Question about Acer Aspire™ T180 PC Desktop
Yahoo voice says audio input already being used
  • 133 Answers
If you are using an integrated sound card you will want to check the way the inputs are configured as some integrated sound jacks share more then one function on the same jack.
Posted on Aug 16, 2008
"no input from your microphon
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
Feb 11, 2011 | Computers & Internet
I have an alpine cda9831 unit with 10" subs. I have an alpine v power m500 independently running them. The subs will randomly cut off and on and the wires to the head unit have been checked for loose...
so you have already ensured that there are no crossed/loose wire strands.
you are running 2 subs off a single alpine mono amp.
if subs are 4 ohms apiece, you should be fine. if you have 2 ohm subs, or you have dual voice coil subs and you are running all the voice coils parallel, then there is your problem. you can have a maximum of a 2 ohm (2x4 ohm speakers= 2 ohms.) load with that amp.
ensure that the subs are 4 ohms apiece, and that you are not using dual voice coils. if the subs have 2 inputs (dual voice coils) then only use 1 input apiece.
if this is already taken care of, then your amp is defective.
Nov 06, 2010 | Car Audio & Video
Yahoo voice call not working
Make sure ur mic settings are configured properly.
Open Yahoo Messenger Window, goto Actions > Call Setup as seen below:
Now follow the step by step instructions, and select the input and output source from the drop down menu on the setup screen until the microphone and speakers are working properly with this wizard.
Yahoo Audio Prefernces
Go to yahoo messenger main window , Messenger > Preferences > Calling & Audio
In this setup, select the microphone input from the dropdown, and similarly the speaker settings.
After selecting the proper input and output, the voice char worked just fine with me. Hope it helps you solve your problem.
Aug 26, 2010 | Yahoo Messenger
Realteck mic problem
Well, if it's working when you record sound, then there might be settings related problem with the skype or yahoo messenger etc... Let's get started with the "skype" open your skype - sign in - click on "tools" select "options", on the left pane of the options windows, click "audio settings" and now on the right pane, check the "microphone" settings and verify it's set to "Realtek High Definition Audio", if it's not, do so now. click "Save". You can set the volume manually by uncheking the "automatically adjust microphone settings" and turn up the volume slider. Do the same with the yahoo messenger, but you can't set this before you log in. In yahoo messenger you need to go to the "preferences" - "Video and Voice" from the "Messenger" menu. Also make sure, that "digital input or output" isn't selected.
Good luck. Thanks for using FixYa.
Jun 06, 2010 | MSI K9N6SGM-V Motherboard
Hi we are the user of dvx102b we are having a big problem with audio when we are in room with DJ sound THE audio sound are crack .we are use ALC Accroding to the book we adjust the audio manualy but no...
Dec 24, 2009 | Panasonic AG-DVX102AE DV Digital Camcorder
No voice chat in Yahoomessenger
open controller panel to the left click on classic view--if already on classic view the open the "sound" icon click the record tab look for the logitech mic -right click and set as default-reboot the pc and log into yahoo again and try the sound. if no logitech mic is detected under the record tab then headset may not loaded correctly check the device manager for any device that is not loaded.
right click and update it.
Jul 22, 2009 | Logitech 250 Headset
Yahoo Messenger 9.0 Voice Chat Drops
Normal 0 Also send this to your family and friends so they have their computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
Yahoo Setup:
After downloading and installing Yahoo Messenger ( ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hope this helps. Bud
Jun 10, 2009 | Yahoo Messenger
Yahoo messanger voice service is not working
Dont use yahoo messenger for ACER ASPIRE ONE not compatible, I suggest use SKYPE messenger text chat, video and voice call as well work great.
Yahoo messenger work only video and text chat only but voice call not work.
Skype messenger works video and voice call works perfectly.
Nov 23, 2008 | Yahoo Messenger
Trouble with yahoo voice
you need to ports on your router for each computer that uses the yahoo messenger service to talk. the built in firewall is blocking the service and thats why you lose connection when you try to use voice communications. also check out this link for more help - - hope this helps you.
Sep 18, 2007 | D-Link DI 514 Wireless Router (DI-514)
Vista and yahoo voice compatability
I had the same problem(s) with Vista and Yahoo Chat. I ended up with a simple workaround that doesn't involve downloading codecs etc., from 'suspicious' places, that may or may not work with your particular flavor of Vista..
First, go here: and get the newest Yahoo Messenger 9.
Then go into a Yahoo Chat room. (I'd suggest one of the romance ones as there are usually quite a few attention strarved women and desperate men chatting away on mics.) When you click on the "Voice" button, you'll probably see this,
"this computer does not appear to have input, or it is not configured correctly" (which doesn't seem a whole lot better than the original compression issues,) BUT, all you have to do is plug in a microphone and everything works just tickety-boo. If you don't have a mic, just plug some headphones INTO the INPUT for the mic. You'll still hear everything just fine through your speakers.
It's not an ideal solution but unless someone out there remembers more than I do about their days as a 'sound guy' for local bands, it shouldn't do any harm.
Good luck.
Aug 29, 2007 | Logitech 250 Headset
Acer Aspire™ T180 PC Desktop Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
