Question about NetGear WGR614 Wireless Router
Wireless router signal
I have a netgear wireless router upstairs and the computer that is directly below downstairs will not hold a signal. It seems to be recognizing the signal and is strong at points. I also have a laptop that will work with the router anywhere in the house. We have uninstalled and reinstaled a few times.
  • 477 Answers
Hi
It seems to be somekind of disruptions in your house try to change the wireless router to work in a different channel think its 6 default change it to 7 or 8. it can also be your network card that have hardware failure. seems like that if the laptop work properly.
Posted on Aug 14, 2008
  • 44 Answers
I suggest that you move the router around to find the strongest signal for you computer or if your computer has a small antennae try moving that fround for the best signal
Lou Margolis
Allied Electronics
How to connect a linksys e1500 router to a repeater?
Run an Ethernet cable from one of the LAN ports on the downstairs router to connect to the WAN port on the upstairs router. Result: 100% connection.
Jul 08, 2012 | Linksys E1500 Wireless-N Router with...
I got a wireless network connection home but the modem and router are both upstairs while my ps3 is downstairs. i bought wireless-g range expander model no. wre54g in order to expand my wireless network...
Hello
This not a big deal for a wireless network to work on downstairs, you need to check your connection and settings of the routers/computers. or just put a repeater for improvement of signal strength.
If the matter is signal strength, for the purpose see the TIP link below
http://www.fixya.com/support/r7245572-improve_signal_strength_wireless_network
Good Luck
Dec 13, 2010 | Linksys Wireless-G Range Expander (WRE54G)
I have netgear wgr614 upstairs my laptop downstairs loads pages VERY slowly what can I do
Verify that it is indeed a wifi signal problem by moving the laptop upstairs temporarily.
If this fixes the problem, you're getting poor wifi signal downstairs. Not much you can do with the elements at hand. So try adding another element: install a wifi signal repeater (around US$ 25) somewhere in the middle. Or you can run a cable (or use Powerline Ethernet - around US$ 100) to downstairs, and there install a wifi access point (US$ 30-60). Or directly connect the laptop to the newly installed network wire.
If the problem isn't fixed, you have some other problem on the laptop: most likely a faulty network configuration. Verify against whatever PC you have upstairs; they should have identical configurations except their IP address (if fixed instead of DHCP).
Just to be on the safe side verify the laptop is properly operating and immune from virus and malware. Not all slowdowns are the system's fault.
Happy navigation!
Jan 03, 2010 | NetGear WGR614 Wireless Router
I am running qwest DSL through a Linksys wrt160N that is brand new. it will work next to the router, but not upstairs or in the basement which is less than 15 meters. The upstairs bedroom is directly above...
If you have concrete floor slabs the the wireless signal from the Linksys will have a difficult time penetrating the floor slabs.
The wireless card in the computers will show a low signal strength.
Try altering the Linksys aerial to a horizontal position and also positioning the Linksys to another location.
You could be getting interference form other wireless sources, check the wireless channels of other wireless router/access points in your area. If they are broadcasting on the same channel then configure your Linksys to broadcast on an unused channel or one that has the weakest signal strength.
If none of these methods work then I would suggest you run network cables from the Linksys to upstairs and downstairs and not use the wireless connection.
If network cabling option is not an option then consider extending the wireless range with wireless repeater access points.
Nov 07, 2009 | Linksys WRT160N Wireless Router
No connectivity to 2nd desktop or laptop - although worked before
Hello....sudden loss of wireless on two computers, in the same home, may indicate that a powerful source of wireless interference has just arrived (since your wireless router light is still on).
1) Does the signal improve if you move the router, or move the laptop closer to the router?
2) Have you had any success with changing the channel on your router? (Login to router > select Wireless Settings > Channel)
If you have not moved furniture yourself, or installed a device which could interfere with the signal (eg a DECT phone), it's possible a neighbour's new router may be the culprit.
Please come back to Fixya if this does not help.
Jan 11, 2009 | NetGear WGR614 Router
Low signal from my wireless adaptor / router
Have you tried connecting the laptop in a different wireless network? Try changing the channel in your router and you may also upgrade the firmware of your router.
Oct 04, 2008 | NetGear WGR614 Wireless Router
Slow connection
Your slow connection could be affected by poor location wireless router (therefore poor signal strength), electrical interference, or even someone else with a wireless router transmitting on the same channel as your wireless router.
Try relocating your router away from solid walls, and/or move your computer or router to another location.
If your connection speed varies, could be electrical interference with appliance/s in your house, turn off all appliances, test your internet speed connecting then turn on one appliance at a time to determine which appliance is at fault (could have a faulty capacitor in the appliance)
Jul 24, 2008 | NetGear MR814 Wireless Router
Signal Problems
try to bring another laptop to the location where you are having problem and see if the other laptop will have the same problem. if thats the case the problem is with the router. You can try upgrading the router's firmware or change the wireless channel
Apr 21, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
82 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
