Question about Lexmark X125 All-In-One InkJet Printer
Paper jam The screen on printer says to clear paper jam and then press start to continue printing. There is no paper jam. Everything was checked.
  • Lexmark Master
  • 6,487 Answers
You can check this link for the step by step procedure to resolve this concern for your printer http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00651302&lc=en&cc=us&dlc=en&product=1141647
Hope that helps.........
Posted on Aug 14, 2008
  • 2,427 Answers
Remove all the paper from the papoer feed tray, open and close all the compartments that allows you to remove the paper if any is stuck.. with the paper out the tray, press the paper feed button or contine and this should work, if not unplug then plug back in.
When printing documents no matter how few or how many pages, paper gets stuck in the middle of printing.
Try using regular paper on unit as specified by Samsung. If that does not resolve the issue then the hassle lies with the paper feed mechanism. Often a good cleaning of all the rollers in the path can take care of the issue.
Aug 24, 2015 | Samsung ML 2525 BW laser Printer
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    My Lexmark 4600 printer has a paper jam. do not know how to unjam it.
    How to clear and avoid paper jams
    Follow these instructions to remove and/or avoid paper jams and misfeeds in your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
    Paper jam in the printer
    Remove the paper manually
    1. Press pattlnk_10282008_1820-power-icon.gif to turn off the printer.
    2. Firmly grasp the paper, and gently pull it out.
    3. Press pattlnk_10282008_1820-power-icon.gif to turn the printer back on.
    NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
    Paper jam in the paper support
    Paper or specialty media misfeeds
    These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
    Try one or more of the following:
    Check paper condition
    • Use only new, unwrinkled paper.
    Check paper loading
    • Load a smaller amount of paper into the printer.
    • Load paper with the print side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
    Remove each page as it is printed
    • Remove each page as it exits, and let it dry completely before stacking.
    Adjust the paper guides
    • When using media less than 8.5 inches wide
    • To rest against the edges of the paper or media, making sure it does not buckle
    Printer does not feed paper, envelopes, or specialty media
    These are possible solutions. Try one or more of the following:
    Check for paper jams
    • Check for and clear any paper jams. For more information, see "Paper jam in the printer" and "Paper jam in the paper support" above.
    Check media loading
    • Verify that the specialty media is loaded correctly.
    • Try loading one page, envelope, or sheet of specialty media at a time.
    Check printer default and pause settings
    1. Click:
      • In Windows XP (default Start menu): Start pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
      • In Windows XP (Classic Start menu): Start pattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
      • In Windows Vista (default Start Menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gifControl Panel pattlnk_10282008_1829-right-arrow.gif Printers (under Hardware and Sound).
      • In Windows Vista (Classic Start menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers.
    2. Double-click the print queue device.
    3. Click Printer.
      • Make sure no check mark appears next to Pause Printing.
      • If a check mark does not appear next to Set As Default Printer, you must select the print queue device for each file you want to print.
    Banner paper jams
    There are many possible solutions. Try one or more of the following:
    Clear banner paper jams
    2. Remove the jammed banner paper from the printer.
    Review banner printing checklist
    • Use only the number of sheets needed for the banner.
    • Select the following settings to enable the printer to feed paper continuously without jamming:
      1. With a document open, click File pattlnk_10282008_1829-right-arrow.gif Print.
      2. Click Properties, Preferences, Options, or Setup.
      3. Select the Paper Setup tab.
      4. From the Paper Size area, select Banner.
      5. Select Letter Banner or A4 Banner as the paper size.
      6. Select Portrait or Landscape.
      7. Click OK.
      8. Click OK or Print.
    Regards,
    Ron
    Mar 26, 2011 | Lexmark 4600 Multi Function Printer Option...
    The paper light is flashing. The tray has paper, there is no paper jam. I check everything, put tray back in, press go and after a few seconds, there is a click noise and it starts flashing. What do I do?
    The light flashing may mean more things, not just a paper jam. Could mean any of the following:
    - Front cover is open: Close the front cover of the printer.
    - Back cover is open: Close the back cover of the printer.
    - Paper jam: Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
    - No paper fed manual feed slot: Put the paper back in the manual feed slot.
    - Memory full: The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
    - Print overrun: A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, go here.
    - Drum Error: The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
    Thank you for using Fixya!
    Dec 02, 2010 | Brother HL-2040 Laser Printer
    Message shows 'clear paper jam then press check mark....no paper jammed in printer but it will not reset.
    message keeps showing print cartridge cradle cannot move, I have check everything, no paper jams nothing under printer, I am turned off printed but keep getting same message.
    Sep 17, 2009 | Lexmark X4530 InkJet Printer
    HP 6200 without telling it to print, feeds and jams continually
    I already encounter that problem lately. when you print your documents, the only response of the printer is paper jam. feed and jam.
    try this tip if acceptable of your situation now.
    only to do is copy your documents by edit button and then select all or highlight all that your going to print and then right to copy
    and then, open a new documents page set up if needed.
    and then print it without saving your file because that already save.
    Dec 05, 2008 | HP Officejet 6200 All-In-One InkJet...
    Could you please tell me how to release paper jammed in a hp photosmart c3175 ALL IN ONE printer scanner copier,if I pull the paper it just tears away. Thank You . RAY WINCH. EMAIL...
    Clearing a paper jam from the rear door Follow the steps below to clear a paper jam through the rear door.
    1. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the unit. Figure 1: Removing the rear door c00652942.gif
    2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all of the pieces of paper from the unit, more paper jams are likely to occur.
    3. Replace the rear door. Gently push the door forward until it snaps into place.
    4. Press Cancel to continue the current job.
    Clearing a paper jam from the front door
    1. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door c00652943.gif
    2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all the pieces of paper from the unit, more paper jams are likely to occur.
    3. Close the print cartridge door. Figure 3: Closing the print cartridge door c00652944.gif
    4. Press Start Copy Black or Start Copy Color to continue the current job.
    Aug 06, 2008 | HP Office Equipment & Supplies
    Printer jam
    There is an easy fix for Lexmark E232 paper jams at the beginning of the paper path. This fix only works when the problem is that the paper starts to feed, but does not quite make it out of the paper tray.
    The problem is the pickup paper rollers. If you remove the paper tray and press down on the paper indicator (the red lever to the left of the paper tray) you can see the twin rollers attached to a spring loaded armature.
    Chances are these rollers are worn and are very smooth to the touch. This slick smooth surface does not have enough friction to push the paper up to the next roller.
    To fix this, remove both rollers, they slide off easily. Then simply turn both rollers inside out and replace them on the armature. Notice how much "stickier" they feel now? Chances are your paper jam problems are over, until the rollers wear out again.
    At that point you will have to replace them.
    Mar 30, 2007 | Lexmark E232 Laser Printer
    Lexmark X125 All-In-One InkJet Printer Logo
    96 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
