Question about RCA F27TF700 27" TV
Power flashing on and off
My RCA truflat TV stopped working without any signs of problems, now when I try to turn the TV on all I get is a flashing power button and it sounds like it is trying to turn on. What do you think it could be?
  • Anonymous Sep 27, 2008
    i have the exact TV fand the exact problems
  • RCA Master
  • 19,396 Answers
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
My rca truflat 27f520t27'' tv keeps turning off and all
There is some shorted component/s on the main power supply regulator baord to your TV. Work with main power board circuit is fatal to any inexperienced person, as 80% of the components at this stage will be Hot [electrically], when the set is switched ON. Without switch it ON, you cant check the voltages at this section. S, if you are not experienced to do this work, contact any experienced service technician to get this set repaired.
Jul 20, 2012 | RCA TruFlat 27F520T 27" TV
How can i change the video input on my rca truflat tv 27F520T without the remote
As there is no Menu button on its front panel. you can't select inputs to this TV without a remote control.
Jun 05, 2012 | RCA TruFlat 27F520T 27" TV
I have an 20" RCA TruFlat Digital SDTV that is
The problem sounds like a problem with a power supply or a power chip. These can be a cheap fix if you can find a cheap TV repair man, but expect to pay hundreds at a TV repair shop.
Mar 03, 2011 | RCA Televison & Video
My 27" RCA truflat shuts off immediately after turning it on, would anybody know the problem?
Hello Jdjmp, hi, the problem is on the power supply section of your TV, check the following for open, short, or leaking parts such as, transistors, diode, ICs, and bulging capacitors,
Apr 20, 2010 | RCA TruFlat 27F520T 27" TV
RCA TruFlat Won't Turn On!
Same problem with Sony. Unplug for 36 hours at wall and it should work
Aug 11, 2009 | RCA TruFlat 27F520T 27" TV
No video
Take out all of the leads going to the tele and replace them again. Make sure any hardware you have hooked up to the tv has the leads inserted correctly
Oct 14, 2008 | RCA TruFlat 27F520T 27" TV
RCA TruFlat 27F520T 27" TV Reset
Buy a new remote.
Look around the tv and find the menu button.
Generally there is a separate power button.
You can also download the manual:
http://tv.manualsonline.com/manuals/mfg/rca/27f520t.html
Dec 02, 2017 | RCA TruFlat 27F520T 27" TV
RCA TruFlat just up and died...
I had a problem similar. I found the menu tac switch leaky
Dec 04, 2007 | RCA TruFlat 27F520T 27" TV
Unlock rca truflat tv with no remote
Buy a universal remote and program it for the TV. That's the only thing that will work.
Sep 19, 2007 | RCA TruFlat 27F520T 27" TV
Rca 20F420T
if you can bring up the menu try using the volume up / down and channel up/down on the remote to change your selection. that might work
Sep 01, 2007 | RCA 20F420T 20" TV
RCA F27TF700 27" TV Logo
187 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
