Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Re: I art jvc
I have a 48 wide screen jvc. the picture seems to have a red shadow. where van i get the part?
  • JVC Master
  • 8,617 Answers
You can get the convergence repair kit to fix your model JVc at the following link look under the convergence repair kit category, they provide free step by step instructions with pictures so you can easially do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 14, 2008
My JVC wont converge the red lines so half my screen is good while the other has red lines. What should I do? Thanks A lot
The tv 100% have a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors picture shadows or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | JVC AV-48WP30 48" Rear Projection...
Hitachi50dx10b Red And Green lines
You problem can be your vertical controll circuit, horizontal control circuit and your filter capicators, to figure out which one you will need an on the spot tech.. I'd recommend if you got limited knowledge of electronics you get a tech cause these things can carry hight voltage even when not plugged in.
Jan 23, 2008 | JVC AV-48WP30 48" Rear Projection...
On our JVC AV-48WP30 48in, red shadows
some how the convergence ckt went bad,common problem to pj televisions.
Mar 19, 2010 | JVC AV-48WP30 48" Rear Projection...
Red shadows in 48" JVC rear projection
Well you better be pretty handy with a soldering iron. The convergence output IC's need to be replaced. These are large plastic pack IC's with 18 or so pins that are soldered on the underside of the circuit board. These IC's are mounted to large metal heat sinks.
Jun 17, 2009 | JVC AV-48WP30 48" Rear Projection...
Pictures have a green shadow on all images
Remove front grill and chip board ,there are three knobs one is for brightness I think another for a sharper picture (best to use while convergance adjustment and the third which should balance your
black or white screen to have blue,red, or green tinge ,you like to have it as neutraul as possable.
if you are stll getting everything in blue,green or b-52 agua marine ,your red lamp may be burnt out!.
Feb 05, 2009 | JVC AV-48WP74 48" Rear Projection...
JVC 48 in rear
Probably the projection guns (my JVC had them fail on me). It started that way and eventually I had a triple image of what was on TV, one in red, one blue, one yellow, and all slightly offset from each other. The fix was new projection guns (thankfully it was under warranty as they were about $300 each).
Aug 08, 2008 | JVC AV-48WP30 48" Rear Projection...
Red bending lines shadowing all other correct parts of the picture
you can get the convergence repair kit to fix your model JVc at the following link look under the convergence repair kit category, they provide free step by step instructions with pictures so you can easially do the repair yourself. heres the link.
Aug 03, 2008 | JVC AV-48WP74 48" Rear Projection...
Jvc floor model Tv
I have a 54inch jvc floor model with no sound and it will show a picture then the picture goes out and power button flashes red, can this problem be fixed
Jun 06, 2008 | JVC AV-48WP74 48" Rear Projection...
Red Convergence on JVC AV- 65WP74
have pts rebuild the board which will cost around $130, www.ptscorp.com, or replace the stk392-110 x 2 located on the convergence panel.
Dec 08, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
453 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
