Question about Panasonic KX-T7630 Corded Phone
Main line not recieving calls
Our main phone line has been crackling for the past week or so. Then yesterday we stopped recieving calls from the main line. There is a dial tone from line one and I can call out but when someone calls in it rings out on there end but we recieve nothing. I spoke to telstra and they have tested the line and explained there is nothing wrong with the line but something wrong with the phone internally. Can you please explain what I can do.
  • Panasonic Master
  • 2,460 Answers
I don't know what a telstra is, but I'd be looking at the demarc to see if I could swap the lines 1 & 2. "There is nothing wrong with the line" is a stock answer from the telco. The fact that you can call out and not receive calls tends to make me think they're lying.
Carl
Posted on Aug 24, 2008
Really bad crackling sound on certain calls
if only happens on certain calls it could either be the handset itself, a week point on all corded phones is the cable between the handset and the body of the phone. whilst talking to someone on a call wiggle the cord where it enters the handset, does it crackle if not do the same where the cord enters the phone body, if no crackle likely not phone.
next select a line if you have more than 1 line note which 1 and dial 17070. this will BT autotest the line. if more than 1 line on system do same for all lines. check with your system admin if there are quick codes to select individual lines, eg dial 9 for any line or 81 for line 1 82 for line 2 etc .
if you get crackle still on 1 of the lines get your maintainer to check the lione at the cable head where lines enter building
Mar 02, 2015 | Panasonic KX-T7731 Corded Phone
I have crackling on my phone line when I make or recieve a call. The phone is new and a cordless model. Can you recomend any solutions Thanks
do you have broadband on the same line as the phone? does the broadband have filters connected to the line at the AP. Is the phone positioned beside any other electronics in the house such as microwave, tv, radio, baby monitor, washing machine, if so i suggest moving it to a more reasonable location where there are no electronics to interfere with the signal.
if crackling continues leave item back to store.
May 31, 2011 | Panasonic Lands Phones
Our fax machine is receiving faxes but won't send them. It says poor line condition. I've switched the actual line with another & it still says the same thing.
Sounds like you hve "noise" on the phone line you are using. Try plugging a normal phone into the line socket you are using for faxing, then pick up the reciever to make a call. If you hear crackling then the line is noisy and you need your phone service provider to repair the line. If you dont hear crackling try using another line lead.
Mar 04, 2010 | Brother Multi-Function Center MFC-240C...
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
Stop ringing at main phones when outside calls come in.
Here is a link to program line ringing.
It sounds like your extension is forwarded (confirmed by the one beep you hear on an incoming call.
From any display phone, press Feature 11
then enter your extension number 2 times. So if you are extension 20, do this:
Feature11-20-20
see if that does it.
May 28, 2009 | Lucent PARTNER18 Corded Phone
CAN RECIEVE CALLS CAN NOT DIAL OUT HAVE ONE OF THOSE CORDLESS PHONES ONE MAIN BASE AND TWO SUBSTATIONS AND NO PHONE SERVICE INTO THE HOUSE GE 21518EE1 Bluetooth Cell Fusion Gateway
You have to dial #1#PHONENUMBER# if you have your cell paired to the 1st line or #2# if you have it paired to the 2nd one to call out on these boxes. I have a problem receiving calls with the bluetooth cycling and dropping the call, no problems dialing out though.
Apr 07, 2009 | Lands Phones
Can't fax from my HP Laserjet m2727nf.
Check the phone line with a regular phone.
Make sure you are plugged into the LINE port of the fax.
Dec 08, 2008 | Xerox WorkCentre Pro 785 Plain Paper Laser...
Panasonic SC-PT950 Wireless Speakers Question
It is pairing process again.
Inside the Main set operating instruction can help you solve it.
Aug 13, 2008 | Panasonic Home Theater System System
Crackling Sound
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Jan 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Panasonic KX-T7630 Corded Phone Logo
181 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
