Question about Philips DVDR3320 DVD Recorder/VCR
Won't dub I am trying to dub a VCR to DVD and I just keep getting a red x everytime. I followed the instructions in the booklet....
  • toad_apocs Aug 14, 2008
    Nope, home recorded tape to blank dvd. I even changed dvd's. I'm thinking defective laser. This has happened to me before with a Zenith model - the laser went bad
    Sergeant:
  • 263 Answers
It could be that the tape is copy protected. in that case, you're out of luck.
Posted on Aug 14, 2008
  • Ken Williams
    Ken Williams Aug 14, 2008
    it could be a bad laser, or 1. a bad DVD, or the wrong type of DVD.
    There are two types of DVD recordables. DVD-R and DVD+R.
    Please check the compatability of your burner. some burners will do both DVD+-R. Of course, there are also the 'RW' types, and now dual sided and HDDVD/Blue Ray... Good luck
    Lastly, it COULD be a bad recorder...
SOURCE:
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Oct 24, 2009 | Televison & Video
I have a JVC DR-MV5S. When I dub a VHS to DVD,
The disk must be finalized. Instructions are on page 79 of the instruction booklet for the MV5S. I can't get the manual to download from the MVC site, but maybe it will work later. Hopefully you have the manual.
Jul 13, 2009 | JVC DR-MV5S DVD Recorder/VCR
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Dubbing VCR to DVD
Have you correctly referred to its original instruction manual? If not , try these simple instructions: 1. On the unit, Press the (VCR>>) button until it is illuminated 2. Still referring to the unit, Press the (DUB) button, which is situated in the middle of the (<<DVD) and (VCR>>) dub buttons. these two steps should automatically start a VCR to DVD dubbing. If not please continue to post, but in more detail, so your problem can be more easily interpreted, Thank you.
Dec 30, 2008 | JVC DR-MV1S DVD Recorder/VCR
Cannot start dubbing
I'd guess you are using cable TV-some cable companies put their own copyguard on the cable signal, Comcast, in my area does this. The DVD sees the 'do not copy signal' and won't do it.
Try recording directly to DVD without using the HDD drive. If you get a playable disk, I doubt it is your machine. If you don't get a playable disk, that plays in THAT machine-it is the machine..
Jun 07, 2008 | Televison & Video
VHS to DVD Dubbing Problem
I have the same problem. I saw a solution that said I needed to set my cable to a non-premium channel like NBC, ABC, PBS, CSPAN in order to allow the dubbing to occur without the +VR problem. At first, I thought it was a stupid solution; but guess what, It worked. I just set my cable box to from HBO to CSPAN,restarted the dubbing from VCR to DVD and it worked. Now the question is: Why do I have to change the channel when I'm dubbing from VCR to DVD?
This worked for me..still trying to figure out why it worked???
May 25, 2008 | Philips Magnavox DVD/VCR Dual Player
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Philips DVDR3320 DVD Recorder/VCR Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
