR remote control to switch from the now defunct analogue tuner to the Line or AV input. Put your TV on the channel you use to watch video tapes. Switch on the Strong receiver. Do the switch to the Line or AV input on the VCR. When your VCR is on the correct input then you will see the picture from the Strong receiver on the TV. You can confirm it is the correct source by displaying the Strong's EPG.
When you come to make recordings, the Strong will need to be left on the channel that you want to tape. If your TV already has an aerial feed and isn't relying on the strong for its signal then you can watch another channel on TV.
Aug 27, 2014 | Televison & Video
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
I just need a diagram to show me how to hook the dvd/vcr up to my television. I have Dishnetwork as well. I un-hooked and now I can't get a picture.
Not knowing the model of the TV its hard to tell you how to hook it up. Howeever let's assume that yu TV has an auido in and a composite video input. it it does is should have three RCA jacks on the back...one red, one white and one yellow.
Assuming Dishnetwork is being used as a analog video.
Connect the VCR/DVD player via a patch cable ( usually has three cable all color coded, red, white & yellow) Red and White section is used for the audio Left and Right. The yellow cable is video.
Connect the audio out of the VCR/DVD player to the audio input on the TV. Do the same with the videoout of the VCR/DVD to the TV may be marked "Composite Video". Now connect your Dish Network receiver RF Out to the TV. This should be a coaxal cable.
Now when you want VRC/DVD use your remote and select input. Some older TV's have the aux input just before Ch 2. Some remotes have an input button.
once you have aux inpsut selected turn on the dvd and play your movie to view Dish go to Ch 3 or 4 depending on how your TV and system is set up.
Again not knowing the model TV you have, this is a general hook up.
Thank you Let us know if it helps
Tom Miller
Broadcast Engineer
Sep 09, 2011 | Televison & Video
Vcr
do you have a cable box/satelite/directtv? yes..okay box out to vcr in....vcr out to tv...(vcr must be set to ch 3 at all time)....no box at all, antenna should be connected to vcr/tv
Jun 19, 2010 | Memorex MVD4540 DVD Player/VCR
I have a 20 inch sanyo hd digital hooked up as a second tv on dish network receiver. I had to unhook it temp and when I hooked it back up, no picture. I tried channel scan and nothing. How can I get the tv...
bring the tv out to the main tv and hook it up to that connection to determine if it's the TV or the connection. Or try hooking up a VCR to the tv while the TV is set to CH 3. Do you get a blank picture or a snowy Picture?
Sep 20, 2009 | Sanyo Televison & Video
My Zenith VCR is not working with the digital converter box
When the VCR is "off" the converter signal should go right through the box, which you say it does. Then, when you turn the VCR "on" the picture disappears. That, so far, how it should be. To get your picture back while the VCR is "on" you must set the VCR to "receive" channel 3, and use your new converter box to change channels...accordianman
Dec 16, 2008 | Televison & Video
Troubleshooting vcr
Aug 14, 2008 | Televison & Video
Blurry Sanyo TV
Well after playing around with the tv some more, I decided the problem was probably the cable jack, and tried running the video in/out cables thru the VCR to get around this, which I read generally works but in this case nothing. I had tried the tv on various settings, anytime I put the tv in "video" mode I'd get a blue screen and nothing else. Anyway I found a switch in the back of the Direct Tv box for ch. 3 & 4 settings. So I flipped it but still got a snowy picture, only this time it was on ch 4 instead of ch 3. By sheer accident I put the tv back in video mode while I had the satilites setting to ch 4, and the picture came up crystal clear. Since I didn't mess with it further, I'm not sure if it was the channel selector or the fact that hooked the tv up via the video cables, but whatever it was it did the trick.
I just KNEW this could not be a broken tv despite the fact that everhwere I read online suggested it was. I knew pictures can go out, or sound can go out....but to have BOTH go out didn't make sense to me. Anyway, glad its working! :)
Jun 15, 2008 | Televison & Video
Emerson VCR and new TV don't hook up
hey i sort of hav the same problem except, i cant access the "channel" with my sons game stuff on it
if i click menue then it just givs me "Picture" "Channel Set" "Language" "V-Chip Set-Up" "Captions" and if i click channel set i get "CH{TY}" "CH{CATV}" "CH{DTV/TV}" and v-chip asks me for an access code. and i got this tv from a friend and he lost the remote. i only hav an iO Digital Cable remote. help me plz
Oct 28, 2007 | Emerson EWD7003 DVD Player
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
