Question about Frigidaire ATF6000ES Front Load Washer
Washer won't work!
I overloaded my frigidaire gallery washing machine (2 sets of sheets and pillowcases) and it stopped midway through the cycle and I can not get it to go on again.  I have just unplugged it and I am waiting to try again after an hour.  Is there any other way to reset it? Thank you!
  • 639 Answers
Dear jp01
ngfam at you service,
You did the right thing to try and reboot it!
If it fails I believe you will need service
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 25, 2008
SOURCE:
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Jun 09, 2013 | Frigidaire Washing Machines
My frigidaire gallery washer jumps around on the spin cycle. I have beeen told that I have overloaded it and underloaded it. Sometimes it works just fine but most of the time it shakes my house and I...
Two thoughts come to mind;one is that the load is not distributed evenly in the tub, try distributing the load by weight more evenly; two perhaps the feet of the machine are not set for even contact with the floor.The machine should not rock from corner to corner
Feb 14, 2018 | Frigidaire Gallery GLWS1339EC Top Load...
The washing cycle stops at the final spin. The
If this machine is a Kenmore 417 Sourse (WCI) built washer with a font load,check tech sheet.I had the same problem on a Frigidaire frontload and it was the door latch/lock assembly.These machines can be tricky sometimes.Use tech sheet and make sure lock assembly ohms out ok.
Mar 04, 2010 | Kenmore HE2 Plus Front Load Washer
Door will not unlock, cycle did not finish.
Unplug the power cord let it reset..It should unlock
May 21, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire ATF6000ES Front Load Washer Logo
117 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
