Question about Acer AL2216W LCD Monitor
Overscan from my PS3 to my Monitor.
I've hooked up my PS3 to my monitor via HDMI to DVI. It worked but I have this huge overscan on the right side of the screen. I can't change the H.Position or the V.Position from the monitor. Please help, thank you.
  • iancomings Aug 31, 2008
    I have the same problem, just a different model. I own the P201W and it does the same thing.
  • traclo Dec 17, 2008
    Same deal. Huge overscan with the monitor.
SOURCE: PS3 to Acer AL2423W
this link will help you:-)
http://forums.entechtaiwan.com/index.php?action=printpage;topic=4280.0
Posted on Jun 24, 2009
SOURCE: No HDMI Signal from my PS3 and it works on other monitors. Help?
I'm guessing it's the PS3.
When you turn on the PS3, HOLD down your finger on the power button (the one that turns it on/off, NOT the switch in the back) until you hear a second beep while the console is turning on.
It will completely reset your display settings. I have an HDTV and a HDMI, and whenever I switch from one to the other I HAVE to do this or I get no video on screen.
Posted on Apr 02, 2010
  • 201 Answers
SOURCE: Acer T230 H monitor Hdmi ConnectionProblem
I don't think your doing nothing wrong, but I may be wrong. I would just stick with the other connections. HOpe this helps!?
Please rate solution - Thanks.
Posted on May 14, 2010
damnor01
  • 1179 Answers
SOURCE: I have my PS3 hooked to the HDMI port, but the
There are a varity of HDMI cables, ensure that your version is supported also using the input touch "button" to change the input through VGA, DVI and HDMI.
damnor01
Posted on Nov 22, 2010
  • 3 Answers
SOURCE: Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Posted on Jan 30, 2011
How can i connect my sharp lc-26sh10u hdtv to laptop
Sharp had a standard VGA socket on it?, with an adaptor for connecting Component to it (via unused pins). but presumably you simply connect via a VGA lead and select the PC input on the menu
ure HD is cool on a computer monitor, but it's nothing like a huge HDTV.
How you do this will depend primarily on your PC and your HDTV. Lucky for us that they both share some common interfaces. The most common interface is DVI for computers and component for HDTVs. You have a few options here. S-Video and Composite won't work because they only carry SD signals and what fun would that be?
Before we get started I want to mention that all TV's are subjective to some overscan, yes all, but some more than others. At the very least 2% and at the very most 10%. Normally you don't notice, but when displaying your desktop on your HDTV even a small amount of overscan is noticeable. If you plan to watch movies and other videos it won't bother you. If you are planning to surf the web or play video games it can be more intrusive.
If you are one of the lucky ones who have a DVI port on your computer and a DVI or HDMI port on your HDTV. You can buy a180px-video_standards.png cable and set your computers output resolution to one that is supported by your HDTV. That is This seems pretty simple, but unfortunately it isn't always that simple. HDTVs and computer monitors don't always support the same resolutions. All the video standards are covered in this image. It is confusing but useful. The main thing to pick up from the image is that PC's don't use the same native resolution as HDTVs. Some HDTVs can accept standard PC resolutions like my Sharp AQUOS. To see which resolutions your HDTV supports check out the manual. Most companies have their manuals online so if you don't have yours head over to the manufacturer's website to look it up.
As you can see from the grid my HDTV supports most resolutions, the other great thing about this TV, is that there is no overscan at PC resolutions, but there is at normal HDTV resolutions. Unfortunately this is not the norm, but if you are one of the lucky few then you can grab a cable and connect it.sharpres_small.jpg
You can use VGA, component , DVI or HDMI to carry HD signals. Since digital is generally preferred you should use either DVI or HDMI. If your HDTV has a HDMI and since no computers have HDMI yet you will need to use an adapter from DVI to HDMI. Lucky for us, HDMI uses the same signaling technology as DVI.
Before you plug in your DVI cable from your PC to your HDTV be sure to set the resolution to one that is compatible with your HDTV. If your computer monitor and your HDTV only share one common resolution, set it to that until after you get a picture on the HDTV, then change it to the desired resolution. When possible always try to use the displays native resolution. For example my Sharp AQUOS's native resolution is 1280x768.
If the desired resolution isn't available from the display controls of your PC then you will need to add it. You can use apstrip_small.jpg great piece of software called Powerstrip to do this. Install it and then add the desired resolutions. To add a custom From here you can add a preset or user defined resolution. If your TV only accepts 1080i then use "1920x1080i 60hz". resolution to PowerStrip go into display profiles, then "Advanced timing options", then choose "Custom Resolutions". User defined resolutions are beyond the scope of this guide. The best article I have ever read on how to do this, is at the AVSForum. So check it out, but keep in mind that Powerstrip includes most of the HD resolutions for you, so you don't have to copy and paste the timings in yourself as described in the article. If you are a Mac user look for DisplayConfigX. Linux users need to add the custom resolution to their xorg.conf, you can find help here.
