Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Harley davidson fat boy 2005
Something keeps draining the battery
  • LennyL56 Nov 11, 2008
    76 harley,slow battery drain
    found coming out of the generator(four prongs)
    two had a slight groung,plugged in threw the regulator (wire going to battery)has a slight ground
    with wire disconnected from battery,voltage is recovering on its own
    What causes the problem???what has to be fixed??
  • 25 Answers
Regulator blead take ground wire off the reg and check volts between ground wire and goood ground shoud be less than 2.2 volts per h-d
Posted on Nov 26, 2008
  • 216 Answers
Every battery will loose some charge when its not in use. The first thing I'd do would be to put a voltmeter on the battery when its fully charged and then crank it up. If the voltage drops, you probably have a bad regulator
Posted on Aug 15, 2008
    Genius:
  • 2,028 Answers
You've got something that's pulling from the battery. It could be as simple as a loose connection or bare wire touching the frame, it could also be a bad relay, and this will generally show when testing for an open circuit. Check any added electrical devices. Also, keep in mind that the system on a Harley doesn't charge the battery, it only keeps it topped at where it's at. So, if you have a half charge on the battery, you can ride to Hawaii and back, and you'll still only have a half charged battery. This is where a battery tender comes in helpful for garage time. I'm afraid you're just going to have to start tracing wires, and checking relays.
Posted on Aug 14, 2008
Drain location for oil,trans ,and diff on a fat boy
oil and trans plugs on trans pan oil between shocks tough to get to,trans exaust side directly below trans door and it aint a trike trikebuilder harleys dont have differentials but you do change primary oil not rocket science but ya think a book might be a good idea i do
Jan 21, 2010 | Harley Davidson Harley-Davidson Motorcycle...
Oil drain plug? 08 fat boy cant find plug
bottom of trans pan 2 plugs one oil other trans oil should be on bottomfront of pan facing forward rather than strait down by the way heres the best advice youll ever get from a websight buy a book
Oct 04, 2009 | Harley Davidson Harley-Davidson Motorcycle...
2000 Fat boy starts sputtering and lights flash on and off
Check you battery terminal connections. Can't think of any other reason that the rear light should be fluttering. If battery is tight then trace through your circuit breakers with a test light.
Jul 27, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Where is the drain for a 2003 harley fat boy
There should be a hose that come off one rear corner of the oil tank, it either goes straight down to the frame with a plug directly underneath (has oil o'ring #11105). It could also just be a line that is attached to the swing arm with a hose plug in it and a funny spring clamp holding the plug in the hose. I think 2003 is the first solution though.
Jul 01, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Battery
remove the screws on each side of the seat using a 5/16 allen wrench, then remove the screw at the back of the seat and lift the seat off the bike. your battery is under the seat.
Mar 28, 2009 | Harley Davidson Harley-Davidson Motorcycle...
2005 Fat Boy will not start
if your battery is good and you have check the maxi-fuse and its good then you have a bad ground so check that, harley's complete circuits using ground
Feb 01, 2009 | Harley Davidson Harley-Davidson Motorcycle...
What color is the coil wire in a 1996 Fat Boy wiring harness?
I show Pink - coil to Ignition module and white/black - coil to harness
Nov 10, 2008 | Harley Davidson Harley-Davidson Motorcycle...
1998 dyna wide glide
check fuel level and petcock.getting fuel? next check for spark ground spark to cylinder fins and crank motor, no spark check cam postion sensor for voltage while cranking (if fuel injected check crank positoin sensor for voltage) if you get voltage replace coil
Jun 20, 2008 | Harley Davidson KNG America 026711...
Lands Phones Logo
183 people viewed this question
Top Harley Davidson Lands Phones Experts
Brian Mathews
Level 1 Expert
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
