Question about Kodak EasyShare C713 Digital Camera
EasyShare Screen is blank
My daughter's Factory Reconiditioned camera that she bought about a month ago is not working. Once it is turned on, with brand new batteries, the screen is blank except for a few vertical lines running on the left side of the viewer. Any help?
Miss Mac
SOURCE: Blank white screen
same problem unable to take pictures or anything
Posted on May 30, 2008
SOURCE: Kodak Easyshare CX7530 won't stay powered on
SOLUTION: Fot the past two years, fully charged NiMH and new alkaline (generic and fresh Name Brand batteries) in my CX7530 always gave a red light and immediate power off -- symptoms of low batteries. Today I tried it again with the same problem. This time, I folded up a small piece of stiff paper to depress the small Lithium battery module detect switch in the battery compartment, and put my NiMH batteries back in -- it WORKED for the first time in two years! After removing the paper and reinserting the batteries, it still works. I suspect this somehow recalibrates the low battery detect circuit. I hope it helps you as well.
Posted on Feb 10, 2009
leecom72
  • 4806 Answers
SOURCE: I bought my Kodak Easyshare C310 a few years ago
Hi there
Check to make sure the cards write protect is off, take the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg . Put it back in the camera and use the menu to format the card.
If the format fails then its a possibility that you will need a new card.
Good luck and thanks for choosing FixYa!!
Posted on Jun 08, 2009
leepania
  • 1099 Answers
SOURCE: My kodak easyshare V1003 camera will not turn on.
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Dec 09, 2009
  • 11967 Answers
SOURCE: Lens Error 117..
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 07, 2010
How do i fix a cracked screen on a kodak easyshare m575,its cracked an when turned on the screen is black an the lens barely comes out.
This is one of those bad luck unfortunate solutions where I had our daughter do the same thing to our Sony. So I found out then that there was better to replace than try to have fixed. Even laptops if under warranty and you spill water into the keyboard the factory will not honor the warranty. So to make this story short I replaced the camera with a Sony Cyber-Shot 12.1 Megapixels. Also has High Definition Video 720P. Wish I had better news but our daughter cannot get the camera now and I keep hidden and inside a padded case! These cameras are like crystal and very easy to break and more expensive to repair. Thanks, Sea Breeze
Oct 13, 2011 | Kodak EasyShare M575 Digital Camera
My Kodak EasyShare C142 keeps telling me that it cannot read the 2G memory card. I have had the same memory card since I bought the camera new 2 months ago I just took pics with it 2 days ago and when I...
The card may have become corrupted. Use a separate card reader and download any pictures from the card. Then, insert it into the camera, go into the menu and find "format"...follow the on-screen instructions.
Oct 08, 2010 | Kodak EasyShare C142 Digital Camera
Bought a Kodak M340 about 6 months ago and it's been great. However, this time that I tried to charge it....it will NOT charge! When I plug it in, it flashes green once, then red three times, then nothing....
Hi , if your camera wont turn on with the power pack
you may try another one or battery that you no they are full charged, probly your battery charger is dead
if that not works you may have a problem whit your camera
hope that help
good luck
Mar 13, 2010 | Kodak EASYSHARE M340 Digital Camera
Screen blank
Do you have the Lens cap off ? Just asking.
Dec 27, 2008 | Kodak Easyshare C813 Digital Camera
Camera lens error
i need help. i have the same problem. i had my kodak easyshare 853 for about 4 days and it turns on saying kodak easyshare and then it just has a blank screen and turns off by itself. please help. and yes my screen is tilted sorta. but im havin a hard time getting it to go back in place.
Mar 29, 2008 | Kodak EasyShare C513 Digital Camera
Black viewing screen and blank pictures
Luckyfourme,
Check to see that the automatic lens protector is opening and/or off when you experience black screen, as it should open letting light in when you power up the Kodak easyshare camera.
Good luck and Congratulations on your Daughters upcoming Wedding!
Mar 10, 2008 | Kodak EasyShare DX4530 Digital Camera
A White Screen!
I had the same problem a few months ago. Best bet is take it to get it fixed. If you still have a warrantey it won't cost you a thing. Good luck!
Feb 29, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
Wont always power on, also doesnt auto focus
we have the same problem.....just started today...on a vacation trip...go figure!?
Can anyone help us here?
Jun 04, 2007 | Konica Minolta DiMAGE Z20 Digital Camera
Pink screen
Back to store or maker with it. Check out the makers Tech support site but this needs a new camera replacement.
May 16, 2007 | Kodak EasyShare C643 Digital Camera
Kodak EasyShare C713 Digital Camera Logo
99 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
