I got a panasonic PT-51SF30R rear projection Tv that has a bad convergince issue. The controls on the front do very little.
  • 19 Answers
SOURCE: cleaning the INSIDE of a rear projection tv - Panasonic PT-51G35
its better to see any experts near you,its risk your tv.
Posted on Oct 30, 2007
  • 5138 Answers
SOURCE: panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Posted on Feb 05, 2008
  • 8617 Answers
SOURCE: power up
is it a constant blink, or does it blink a nummber of times in between payses? Let me know the number of blinks. Please respond to this same post so I have access to previously posted info.
Posted on Jul 01, 2008
SOURCE: Panasonic Rear Projection TV PT-47WXC43
I have a Panasonic PT-47WXC43 47 in Rear Projection. It went off, on picture, no sound.
Posted on Oct 11, 2008
  • 10594 Answers
SOURCE: What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Posted on Apr 18, 2010
Testimonial: "Thanks"
How do I reset the Panasonic PT-43LC14 projection TV's lamp hour meter
Go to "Service Mode Map" by pressing the "Volume down" button key on the front panel and "TV/Video" button key on the remote control at the same time and hold it for more than 5 seconds. You can now reset/change the value of lamp operation time.
Sep 21, 2011 | Panasonic PT-40LC12 40" Rear Projection...
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
Chance the lamp?
I assume your TV is Panasonic PT-60LCX63
TV needs TYLA1000 lamp and replacement procedure is written in separately issued manual, click HERE to download a copy.
Pull lower front of TV and unscrew lamp cover, procedure details with exploded views are in above manual.
Oct 16, 2009 | Panasonic PT-60LCX63 60" Rear Projection...
Panasonic 53" tv pt-53wx42
your convergence ic is going bad. remove front and adjust the level of blue.
Jun 01, 2009 | Panasonic PT-53WX53 53" Rear Projection...
My panasonic project tv colors are crazy cant fix convergence lin
you must adjust it by hand located in the front of the tv you must remove front panel and speaker panel,s you will se six
Jan 17, 2009 | Panasonic PT-51G44 51" Rear Projection...
Jul 13, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
Panasonic projection tv
call panasonic, bulb blown under warranty for 18 months the bulb is 284.00 just had mine replaced. it's a little over a year old
Dec 27, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic Projection TV PT-47WX49E convergence ...
may not be convergence may be a bad stk for convergence if that style if so try stk
Oct 28, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-51HX41 51 in. Rear Projection
check the micro chip on the system control could be bad.
Apr 13, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
