Stereo problems Everytime i go to turn on my jvc stereo it flashes "status" then "protect". After that it turns off. I dont know what the problem is.
    Genius:
  • 1,550 Answers
You got problems on the audio amplifier part of the stereo
Posted on Feb 11, 2009
SOURCE:
Protect comes audio
Unplug the speakers from the stereo, then try and power it on. If your problem continues, check the internal fuses on the stereo.
Aug 03, 2013 | JVC HX-C6 Shelf System
"PROTECT" message in display.
two cables of a speaker were touching each other.
this may be the problem
Dec 29, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
My JVC car stereo display " Protect " on display
FIRST PRESS THE RESET BUTTON BEHIND THE FACE IF DONT WORK CHECK ALL SPEAKER WIRES SOMETHING MIGHT BE TOUCHING
Jul 24, 2011 | JVC AM FM CD DET FACE CAR STEREO
My stereo won't work. Whenever I try to turn it on, it always turns off saying "protect." How can I fix this?
The protect has come on because it senses an output load problem, Turn the unit off, unhook the speakers and wires from the stereo, now turn the unit on and turn the volume down as far as it will go, this should reset the processor ic, if the word protect stays off you have a short in the wiring or bad speaker. If the protect comes back on with everything unhooked the problem is in the audio output ic pack in the stereo and will require a technician to remedy.
Jan 17, 2011 | JVC MX-KC58 Shelf System
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
Jul 22, 2010 | JVC AM FM CD DET FACE CAR STEREO
Everytime i turn on the stereo it shuts off an says protect
When sound system shows Protect that means it got problem in amplifier section and protection circuit is activated that shuts down system in safety. Qualified tech will fix it.
Jul 31, 2009 | JVC HX-C6 Shelf System
I have a jvc home stereo model number CA-HXC6 i have had it for a few years its on protect mode and i cant get it off dont know how it cuts off
Turn off power, unplugg unit, very carefully check speaker wire connections making sure no wires are touching each other or the back of the unit same at speakers connections. Also check speakers. Blown drivers can short terminals internally. This is the most likely problem. Remove the short, unit will come back on
Dec 21, 2008 | Bose 901 VI Main / Stereo Speaker
Protect
The protect message indicates that a problem has been detected in the final output stage of the amplifier. The most common failure parts are the output transistors. Plan on a parts cost between $15-$40. Add in the local labor rate for the total repair cost.
Dan
May 28, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
JVC HX-D77 PROTECT!!!
MAKE SURE YOUR SPEAKER WIRES R CORRECTLY COLOR MOUNTED INTO OR CROSSED INTO THE STEREO
Dec 25, 2007 | JVC HX-D77 Shelf System
PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
That could meen that something is improperly connected. You should try to disconnect everything, and then reconnect it step by step.
Oct 11, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
106 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
