Sounds like you're having a problem with your Power TakeOff system. The first thing to do is check to see if you didn't bump the PTO switch on your dash. Since you were in tall grass, check to see that there is nothing obstructing your machine.
If all appears OK, then the PTO should be tested. This is an electrical problem and requires a multimeter.
Before you test, check your battery to see if it's charged and that the terminals are clean.
For information on testing the PTO system, I'm pasting a web address with detailed instructions: >>>> http://www.ehow.com/how_7725472_troubleshoot-pto-system-john-deere.html
Copy and paste this link into your browser's address bar.
Good luck to you.
I hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