Unfortunately for most of us, it isn't this easy. Most HDTVs only accept a few resolutions and some only have component input. Since most PCs don't have component output, it can be a bit more difficult. Your best bet is to either buy a video card that supports component output like a Radeon X600, or to buy a VGA to component converter. Since the convert costs as much as a good video card, it usually makes sense to go with the new Video card. When shopping for a video card keep in mind that sometimes the adapter doesn't come with the card, even though the card supports it. My Radeon 9700 required me to buy an additional $29.99 adapter to unlock the component functionality. Luckily most of the newer Radeon cards now come with the cable. As always when using a cutting edge video card be sure to use the latest driver. But don't be scared to roll back a few versions if you have problems. The latest Radeon drivers have HDTV resolutions built right in, so there is no need for Powerstrip. You can still use it to tweak your setup if you want, not to mention the other 100 things it is good at. If you end up using the VGA to component adapter, then you will need Powerstrip to setup the correct resolution. Don't be afraid to try different resolutions to find the best one. I find that because all HDTVs have overscan, non standard HDTV resolutions can help to eliminate the overscan. It is important to keep in mind that it is possible to break your TV by sending it the wrong resolution. So make sure you understand what you are doing before you start to experiment too much. I wouldn't use any resolutions that is not preset without first reading the thread over at AVS.
Try it ..All the best
Dec 23, 2007 | Televison & Video
I have my PS3 hooked to the HDMI port, but the monitor won't switch inputs to the HDMI port. If I have something plugged into the dvi port it works fine, but I currently need only the HDMI port, and do...
damnor01
Nov 22, 2010 | Acer H233H bmid Monitor
AOC monitor 2436vh does not fill the screen using the HDMI connector. There is a 1 inch black border around the window. Controls to stretch the display are locked out (not accessible) when using that...
The "Best Solution" fixes a problem that is unrelated to the original poster. anononline19's solution is to fix the entire OSD being locked (displays OSD Locked when the menu button is pressed).
Original poster's problem can be fixed by changing your graphics card's "overscan" settings.
Overscan on ATI cards:
http://nigelt.wordpress.com/2009/09/21/overscan-options-in-catalyst-9-9-on-windows-7/
Overscan on nVidia cards is currently not supported.
Oct 16, 2010 | AOC Computers & Internet
Blank Screen using HDMI-DVI cable for PS3
Sounds like your LCD monitor isnt HD compatible.
Mar 17, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
How connect Panasonic TH-50PX75U to PC? it said the PX75 series cant connect to pc, cuz it dont accept pc signal. what i can do? send me a mail: tiancai_6969@hotmail.com thanx a lot dude!
You have to have a couple of things to make this work: 1) a PC with DVI or HDMI output, 2) a video card capable of 1280x720 resolution and 3) a video card driver/utility capable of correcting for overscan.
I have my laptop connected to one of the HDMI inputs via a DVI-to-HDMI cable. I have Windows at 1280x720 resolution on the DVI port (the external monitor). I set this through Control Panel-> Display. Once I did this I was able to see my PC desktop on my TV. The only problem then was the desktop was cutoff on all side. To fix this it was a bit more of an adventure and this solution would only work if you have an ATI Radeon video card.
I installed ATI Catalyst Control Center (CCC). In CCC, it recognized that I was connected to a Panny 50" plasma. Than enabled the DTV settings. Under those settings I put the video card into 720p@60Hz mode. I then had to create a custom format to shrink the screen to fit my Panny display. I then saved this as the default setting for the Windows desktop. Whenever Windows boots it runs CCC and sets this setting for me.
I hope that helps! It can be done and it looks great.
Dec 29, 2008 | Panasonic TH-50PX75U Plasma HDTV
Ps3 hdmi to tvmonitor dmi
You mean HDMI to DVI right?
You need a cable hdmi----->dvi, there are a lots of them, you will find them in any good tv/audio store or on the net. Buy one of good quality, you wont regret it, the differens betwin a good quality and a cheap one is huge
Good luck
Dec 08, 2008 | Acer Computers & Internet
Dvi connection to ps3
try to hold the power button for like 6 seconds until u hear a beep...
it will reset the display and adjust it to ur monitor...
hope this helps
Sep 20, 2008 | Samsung SyncMaster 940MW 19" LCD Monitor
Overscan
do you mean the top of the picture is cutt off? if so then go into tv menu and set screen size to 16:9 not auto. if that doesnt work then try settings on ps3 hopefully that works
Jul 23, 2008 | Toshiba 55H70 55" Rear Projection...
Magnavox 37MF337B/37 overscan only sometimes problem
This TV has a pixel resolution of 1366x768p
It will accept a 1920x1080i input from a high def source , but running a PC at 1920x1080i/p will cause the problems you describe, depending on what the PC is sending to the TV, because PC signals are not the same as high def.
Your PC should be set to a resolution as near to 1366x768 as possible. My PC allows 1280x768 and 1360x768. Try one of these for best results.
There are no settings on the TV to solve this problem.
Feb 06, 2008 | Philips Magnavox 42MF521D/37 Television
Acer AL2216W LCD Monitor Logo
252 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
