Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool fridgerator door
Can i replace the door cams at the bottom of my side by sides with regular plastic washers so the doors don't lock open? I want them to close by them selves.
  • 61 Answers
You can try it make shure there are now wires running thew this hing into the door .remoe the top hing plate or loosen it enough to swing it out of the way then lift the door off the bottom hing. good luck
Posted on Oct 06, 2008
My washer door is locked and will not open
unplug washer and remove bottom panel reach up r/h side of washer till you feel a ring pull ring door will open.
check drain pump if blocked door will not open at end of cycle
Aug 01, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool fridge door "drops" into place when opening.
are both door leveled? if not the door cam worn out and need replacement
Nov 23, 2017 | Whirlpool GSS30C6EYW 30 cu. ft....
Whirlpool dishwasher door falls open fast when opening. plastic part came off, but don't know where it is from
remove the bottom access covers on the bottom of dishwasher. turn on the dishwasher with water valve in off position so you can here the motor running,while its on, find the breaker and turn off power.you will here motor stop. disconnect power wires from power box on right hand side,then disconnect water line open the dishwasher door and at the top remove screws holding dishwasher in place. pull dishwasher out from bottom.you may have to adjust bottom adjustable screw legs. pull it out and check sides where springs are for the door to open and close. it may have came loose.
Feb 27, 2013 | Whirlpool Gold GU2275XTV Builtin...
Hi, my refrigerator door squeals very loud when you open it. The freezer side door does not make noise. I think it might be a washer at the bottom of the door, but I don't want to spray it with a...
You can try a silcone spray, that shouldnt damage any plastics or rubber. Also check the door seal. Make sure its clean. Sometimes, cordials, coke etc spill onto the door gasket and become all sticky which causes some wierd noises when you open the door.
Jul 26, 2011 | Admiral 26 cu. ft. Side-By-Side...
Door is locked, wont open
remove bottom acces panel 1/4 screw sometimes torx bit ubplug washer reach in on non hinge side against doorshould be door lock latch assymbley, bottom of latch assymbley is a round plastic end thats spring loaded ,pull downward and open door replace door lock assymbley
Jan 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do I take the door panel off of a 95 Ford F150 to replace the handle?
All there is is just screws around the outer sides of the door panel(3 on bottom). There is one located on the arm rest where the handle is. Then you need to take the screw out where you can lock your door and open your window ect... And just move the panel around until it comes off. You might have to pull the door opener out a little to get it through that hole.
Nov 02, 2010 | 1995 Ford F150 Styleside Regular Cab
Fridge door not closing properly
This section of this refrigerator door repair guide will walk you though repairing a refrigerator door on a side-by-side refrigerator. On most side-by-side refrigerators there is a cam that lifts the door up when you open the door so that the door has a tendency to fall down and back into place while it is closing. If the refrigerator has a cam and it is working properly, the refrigerator door will rise up when you open it and lower when you close it. If this cam is broken the door will not close properly. A lot of refrigerators have two cams, one screwed on the door and one on the hinge. You may have to replace the entire hinge to replace the lower cam but the cam on the door can always be replaced. You will have to order the cam by model number and can do so on this website AppliancePartsPros.com.
On side-by-side refrigerators without cams there will be a spacer on the door hinge. If this spacer is missing replace it. Note that any plastic spacer will work as long as it will go on the hinge pin and is not too thick. Never use a metal spacer because this will cause wear on the door and it will eventually squeal when closing.
As on top-freezers the door gasket may be ripped and if so refer to the bottom section that talks about door gasket replacement.
Sometimes the door can get warped out of shape. If the door is closing at the top and not at the bottom or vice versa the door may be warped out of shape. You can fix this by twisting the door back into shape. Take you foot and place it at the bottom and pull the door out at the top or place your foot inside the door at the bottom and push at the top with your hand depending on which way you need to twist the door. Note don’t over do it twist it a little and if it isn’t enough twist it a little more. If it gets worse you may need to twist the other way.
hope this helpout ......
Aug 12, 2010 | KitchenAid Superba Architect KSCS25INSS...
My door lock has locked with the door open , how do i get it to unlock ?
There is a manual unlocking tab located at the bottom of the door lock and switch assembly. Disconnect power to the washer before accessing it.
Remove the three screws attaching the toe panel to the cabinet then pull the panel down and off the cabinet. Prop up the bottom front edge of the washer or cushion and lean it against the wall for an easy access of the screws.
Reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side.
Locate the tear-drop shaped tab then gently pull it down until a click is heard, and then open the door.
The door lock and switch assembly may need to be replaced if the problem persists. Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening.
Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel.
Pull the door lock/latch assembly out of the washer and disconnect the wiring harness.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel.
Secure the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Jul 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The door won't open after the wash!
Hi. Kindly unplug the unit for five minutes. The will reset the main control unit, and may release the door lock as well. Once the five minutes have passed, simply plug back in the unit, and try to operate the unit normally. If this problem with the door lock still exist, the door lock mech will be the culprit. It should be replaced asap. Here is a manual unlock procedure that will help you open the door if the rest dose not release the lock.
First, you must unplug the machine.
Next, remove the lower front kick panel. You will need a star-head driver (six points), which you can get at your Sears store. It requires a fairly small unit. I used an interchangeable handle with swappable parts to match the right size head.
The three star-head screws are located along the bottom of the kick panel. If the washer is sitting on the optional pedestal, be sure to pull the drawer out before proceeding. Then unscrew each of the screws and place in a plastic bag to avoid losing them.
The front panel is now attached by pressure to the rest of the washer. Take a crowbar or any slim tool to pry open the panel. Cover the end with a thin paper towel to avoid scratching the paint on the washer, insert the thin end low in the gap between the washer and the panel, and gently twist until the side pops off. Do both sides.
Once the panel has been removed, look to the right on the side of the inner wall of the washer. There you will find the lost manual pages intended to help the tech interpret error code and fix conditions. It also contains instructions on how to (((UNLOCK THE DOOR))). Take the manual pages out from behind the plastic envelope (they are taped and sealed, be careful not to tear them) and put them with the rest of the user manual, where they belong.
You can now see the inside of the washer. Look up in the inside where the latch for the door closes. You will see a small plastic black box. Pull the bottom end straight down. Then, open the door.
Dec 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Refrigerator door stays open.
Sears came out and repaired my door with this same problem. It was a pretty easy fix. There is a small black part that the door rests on. It just was worn out. The repairman simply unscrewed the door from the top of the refrigerator. He lift the door off. The door normally rest on a black round circular plastic part about 1 in in diameter. It has a small plastic piece sticking up about 1/2 inch that the door rests on. This piece was worn on bottom. I have the Sears invoice and I bought a replacement bin for the door and I don't know which item is for the black plastic piece. Here are both part numbers so call Sears and order the correct part
CAM-DOOR 46 106 4318165 1 or $14.83
SUB TRIM-DOO 46 106 2156022K 1 $12.48
It took the Sear's guy about 10 minutes to repair. So save yourself $200 and do it yourself.
There is a picture of the part in the Whirlpool Manual, under Door Removal, look at the bottom hinge.
Email me if you need another picture.
lcbeaty2004@yahoo.com
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
74 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
