Question about Kenmore Oasis HE 27082 Top Load Washer
How did you get your repair so easily
We also suffer from the F1 defect and Sears will not cooperate in making the fix. They advised that we must first pay for the work and then try to collect the money back. I hear of stories of them offering to replace this defect but do not seem to cooperate at all with us after calling the 800 number
Call One Source 1 800 479 5899, option 2
Posted on Aug 19, 2008
When my oven almost reaches the temp during preheating, an alarm sounds and I recieve an error code F 1-2... The tech support line for Maytag(now Wirlpool)had no idea what this means and advised me to...
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
never heard of an F1-2 code but they make new stuff everyday. Go to this link to get tech data: Maytag library of manuals
Aug 19, 2010 | Ovens
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Oasis 110.273 "F1" error on inital and rinse cycle fill. Have already checked to make sure all connections were secure.
The F1 error on the Oasis is a known issue. Sears recalled the computer module because it's defective and produces this error along with F71 code errors. Unfortunately, unless your serial number meets their current criteria, they won't honor the recall because it expired on 08/31/2009 for some serial numbers. Best bet is to call and find out if they'll honor it. If you talk nice & originally bought it from Sears, they might. They did for me. But then we had to replace the RPS. Now the stator. This machine is an expensive piece of junk.
Nov 23, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I have a Kenmore washer model no.4174102000 that has broken and was advised it cannot be fixed. I have a Kenmore stackable dryer model no.41781042000 and am being told by Sears that I have to buy a new...
a stack unit is a very risky investment, altho it's understandable if you have limited space. if the hold downs on the washer are rusted out or broken thru you need to have someone weld them for you. That's how we used to do it where I worked but stacks are not usually easily worked on. I'm afraid you will probably have to get an entirely new unit or maybe a used one from a reputable used appl. dealer in your area. Check around, you might get lucky and find one relatively inexpensive
Aug 24, 2009 | Kenmore Washing Machines
Please advise on how to reset the F1 code? The continuious beeping is driving me crazy .. Thank you
It sounds like you need a new heat sensor installed. It will run you about $175.00 +/-
Jun 01, 2009 | Kenmore Kitchen Ranges
F1 error code on Kenmore Oasis He
Per Sears. To fix the problem. Unplug the washer for at least 10 min then push pause or stop 2 times and this will fix the problem.
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
2005 Mini Cooper Engine Cooling Problems
There is a problem with the thermostat gaskets. Often times they leak and allow cars to overheat. Check under your car and make sure that there is no coolant leaking. MINI has updated the gasket so if you get your car serviced at a mini dealer then your gasket will be updated. There is not a bulletin or recall for this replacement this would be at your cost.
Mar 01, 2009 | 2005 Mini Cooper
F1 Error Codes
sorry to be the bearer of bad news, but its the machine/motor control unit (circuit board). if you don't want to involve sears to get them to pay a portion of the bill, then go to searspartsonline and order one yourself. you'll need your model number to get the right part number ECU (which should be W10189966 rev A) which will run you about $150. replacing it is relatively easy is you're handy at home. sears service will charge you another $130 to install it. this will fix the F1 problem.
not sure if sears has finally recalled this washer. if they finally do, then all our problems go away (yeah, right).
Jan 18, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
87 people viewed this question
Sal De
fordexpert
Robert Rankin
