The bigger of the two pipes of my central air unit is frozen and i am getting very little cold air please help
Sounds like you have either a low refrigerant situation or an airflow problem. The lack of cold air is most likely due to a frozen up evaporator coil. You should check your filters and call your service man.
Posted on Aug 14, 2008
Bryant central a/c working great, then suddenly inside fan not working, but outside unit on and pipe frozen.
sounds like inside coil froze due to low air flow. bad fan motor, fan relay,dirty coil or filter.
Sep 09, 2013 | Bryant Heating & Cooling
My central air AC unit (Double wide home) always works for generally up to two hours, then it freezes up, by the copper pipes ice over, shutting them off and letting them thaw out, works to get it going...
You are absolutely right! The copper pipes should have insulation them. When they don't and they get cold in hot weather, they sweat and then freeze. Tubular Foam Insulation is what you need. Most home centers carry it. Once you cut and install it, be sure to wrap it in a good quality Duct Tape.
Hope this helped you. Good luck.
Jul 15, 2011 | Coleman Heating & Cooling
My central air conditioner is making a whistling noise in the inside unit when the compressor is running. It's not the blower because the noise stops after the outdoor unit shuts off. It's also not blowing...
If there is no cooling (meaning no cold pipes and not blowing cold air) then check the outdoor A/C for any visible/obvious issues; breakers not tripped, no debris blocking the outside unit from passing air through it, etc. If all looks ok, you can start checking some things inside of the unit if you feel comfortable doing so. Also, most indoor heaters have a higher speed/rpm for the fan when the cooling kicks on, and the heat runs on a lower speed/rpm.
Hope this helps James
Apr 05, 2011 | Heating & Cooling
Frozen pipes coming from my outside heat pump and going to my inside unit
Frozen in suction line (bigger pipe) line due to indoor coil,airfilter and blower wheel dust blocked. Service the unit.
Second reason is short of gas. -Find out the leak and arrest it. And then do gas charging after vacuuming.
Dec 26, 2010 | Heating & Cooling
Hi there,any advice please on frozen pipes..no water at all,no toilet,shower..can i use my central heating?...im forozen..
You will need to get to the pipes with a torch or heat gun and melt the ice out allot of times when the pipes thaw out you may have busted pipes with long cracks running down the pipe. The best way to handle this is to turn off the water to your house and inspect the pipes I would go and purchase some heat tape and cover all the pipes in exposed areas (crawl space, attic, and basement) and let the heat tape thaw out the pipes. after about an hour turn off all your inside valves ( tubes, shower, sinks and the cold water to the water heater) then turn your water back on and watch the meter at the street if it spins then you may have busted pipes.
1- Turn off water at the meter by the street.
2- Thaw out pipes with torch or use the heat tape.
3- Close all valves in house including cold water valve at the water heater.
4- Turn water back on at meter and mark on the meter where the hand is now then watch to see if the meter is turning.
The heat tape will keep you from freezing pipes in the future.
Hope this helps..............
Dec 07, 2010 | Heating & Cooling
How to add freon to central air conditioner
dear sir
if you have some knowledge about air conditioner system then first connect hose with suction side of aircon pipe conector(valve) with Gage and second hose with cylinder and GAGE .during of this you must remember don,t forget to open valve before START this job then make your ac unit vacuum it should be 18-20 micron after vacuum fill freon (approxmatily 60-65 pci)
and check your aircon system,s evaporator all pipe has been cold not and any pipe is getting ice on it .if its reach pressure 60-65 psi AND YOUR AIRCON BLOWING COLD AIR then it,s good the close by cup nut on the connecting point and remove hose from connector and disconnect Gage from system .
(but please don,t do if you have not proper knowledge it can be dangour)
warning: if you don,t have knowledge to do this please don,t try
thank you
hope answer the question
Aug 22, 2010 | Whirlwind FH-778 Air Conditioner
Hi have central air . Unit working ok but noticed not blowing cold air . The fan outside is working , Unit comes on . Could it be feron . unit it about 7 years old . Purchase house about 4 years ago
You need to have a pressure gauge the reads for R-22. (Freon) It sounds like the system might have a leak. Look for a wet place any place on the units pipe system. It has a little oil in with the freon that is forced out of any leak. If you see a wet place this is oil. It is also the location of your leak.
Jun 27, 2009 | Heating & Cooling
AC is running but can't keep the temp down. Everything is brand new. AC unit is on shady side. New filter, no cloggs. No clog in drip pipe. Condinsation building up on pipes outside. Please help.
If the big pipe out side is cold and sweating and the little one is warm to touch if it is hot to touch under charged. I would suspect insulation, or under sized unit
is their a 20f difference from supply air to return air the i would lean towards insulation. Tom
Jun 25, 2009 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
128 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
