When using ethernet connection with wireless router rate is 100 mbps but when I use linksys 2.4 usb wireless adapter ( to get rid of the ehthernet cable lying on the floor)rate is now 54 mbps? Is this the max transfer rate I can get with this adapter?
  • stewartchris Aug 14, 2008
    Thanks for the help - I purchased a longer ethernet cable.
    Problem Solver:
  • 14 Answers
By the sounds of it the router is Wireless-G standard. This has a theoretical max speed of 54Mbps. If you wish to increase wireless speeds you would need to upgrade to Wireless-N standard. Do would need to change the wireless in the pc or laptop also. This should give a theoretical max speed of 100Mbps.
Ethernet cable will be cheaper!
Posted on Aug 14, 2008
I am only getting 34-54 Mbps with my Linksys. I have a wireless adapter in my computer. It will go lower, but never than higher than 54 Mbps? I know i can get 100mbps because my Xbox does. Help me out!
Wireless Ethernet (802.11a or b or g) does not get the bandwidth you would get through a cabled connection. My guess is that you have an 802.11g network card in your computer and 54 Mbps is the top theoretical speed for that type of Wireless adapter. Cabled connections will give you the theoretical throughput of 100 Mbps. Also, since this Linksys device is not a Wireless access point but simply a switch, your computer doesn't actually connect to it. Most likely you are connecting to your cable or DSL modem. Most of these have a wireless radio built in.
Oct 15, 2010 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
54 mbps PCI Adapter Card limits my connection to 2 mbps
Wi if is the slowest form of connection and is shared with other devices. If you want good bandwidth you need to connect via ethernet cable directly to the router.
Examlpe... wi if 4 meg shared, Ethernet 100 meg..
good luck !
Mar 30, 2017 | NetGear WG311 (0060449028409) Wireless...
Use 2 wire to run laptop
Yes you can use the laptop with this router because this is a wireless router.
Details of the router are:-
Manufacturer: 2wire Product MPN MPN 1000-400108-001 Key Features Router Functionalities dtrquestion.gif Wireless Access Point • DSL Modem • Firewall • DHCP Server Connectivity Wireless Interfaces Built-In 4-port Built-In Switch LAN Interfaces 10/100 Base-T Additional Interfaces 1 x USB Standards and Protocols LAN Standards IEEE 802.3 CSMA/CD or Ethernet • IEEE 802.3u 100 Mbps (Fast Ethernet) Protocols dtrquestion.gif AAL5 • ARP • ATM • DHCP • ICMP • IP • PPPoA • PPPoE • TCP • UDP Remote Management Protocol dtrquestion.gif SNMP • HTTP Firewall / VPN Firewall Features Stateful Packet Inspection (SPI) • NAT VPN Protocols IPSec Pass-Thru • PPTP Pass-Thru • L2TP Pass-Thru Authentication CHAP Wireless WLAN Standards IEEE 802.11b 802.11b Data Rates 11 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps Modulation dtrquestion.gif CCK • DBPSK • DQPSK • DSSS Security dtrquestion.gif WEP Antenna Type dtrquestion.gif Internal / Integrated Antenna x 3 Modem DSL Standards ADSL Lite (G.Lite ITU G.992.2) Other Features LED Indicators Power • DSL • Link Additional Features Auto Crossover (MDI/MDI-X) Dimensions Width 2 in. Depth 10 in. Height 8 in. Weight 1.4 lb. Miscellaneous Release Date December, 2003
May 03, 2010 | 2wire (1000-400108-001) Router
Can only get a 10 meg when connected via cable to srx 200
The speed of your wireless adapter maybe up to 54 Mpbs only, check the wireless adapter that you have if it is 802.11 G its set to 54 Mbps only however if your using 802.11 N the speed of the adapter is around 300 mbps of connection.
There's a settings on the router that you can lock WAN port speed to around 10/100/1000
Note: To have a 300 Mbps of connection you should set the wireless settings of the router to WPA2 and AES with bandwidth of auto 20/40
Mar 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Broken Ethernet Port
You say "your Ethernet Port" (= LAN port)
If unavailable try using any USB to rj45 adapter and you can use any USP port.
Check this device:Linksys - USB200M - Compact USB 2.0 10/100 Network Adapter (20 $?) or similar
Dec 28, 2008 | Linksys Wireless-G Broadband Router
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
Can't get to internet anymore
Try to remove the preferred networks on your Presario then try connecting again. If you have wireless security enabled on your router, you have to enter that. Make sure that the settings on your router is the same as your wireless adapter so that they can synchronize.
If you have difficulty with that, just ask me and I'll answer as soon as I can.
Apr 28, 2008 | D-Link Platinum RangeBooster N DWA-642...
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
