Trouble shooting problem, Please help!
After restart the ac works for approximately 30 or 40 minutes, and then it stops and on the display screen a message pops up with E1 which talks about cleaning the filter. The filter was cleaned several times, yet the error keeps happening.
Whatever can be done without taking out the AC and taking it to a repair shop.
    Problem Solver:
  • 4 Answers
Probably a programming issue ( in a board or something ) might need to call a tech to come out or take it to a shop. under warranty?
Posted on Aug 14, 2008
My livestrong LS15 treadmill stops running after 6 mins. The manual under trouble shooting says it may be the mcb. The display is still on but is nonfunctional.
If you just run the belt with no one on it do you have this same problem or does it run fine? If it runs fine then you need a new walking belt. If it still shuts off then it may be your controller.
Jun 04, 2017 | Exercise & Fitness
Comperasor running e5 problem
Change capacitor motor and outdur working almost
But 3 minute working ok
After E5 error show display screen on indur with outdour fan stop but compressor sound
Apr 23, 2015 | Haier HSU18VC7-G Mini Split Wall A/C Unit
I have an RCA projection TV, model D52W19B. The TV powers on ok, stays on, and audio is normal. I don't get a picture. If I press the menu button, the menu will appear on the screen normally.
my guess is you either have a satellite or cable box try unplugging the system cable or satellite and set for 5 minutes and then plug them back and and restart the unit up and see if it comes back the gemstar module would some times lock up causing this problem . and please let me know if that get's you working or if there is more trouble shooting to be done
Nov 03, 2014 | RCA Televison & Video
Dryer stops, restarts minutes later
It seems like clogged vent problem but as I always say The best method is to do your home work and you must do total trouble shooting procedure and replace defective parts if necessary and
Best way is visual check and check for any faulty component and parts and check all thermostats and sensors and look for clogged vent or any damaged or rusty or cracked components and use step by step deduction method for trouble shooting
Dec 07, 2013 | General Electric Dryers
Our projector has said replace lamp for approx. 1 year. We did and it still saying to place lamp. Also it stops projecting after about 5 minutes and then 10 minutes later we are able to use it again for...
You need to reset the LAMP RUNTIME counter
1. Press the MENU button to display the menu screen
2. Press the UP and DOWN arrow buttons to select the "OPTION" menu
3. Press the ENTER button and then press the UP and DOWN button to select the LAMP RUNTIME
4. Press and hold the ENTER button for approximately 3 seconds
5. The LAMP RUNTIME screen will be displayed.
(Note: press any button other than the Power button to cancel the LAMP RUNTIME screen)
6. Press the POWER button to turn off the power
7. After the POWER button on the projector illuminates red you restart the projector
and check the LAMP RUNTIME counter it should be "0"
Nov 24, 2010 | Panasonic PT L735U Multimedia Projector
Blue Screen
please remove battery and ac-power for a couple of minutes and then try to reboot the computer.
if it still doesnt work, shut it down, remove battery and ac.
remove ram
connect ac-power
try to boot without ram
remove ac power
insert ram
insert battery
connect ac and try to boot again.
when the blue screen appear, please write down the top line that looks something similar to this:
IRQL_LESS_OR_NOT_EQUAL_ETC_ETC
and the line close to the bottom that says
STOP: 0x000021 (0x000+++alot of not needed numbers)
when you have done that please come back to me.
May 29, 2009 | Acer Aspire 4520-5141 Notebook
Nikon D90 Image playback Mode
Hi - My D80 allows the length of time the the image displays to be set using the menu system. You shouldn't have any trouble setting this. Mine can be set from 5 sec to 10 minutes. Lookup Monitor-Off in your manual.
Apr 27, 2009 | Nikon D90 Digital Camera with 18-105mm...
My XSA 975 telephone was accidently disconnected from the power outlet. When reconnected I found cannot dial out but can receive calls inward. I have tried disconnecting the AC adaptor and reconnecting...
I unplugged the AC Adaptor from the wall socket and left unplugged for an hour or so (a few minutes as per the trouble shooting advice page in the instruction manual did not work). I then reconnected the adaptor to the power and the phone returned to normal service.
Dec 04, 2008 | Lands Phones
Wont turn on
Normally there are steps to trouble shoot the problem. If you did not find anything useful such as the following suggestions to trouble shoot the problem then please visit the manufacturers information below, based upon the product information you have posted on here.
Let us know how things work out. Also, sorry to see no one has gotten back to you sooner!
Trouble shoot:
Take out batteries for a full minute then insert back in, try to restart. some times that resets it otherwise press the rest button on the device.
Check with the manufacturer for a possible firmware upgrade that might need to be installed in order to get this working or to see if this is a defective unit.
USB-Stick MP3 Player (1GB) Documentation
Feb 26, 2008 | Coby MP-C883 MP3 Player
Heating & Cooling Logo
170 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
