Question about Garmin GPSMAP 180 GPS Receiver
Internal Battery Low
I have a Garmin GPSMAP 180 and when I turn it on, the unit says that the internal battery is low. I lose all my saved waypoints. Can the internal battery be replaced easily by me with limited repair skills, and if so, what kind of battery do I need to purchase.
Thanks for any advise
Same problem. Remove the 8 screws, unsolder the battery from the circuit board, pry off leads, place electrical tape around edge of new battery, solder on the leads, solder leades on circuit board. Remember which side was up before soldier, close unit, you should be good to go.
Posted on Jun 19, 2009
Even after changing internal memory battery with the specified battery I still loses the memory.What am I doing wrong.
Posted on Aug 25, 2009
    Problem Solver:
  • 5 Answers
Georgevb., Had the same problem, called Garmin, they no longer support 180.
Did tell me the battery is a Panasonic BR2032-1F2 or equivalent.
Also said case was heat sealed so I took mine to an electronics repair shop.
Seadrive Joe
Posted on Aug 29, 2008
GPSmap 296 doesn't show any satellite signal
Check that the date shown on the unit is correct. If not, choose autolocate and allow about 10 minutes for the unit to find satellites. If this works, then the internal lithium ion battery is defective.
Jun 02, 2010 | Garmin GPSMAP 295 GPS Receiver
Gpsmap 180 firmware corrupt
It sounds like it has lost its memory battery. Usually you
would get a "memory battery low" message as it is on its
way out but you don't mention that so perhaps it has
completely failed.
The battery is rechargeable - if you leave it switched off
and loaded with a fresh set of alkalines for a few days it
may recover. If not contact Garmin as they have replaced
many memory batteries free of charge even out of warranty.
Oct 30, 2007 | Garmin GPSMAP 430 GPS Receiver
Garmin gps 12 loss of data
I had the same thing happen. The problem is that the internal lithium battery is shot. Solution: phone Garmin at 1-800-800-1020 x 2,2,1. You send the receiver in along with a $42.41 check. They will probably replace the unit. They will explain exact procedures when you call.
Hope this helps.
Joan
Jan 04, 2010 | Garmin GPS 12 GPS Receiver
Data cards for Fununo 1850w
Furuno just stopped producing these models about a year ago. They use a special chart card. You can still purchase the cards from Navionics or C-map if you need to. I will tell you from experience that you should get your internal battery changed out if you havent done so already to keep from losing your settings and waypoints. The dealer will have to save them for you though and put them back on. Furuno made a GP7000 to replace this one and it's uses SDcards and is nothing like the rest of Furuno's product line. The best replacement for this unit is the Garmin GPSMAP 700 series. You can use your old furuno transducer if you have one (with an adapter plug). This garmin unit also has a built in GPS or you can use an external one. The 700 series will be shipped in April. Check out Garmin's website or mid-shore electronics.
Aug 29, 2009 | Furuno 1850w/Nt Gps Chartplotter C Map Nt...
GARMIN 60CX Contour Map display: Sent maps to unit OK. Then was able to display a WayPoint with its contours. However... later, now able to display WayPoint but NOT surrounding contours. The Map IS...
The topo maps are low in the map hierarchy. If another mapset is loaded at the same time and is also checked it will likely "cover" topo. I think the Recreation maps are the only one's lower in the hierarchy.
Jul 06, 2009 | Garmin Gpsmap 60cx Handheld Gps
Batteries last only 20 minutes?
NiMH batteries work on less voltage than Alkaline batteries, so the unit thinks the batteries are low when they are just the wrong type, put Alkaline batteries in {and turn off the backlight if possible} and you will get your 8 hours of use.
Jan 21, 2009 | Garmin GPSMAP 176C GPS Receiver
Acquiring satellites
Garmin has a history of internal rechargeable battery problems that go back at least as far as the GPS III Plus. There is a button cell battery in the GPS III that is used to help it "remember" where to search for satellites (according to their tech department). It was supposed to have a 10 year life, but mine failed after 6 and they would not repair the unit. The unit would eventually operate, but as soon as power was turned off, it would lose all routes, waypoints, etc. That is not my idea of a good deal.
The 276C has a similar problem; if you leave it off of the charger for more than a day or so, the MAIN battery is fine, but the unit will not find satellites. There is a software fix for this if you have an older unit but it really doesnt fix it; the fix simply forces the unit into a mode that says "STORED WITHOUT BATTERIES" which is a misnomer; my batteries were in and charged, but I think what they meant is - the internal battery bit it.
If you reset the unit by holding the POWER button and the ZOOM OUT BUTTON at the same time, the entry screen will pop up. Accept the conditions and the unit will attempt to power up. I have had mixed success with this technique. The BEST technique is to LEAVE THE UNIT ON THE CHARGER at all times when it is not in use!!!!
Also go to their site and make sure that you have the latest software 5.4 and save your waypoints, tracks, etc., before you download the new software.
Mr. EE PE
Jun 23, 2008 | Garmin GPS
Garmin 180
You need to replace the internal Battery with the Panasonic BR2032-1F2 battery. However, yes your waypoints will most likely get lost when you do this.
May 07, 2008 | Garmin GPSMAP 180 GPS Receiver
Waypoints and nav log
Based on your description I would suspect that the internal memory battery is depleted and needs to be replaced. This battery is required to retain waypoint and route information when the input power is low or turned off. The battery is soldered onto the main circuit board and needs to be replaced by a technician having good soldering skills and access to instructions for the disassembly and reassembly of the unit. There is a list of dealers on the Northstar website. Review the list and make a couple of phone calls to see which ones will do bench work on this unit.
Mar 23, 2008 | Northstar 951XW GPS Receiver
GPS screen went blank
My problem exactly. Unit would start up, acquire satellites, then the screen would go blank with a single vertical line. Unit would not respond to buttons or even turn off. Unit works fine after I did the reset:
- w/unit OFF, press and hold QUIT+DOWN+MENU
- press and release the power button, release DOWN, keep holding QUIT+MENU for 5 seconds.
- unit prompts something like: "erase all data;" choose yes.
- you will lose waypoints, etc.
Go to the Garmin support area for details.
http://www.garmin.com/garmin/cms/site/us/support/searchsupport
Search for: "How do I reset my gpsmap 76"
Oct 06, 2007 | Garmin GPSMAP 76 GPS Receiver
Garmin GPSMAP 180 GPS Receiver Logo
1,401 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
