Question about Jenn-Air JMV8196 Microwave Oven
Everything works but no heating?
I have JMV8196AAS unit and today we realized that when we start the microwave the overall sound is louder and there is no heating??
If I use a sensor cooking (patato) seems like working ..as sound is normal sound. everything else seems to be working??? The turntable, the lights, etc ...but there is no heating and unussual sound ?? Can anyone help??
  • Crcranes2003 Feb 25, 2009
    everything works on JMV8196AAS but no heat!
  • Jenn-Air Master
  • 9,098 Answers
With inside light and turntable on, louder sound, and no heat, this is usually a shorted high voltage rectifier diode or a bad magnetron.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Aug 18, 2008
Electrolux microwave model fgmv185kfa made a loud pop and now won't heat anything and sounds louder than normal when running. Everything else seems to b working fine
SOUNDS TO ME LIKE YOU BLEW A FUSE WHICH IS INSIDE THE UNIT. IF IT'S UNDER WARRANTY TAKE IT BACK BECAUSE IF YOU OPEN UP THE CASING & FIX YOURSELF THIS VOIDS ANY WARRANTY
Dec 24, 2012 | Microwave Ovens
Microwave model MV-1510M is not heating, also sounds louder. Everything else is working, fan, lights, turntable etc..
If everything is working normally, except for heating, the likely cause is the magnetron.  Microwaves can be dangerous to work on, as the site below points out.  If you have an ohmmeter, it is possible to check the magnetron, but be certain to follow the precautions outlined at the webpage:
Oct 08, 2010 | LG LMV1680ST Microwave Oven
Microwave won't turn on
When you say that the microwave won't turn on, can I assume that you mean that the food does not heat up! If that is the case, the problem lies with the magnetron circuit. This circuit consists of the transformer, rectifier and the magnetron, the part that generates the microwaves to heat the food. If it is the magenetron, then it probally not worth fixing since the cost to purchase the magnetron is almost as much as a new oven. To diagnose if it is the magnetron that has failed, when you turn on the oven, do you hear a louder that normal hum or buzzing sound? If that is the case, then it means that the magnetron is shorted and needs to be replaced.
Hope this helps.
Jun 18, 2010 | Sharp R-1502 Microwave Oven
The microwave does not heat..after reading everything about the magnetron my one question is this an easy job that an ammature can tackle or do I really need to call in a service man?
I'm having the same problem with my microwave -- GE JVM1533WD 002.
The inside light, cooling fan and turntable are all working but it is no longer heating food when the Start button is hit.
The unit is noticeably louder than normal, too.
Any suggestions? Thanks in advance for your help.
Jun 09, 2009 | GE JE1660 Microwave Oven
Turns on but not heating food sounds a bit louder
Hi, this is common in most microwaves. this abnormal noise is coming from a faulty Magnetron. this device is responsible for the heating process and, it is damaged and not heating at all at this point.Simply replace the Magnetron and, this unit will start to heat once more.
May 31, 2009 | GE Profile Spacemaker Over-the-Range...
Under cabinet microwave went cold today. Other electrical accessories okay
Most microwaves have an internal fuse. There is a good chance it is blown. Check your manual see if this is easily replaced. The other issue is of course why it blew the fuse in the beginning.
May 04, 2009 | Microwave Ovens
Our Jenn-Aire Model JMV8196AAS Microwave is not heating anything.
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Mar 07, 2009 | Jenn-Air JMV8196 Microwave Oven
Jenn-Air JMV8196 Microwave Oven Logo
310 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
