When I ran my dishwasher tonight it ran for 3 hours and was still not down running. Is this normal? It seems as though that is an awful long time for it to run. Pervious owners did not leave manual. What can I do to fix this problem?
Are you using the high wash temp setting? I was having the same problem with my dishwasher while using that setting. Apparently, it will run until the temp gets to its required number. And my hot water heater was set to not go that far. So my dishwasher would run and run. I fixed it by not using that setting any more.
It also helps to run the tap water at the sink until it is hot, then the dishwasher will fill with hot water and will not need to heat it much. Most dishwsahers water supply line comes off the tap water for the kitchen sink. Also make sure hot water heater is set to at least 120. hope this helps.
my model is FDB1050RES. It will finish but it takes 3 hours it doesn't have a water heater I make sure the water is hot hot hot
