SOURCE: Need help with DACOR Microwave model PCOR30S, w/the minute timer
This
is a problem in one of the damper-related components, most likely the
switch, but it may also be the motor or the damper door.
The
damper is a door inside that opens or closes depending on cooking mode.
If the controller senses that the door is not in the right position, it
will shut down the cook cycle.
Sharp models (and Sharp models made for Dacor) stop after
59 seconds.
See the attached sample
photo for a typical damper assembly.
We have a very close service manual and have uploaded it to our site here to help you.
You will
need the free
Adobe Reader
to view or print it.
If a switch is all you
need, we offer a universal type for only $5 postpaid which you can
order here.
If your model is PCOR30, and you need a new motor, the part number is 66756 and you can order it here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: Dacor PMOR 3021S Microwave -
Hello there and thank you for choosing fixya
there may be a few reasons why this is happening but the most common issue with these is the internal fuse that is on the control board these do blow out over time and expecially if you have a power surge or a loss of power in the home
The repair for this is taking the outer cover off then on the right side as you are facing it there should be a control the fuse is located there now simply replace if blown ok?
if the fuse is good and you are 100% sure of this then you have a bigger problem which could be the power inverter (power supply ) these do go out but not as much
Also if the door switch is bad the unit will not run also ok so you will want to check this too ok?
if you need any further assistance feel free to contact be by posting me a comment here at fixya under your problem section ok?
Best regards mike
SOURCE: My Dacor PCOR30 only works 58-59 seconds at a
Not likely.
This
is a problem in one of the damper-related components, either the switch
or motor or the damper door may be binding.
The
Dacor-branded PCOR30-series microwaves are just cosmetically altered versions of the Sharp R1870-series ovens.
These Sharp-made models stop after
59 seconds when there's damper toruble.
drawing below for a typical damper assembly.
We have the applicable
service manuals for the Sharp models and have uploaded it to our site here and here to help you in disassembling and troubleshooting your Dacor version.
You can find the Dacor PCOR parts list here and you can order Dacor parts by part number here.
need, we offer a universal type for only $7.50 postpaid which you can
order here.
We're
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
