Question about GE APN10AA Portable Air Conditioner
This air conditioneer
Dropped item in back round "vent"---turbine looking item got stripped of all it's vanes---i need replacement part---04032635 (the 3's might be 9's), or 0195x87x01ox66-1 (i think the o is an o, because the 0's have horizontal lines through them. Any suggestions?
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Try the comanyswebpage and its model #
Posted on Sep 02, 2008
I HAVE A MAYTAG PIHXD2-18KW4A I NEED THE IMPELLER TURBINE
Fixya does not sell replacement impeller turbines. Check with a local appliance parts supplier.
Aug 29, 2016 | Maytag M6Q10F2A Air Conditioner
What would cause the Turbo on my 2010 Mondeo not to work in 1st & 2nd gear ? but works ok in the rest
check the turbo vane actuator is operational or the vacuum hose to it is not cracked or broken
the system can become difficult to operate from heat
in the turbine side ( exhaust) there is a series of vanes that move to direct the gas flow better onto the turbine wheel for better acceleration at low engine speeds as the gas flow in creases these vanes move outwards for better gas low
remember that the only thing that makes a turbo is exhaust and it has to be hot from extra fuel being burnt and expanding to spin the turbine wheel
at light engine loads that fuel is not being supplied and so if the vanes are not moving freely the turbo will not perform properly
Take it to an accredited turbo specialist for tests and a proper diagnosis and quote
Jul 10, 2016 | Ford Mondeo Cars & Trucks
How do you remove the air vent on a 2009 vibe
not a good idea find another location
Aug 18, 2014 | 2009 Pontiac Vibe
Nissan d40 manual stx deisel runs fine revs right out but lacks power it used to have under load
Unlikely as the check will only point to an actuator sensor problem. Check the intercooler hoses are tight and check the intercooler for holes/cracks where there may be a loss of boost. Check that the turbine vanes are free to move by pulling on the actuator rod . If it doesn't move then the vanes facing the turbine are stuck and the variable effect is not working. Most small turbos have vanes that direct low speed exhaust onto the turbine wheel earlier to give boost at low rpm and the vane angle alters as the exhaust speed increases to give more torque to the turbine blades. This action is controlled by an actuator located in between the shells of the turbo and the actuator is controlled by vacuum hose connected to a electronic module operated by a sensor.. Check the hose as they become brittle from the heat and crack off.
Jan 26, 2014 | 2007 Nissan Navara 2.5
HAIER ONly blows air on one side
Possible that the vent or the vane is blocked which can also be due to a jammed motor in the auto oscillation vent.
Remove the panle and check the free movement which will confirm this case. Sometimes it could be dirt that is logged in that prevents free movement.
Jul 03, 2012 | Haier HPRB07XC7 Portable Air Conditioner
97 vw sharon tdi has full power to start with when driving but under load power drops of as if the turbo stoped working switch it of and on and it goes ok for a wee bit and does the same thing again
In your case the turbocharger is responsible for engine losing power.
The car goes in "limp home" mode!!!
After scan the EDC-15P engine control unit with a VAS, VAG or KTS -BOSCH diagnosis tool you will find this: Fault code: P1557-Turbo Boost pressure control exceeded
1. Engine stopped and ignition switch off. Check all pneumatic connections and hoses between turbocharger actuator = pressure unit for boost-pressure control, boost-pressure control solenoid valve, vacuum reservoir, EGR control solenoid valve, intake-manifold flap solenoid valve, EGR valve with throttle - part of intake manifold. Also the vacuum connection between tandem pump and brake booster. If you find something wrong replace parts. If not go to step 2.
2. Extract the hose of the turbocharger actuator = pressure unit for boost-pressure control part of turbocharger. Instead of the original hose you must place another 1 meter long hose with the same inside diameter, and then you check to inspire yourself the air from the other one extremity of this hose. The mechanical connecting rod of the turbocharger actuator must have a smooth and whole motion. If you can do that with your mouth, then you must replace the boost-pressure control solenoid valve. If you can not reach this with your mouth, then you go to step 3.
3. This is the most difficult work. The problem is that the soot particles deposits inside the turbocharger plugging the variable nozzle geometry mechanism = adjustable vanes of the turbine. If the turbocharger actuator is not able to adjust the turbine vanes the charge air pressure increase too much and ECU (engine control unit) go in "limp mode" = engine protection software. As a result the "limp home" mode engine still running until you turn the engine off (ignition switch off) and back on when the "limp mode" is deactivated, but the fault still remain in ECU memory!
4. You must be able to extract the turbo out from the engine. Then disassemble the turbocharger, clean inside adjustable vanes mechanism, and refit all in reverse order.
Good Luck!
Sep 22, 2011 | Volkswagen Passat Cars & Trucks
My air conditioner isn't cooling as much as it used to. Someone suggested it may need freeon, or some other type of servicing. What do you think?
Every air conditioner requires normal servicing at least once in 3 months. I would suggest you prefer any services that are reliable as well as effective. You can choose socool aircon servicing for this purpose as this is a prominent aircon servicing in Singapore which is specialized in air conditioning servicing and repair. They offer 24 hour online services and solutions that you need in order to ensure the maximum efficiency of your air conditioner.
Jul 19, 2011 | Maytag MEY12F7E Air Conditioner
Hi i have an audi a6 1.9tdi with the awx engine in it it keeps going into limp mode there is no air leaks ive read the codes and it say says turbo over boost? new egr, you can see the actuvator arm move...
After scan the EDC-15P engine control unit with a VAG or KTS -BOSCH diagnosis tool you will find this: Fault code: P1557-Turbo Boost pressure control exceeded
4. You must be able to extract the turbo from the engine and then to disassemble the turbocharger, clean inside adjustable vanes mechanism and refit all.
Jan 14, 2011 | Audi A6 Cars & Trucks
Air outlet vanes not moving
they usually snap together. they are plastic, its possible it became unhinged or broke.
Aug 19, 2009 | NewAir ACP-1300H Air Conditioner
Front air blows cold, rear air blows warm
I believe the rear A/C - HEATER unit is located under the right rear trim penel. Open the rear hatch and remove inside trim panel on your right side. There you will find an evaporator core and a heater core and a blower motor. Also an expansion valve / orfice tube. Have someone turn the HOT/COLD knob while you look at the motor that opens and closes the temp door located in the evap/heater box for the rear A/C-HEATER. This "motor" doesn't really look like a motor persay. It is about 1 1/2 inches thick and 3 or 4 inches square. If you look at the center of the motot there will be a white round piece of plastic that should be turning one way for heat and the other way for cold. If it's not turning check the plug with a test light to make sure you have power. These things are made of plastic and breake all the time. So if it is turning and you hear it "clicking" then the teeth are stripped or the gear is broken. The motors are not that expensive.(I guess because they breake alot). Hope this helps.
Apr 28, 2009 | 1995 GMC Suburban
GE APN10AA Portable Air Conditioner Logo
80 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Mack Baxter
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
