Question about RCA 36V430T 36" TV
Turns off and on continuously
I've turned up the "screen" adjustment on the back so i could see when it turns on. Continously comes on then shuts down. No sound while on. doesn't seem to be getting enough power to stay on or deguass either
  • boomerkentuc Oct 07, 2008
    My tv will turn on and then turn right back off. Some times it wont even stay on long enough to show a picture.
  • franciservin Oct 15, 2008
    This tv is in the repair shop for the third time. The first time was in July of 2007. The tv started turning itself off in March of 2007 and coming back on, by July, it would not come on at all. Now, the repair shop is telling me it cannot be fixed, something with the board having more cracks, whatever that means, somehow trying to put the blame on me!!!
  • 4,234 Answers
The fact that there is no sound is an indication that the regulator circuit is faulty. This set should get a detailed repair estimate. This is not easily diagnosed remotely without takeing measurements internally. If you can get the estimate and post the results here, I should be able to walk you through the actual repair.
Posted on Aug 14, 2008
I turn my Apple Ipad on and select a game...30 seconds later it shuts down
Make sure your battery is fully charged or just run with a power cord. Also, the battery could be bad.
Dec 05, 2017 | Apple Cell Phones
Odes dominator 800
Turn key and Yes pump should run then shut off.The only time i've seen new pumps continue to burn out is if All(maybe more than one) fuel filters are not replaced.Hope this helped.Richard
Apr 28, 2014 | Computers & Internet
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
It will not turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Aug 18, 2012 | RIM BlackBerry Curve 8520 Smartphone
Panasonic TC-P42X1 acts like it is turning on, the screen turns black, then the tv shuts itself off and back on again.
Rule out any loose contacts in power outlet, RC Jack, cables and connectors. The problem described by you calls for opening the back cover and further investigation, which should only be done by a qualified service technician.
Aug 17, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
After baking at 425 degrees, ew30mc65js2 will not shut off - fan continues to run and some heat, although lower, continues after 1.5 hours
Hi - if you still have your user manual I think you will find that oven have a time delay designed into the electronics for cool down purposes after the cycles completed. If it does shutdown after say 1.5hrs, it may seem a bit long but its actually doing what its designed to do, it should not be heating but circulating the hot air thru the oven.
We use to have a similar problem with our F & P BI600 wall oven - what we've done is have the door slightly ajar to quicken the cool down process until one day the fan ran continously - then I had it disconnected.
I hope this may help with your situation, if its running continously then its best to disconnect the cool down fan, the bake fan is normally on a separate circuit and not affected.
Jul 13, 2011 | Electrolux Ovens
Sony KP-511HW40 fleshing with green color and shuts off
this is a common fault adjust the little black box in front behind the small wooden cover. you will see 6 controls don't adjust any of the top 3 only the bottom knobs 1 for each color. slowly back the control counterclockwise turn the set on and wait untill it shows a picture, slowly adjust the control for the color in question utill the color balance is correct- black and white with the color setting turned down all the way with the user menu when balance is ok you are all set.. turn the color back up with user control. rtepeat process if needed.
Dec 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Fuji s2pro (2 units)
Your shutter mechanism reached its life expectancy, (5000 shots).
Aug 23, 2007 | Fuji FinePix S2 Pro Digital Camera
RCA 36V430T 36" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
