My GE Profile Arctica Stainless Steel Top Freezer Refrigerator makes high pitch sound that drives me crazy. The high pitch sound stop and start arbitrarily.At time when I remove stuff from the freezer and back on the back of the freezer the sound stops for a while and the continue. Initialy I thought that it happens only if the freezer is full. But iseems that it does it even if it is not full. . My GE Profile Arctica Stainless Steel Top Freezer Refrigerator makes high pitch sound that drives me crazy. The high pitch sound stop and start arbitrarily.At time when I remove stuff from the freezer and back on the back of the freezer the sound stops for a while and the continue. Initialy I thought that it happens only if the freezer is full. But iseems that it does it even if it is not full. .
Hi we also are unhappy with the frig it emits a high pitched whine! What did you do? We are trying to have ours replaced since we have only had in for 6 months.Hi we also are unhappy with the frig it emits a high pitched whine! What did you do? We are trying to have ours replaced since we have only had in for 6 months.
You can't post conmments that contain an email address.
I don't know - I would describe the noise as being like the wind blowing across a chimney. I have never owned a fridge that didn't make such a noise as it grew older - while it was on a cooling cycle and afterwards it sounds like water trickling. It doesn't seem to affect the performance though and I manage to ignore it.
could be the ice maker or the evaporator fan motor.you can try lifting the arm up on the ice maker and see if it stops,this will shut off the ice maker.also when you open the freezer door to lift the arm on the ice maker the evap fan motor should start when you open the door,you should hear it blowing around,is this the noise you hear?these are the two things i can think of that could make a noise up top,if not it could be the compressor or the condenser fan motor but these are down the bottom back of machine but still could be the problem,if the ice maker and evap fan motor both in the freezer are ok pull out the machine and remove the bottom back panel and check to see if the noise is coming from there where the condenser fan motor and compressor are,you're going to have to do some detective work to find the noise,hope this helps you out.
Ususally this is caused by a forein object has gotten hung in the suction impeller attached to the motor. the noise flucuates due to the housing flexes with the movement of the handle and rod. the housings are usually made of plastic and something very small can easily get stuck in it and stay for a very long time. The vacuum needs disassembled and the forien object removed from the fan housing... Hope this helps Sincerely Roger
Sounds like the evap motor and can be found at appliance parts pro part # AP3875639 $44.36/ the mother board if you would like to know is part #AP4436216 $134.95 but i would not waste the money.
Very common problem is the evap fan located in the freezer section is the cause. Sorry but this is controlled by the main board on the back and only way to fix the problem is with a new board. Sorry about the news but it is the problem.
were is the fan making the noise if it in the freezer and making noise check for frost eany frost you may have defrost problem if it is in the refrigerator change fan if is the condenser fan change
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Freezer fan whines when it runs...
I have a GSL25JFPDBS
