Question about Linksys Wireless-G WRT54G Router
How to set up router with a lap top
The instructions explain how to set up the wireless router and keeping a cord plugged into the comptuer. I want to be able to use my lap top in another room. My cable box has ethernet, usb and a place for 2 phone lines.
router wrt54g2v1
Erin
  • erindoyle63 Aug 14, 2008
    there isn't instructions on how to set up the wireless with a laptop in the manual.
  • Linksys Master
  • 6,487 Answers
After you setup the wireless router like for the internet connection and other settings including the wireless settings of it, you can go to your laptop make sure that your laptop has a wireless card/adapter that is use to connect to wireless network which your router will be broadcasting , then just select the wireless name of it for linksys router the default wireless name or SSID is linksys..
Hope that helps.......
Posted on Aug 14, 2008
  • Mark Gil
    Mark Gil Aug 14, 2008
    It will be easy for you to setup the laptop wirelessly just first make sure that the laptop has a wireless capability..
  • 13,433 Answers
The manual should also cover the wireless steps. You need a wireless adapter on the laptop, directly out from the box the router should work, just plug and play, but it is unsecured meaning anyone can use your wireless network.
the wireless router is connected with a cord to the cable box. make sure you plug it into the right spot behind the wireless router.
    Genius:
  • 1,689 Answers
Well you will have to setup the router to run on ethernet, perform a mac clone for your cable modem then setup the wireless.
  • 2 more comments
  • marlon john madrid
    marlon john madrid Aug 14, 2008
    Step 1:
    Access the router’s web-based setup page. For instructions, click here.
    NOTE: If you are using Mac to access the router’s web-based setup page, click here.
    Step 2:
    When the router’s web-based setup page appears, click the drop-down arrow under the Internet Connection Type field and select Automatic Configuration - DHCP.
    Step 3: Save settings
    Step 4:
    Click MAC Address Clone.
    Step 5:
    Select Enable and click Clone Your PC’s MAC.
    Step 6: Hit save settings.
    you may perform a power cycle to make sure the modem will sync with the router.
    the wireless part.
    go back to the setup page, then go to the "wireless tab", change your wireless network name or the SSID to any name you wanna call your network, set your channel to 11 then hit save settings.
    after saving locate the subtab that says wireless security, enable it using WPA personal, set the algorithm to TKIP then make up a password and type it to the space for Pre Shared Key / passphrase, then hit save settings.
    to set the connection to your computer remove the ethernet connection and then enable the wireless adapter in your computer, if you have XP or Vista, it will say that it has found a wireless network in range, just click on the message and it will ask you for the security key once you try to connect to the network you created. and thats it, if you have other questions just let us know.
    oh yeah, power cycling by the way is removing the power from the modem and the router, then power up the modemr FIRST, wait for it to be stable (or the online light solid) then power the router up next.
    if you have IBM or lenovo, the wireless switch is usually infront of the laptop, it will have a wireless antenna icon right on top of the wireless TOGGLE switch. if you have dell, press FN and F2 on your keyboard to ruen it on, for HP compaq and toshiba, you may look for the wireless button on the upper part of the keyboard on the both side of the machine. acer usually has it ont he left side of the keyboard, or beside tje speakers. this is if you have a laptop
How can I assign IP of my access point Dlink DAP-1150 on my lap top. I want to add adapter network DAP-1150 on my pc
there are 3 ways of setting it up as an Access Point, Wireless Client, Wireless Repeater mode. Would be easier if you explain what you want to use it as?
Choose what you want to use it as, you can set it up plugged into the router or over the wireless , so just plug it into your router and follow the instructions in the manual, you will then be able to unplug it and it will automatically connect to the router over the wifi. manual can be found here ftp://ftp.dlinkla.com/pub/drivers/DAP-1150/DAP-1150_A1_Manual_1.10%28B%29.pdf
Jul 12, 2014 | Samsung R540 Laptop
Hi do you know how I can connect my lap top to the internet wireless with my linksys wireless router ? the lap top asks for an access code and I do not know what it is or how to find it do you know how to...
The access code or password is the encryption key in your wireless router, without this key the wireless router won't allow the laptop/computer to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer/laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dec 27, 2010 | Linksys Wireless-G Broadband Router
I want to connect my lap top to a wireless Netgear
You need to do exactly that.
From your web browser type in 192.168.0.1 put in you user name and password.
Your control panel will come up then you got to wireless settings and turn it on and set a Wep key, write that down then rebboot the router or save the settings.
go to your lappy now and open up your wireless card on the tak bar and search for your netgear click on it then enter that key, You should be good.
Thanks please do leave ratings for all the tech involed in your case, thanks
Jun 12, 2010 | NetGear RangeMax WPN824 Router
I purchased a D Link (Model # DIR 601) along with a Retail Plus USB Adapter. My router was set up so that I could bring it home and plug it in. I was not supposed to have any issues with it. My Lap top is...
check to see if your wireless connection is on on your laptop and set to work with your router - check to see if your laptop's wireless signal is b/g/n - if it's only an "n" - and your router is a b/g - then you will need to purchase an "n" class router...
normally, routers do not "just work without issues" when you bring it home and plug it in - it should have come with a setup disk or instruction guide - have you completed the steps to connect?
Feb 17, 2010 | D-Link DGL-4500 Wireless Router
No Internet via zoom X6 wireless router to desk top, lap top ok.
Access your zoom router by using the laptop which still has access to the router.
Your going to have to open your Wireless Network Connection Status window located under your network settings.
If you see this window your going to left click the (details) button
Now you should see a IP DNS server address
for example: 192.168.1.xxx
Type that address onto the address bar of your web browser.
it should take you to your router setup page.
There you will need to check if the lan port is enabled
Feb 04, 2010 | Zoom X6 Adsl Modem/router Rohs...
When i unplug lap top lose enternet conection
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Jan 23, 2010 | NetGear DG834 Router
Net gear box won't connect wirelessly with my lap
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 20, 2010 | NetGear WGR614 Wireless Router
Cannot install D-Link router
1. check your wireless adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 just check the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
Hope this will help
Nov 24, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Laptop wireless hook up
I just got your messages, looking at the details of your laptop it has a build in wireless so as you have noticed since its working now, you won't need to purchase a adapter for the laptop since it already has one build in.
Let me know if you need assistance with anything else.
Aug 14, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
91 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
